    [Plugin] SolidSolver
    129 Posts 40 Posters 104.8k Views 40 Watching
      Here's v1.4 http://forums.sketchucation.com/viewtopic.php?p=359994#p359994
      A daft typo in the heal small faces/holes code has been fixed.
        rachmatrf
        Thank you TIG. You Rock!
        • kenK Offline
          ken
          Found an interesting error. If I use this program to fix a non solid, and do nothing else except go to the file save option to save the file. Before the file is saved, the solid reverts back to the non solid status. If I do something other than go to save, like draw a line the file will save without reverting to the non solid.
            Weird... I'll try to reproduce it... πŸ˜•
              Anton_S
              Thanks, TIG!
              SolidSolver is incredibly easy to use. Just go through a couple of steps and ur model is a solid! 😲 Although, it won't completely solve shapes that have edge with 3+ faces, but I understand it's complex. πŸ‘
              • jgbJ Offline
                jgb
                TIG; Just curious.... 😐
                Any reason SS does not work on components, but only on groups?
                Since almost all my drawings are made of solid comps, I only use groups to keep stuff together, or for layering options. When SS says "Select a group..." when I select a comp, I have to edit the comp, select all, and group it to work, then explode the group. A bit of a pain.
                Otherwise it works reasonably well on SU 8-Free. I generally like to cleanup my solids manually, after SI reports problems. SS tends to clobber very complex solids, which I generated in a quick but sloppy manner, so the fixing after SS may take longer than doing the fix manually in the first place.
                Mind you, SS is far more adept at fixing some real toughies, such as co-linear lines, and co-resident faces. I had one "celebrated" comp that had 7 (count-em) 7 co-resident faces in 3 places. I went nuts fixing one of the faces, then sent SS after the others. I only had to redraw 2 lines to fix that after. πŸ‘ πŸ‘
                jgb
                  It could readily deal with component instances too - it's just easy to write for a group...
                    Here's v1.5 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                    it now works on groups AND component instances; makes the result unique, if needs be.
                      Anton_S
                      πŸ‘ 😍
                      • jgbJ Offline
                        jgb
                        Thanks a bunch. I'll check it on Sunday.
                        jgb
                          smicha
                          Thank you TIG. Great work as always.
                          • jgbJ Offline
                            jgb
                            TIG;
                            Seems to work fine with comps now. Thanks for the response.
                            jgb
                              Bertier
                              @pout said:
                              Hey Tig, ...
                              Hey Pout good to see you there !
                              Sorry not to see you in Boulder !
                                Sergio Morera
                                Brilliant as usual!
                                  Here's v1.6 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                                  It has:
                                  • Improved internal partition removal, even when they are not full width etc.
                                    [It is still fool-able though!]
                                  • A context-menu item is now available if there is an appropriate selection.
                                  • Its progress ... is now indicated in the status-bar.
                                  • pbacotP Offline
                                    Thanks TIG. This is something I am looking at daily--ways to make solids.
                                    Probably an obvious idea to many: I was getting a shape that had way too many interior faces. I decided that with smoothing, I had very few outside surfaces to deal with. So I selected the outside surfaces one by one (double click) and grouped--and had a solid rather quickly, without fussing about the center.
                                    Your work on this is really appreciated.
                                    • cottyC Offline
                                      cotty
                                      Thank you for the update!
                                      my SketchUp gallery
                                        smicha
                                        Thank you TIG.
                                          Here's v1.7 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                                          It has some speed improvements.
                                          It has a better/harder-to-fool internal-partition removal algorithm.
                                          The removal of coplanar-edges [if any] is now a final option.
                                            Here's v1.8 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                                            It has some more speed improvements.
                                            It has an even better/harder-to-fool internal-partition removal algorithm.
                                            You can repeat the process once if it's still not solid.
                                            You may also need to try processing again 'manually' - if there are several internal-partitions facing each other etc...
                                            • 2 / 7
