    [Plugin] SolidSolver
    129 Posts 40 Posters 104.8k Views 40 Watching
      smicha
      Thank you TIG. Great work as always.
      • jgbJ Offline
        jgb
        TIG;
        Seems to work fine with comps now. Thanks for the response.
        jgb
          Bertier
          @pout said:
          Hey Tig, ...
          Hey Pout good to see you there !
          Sorry not to see you in Boulder !
            Sergio Morera
            Brilliant as usual!
              Here's v1.6 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
              It has:
              • Improved internal partition removal, even when they are not full width etc.
                [It is still fool-able though!]
              • A context-menu item is now available if there is an appropriate selection.
              • Its progress ... is now indicated in the status-bar.
              • pbacotP Offline
                Thanks TIG. This is something I am looking at daily--ways to make solids.
                Probably an obvious idea to many: I was getting a shape that had way too many interior faces. I decided that with smoothing, I had very few outside surfaces to deal with. So I selected the outside surfaces one by one (double click) and grouped--and had a solid rather quickly, without fussing about the center.
                Your work on this is really appreciated.
                • cottyC Offline
                  cotty
                  Thank you for the update!
                  my SketchUp gallery
                    smicha
                    Thank you TIG.
                      Here's v1.7 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                      It has some speed improvements.
                      It has a better/harder-to-fool internal-partition removal algorithm.
                      The removal of coplanar-edges [if any] is now a final option.
                        Here's v1.8 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                        It has some more speed improvements.
                        It has an even better/harder-to-fool internal-partition removal algorithm.
                        You can repeat the process once if it's still not solid.
                        You may also need to try processing again 'manually' - if there are several internal-partitions facing each other etc...
                        • cottyC Offline
                          cotty
                          15 minutes between updates, that is fast ๐Ÿ˜‰
                          Thank you!
                          my SketchUp gallery
                            smicha
                            Thank you!
                            Fast and accurate ๐Ÿ˜„ This is how TIG works ๐Ÿ˜„
                            Thank you again TIG.
                            • guanjinG Offline
                              guanjin
                              Updated version too fast, thank you
                                Here's v1.9 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                                Internal partition removal is again improved, multiple parallel face to face partitions now removed [up to ~10,000 per near-normal].
                                I have successfully tested it on several non-solids - including the dreaded 'coil' and some others with complex internal flaps and multiple partition faces, as well as holes etc...
                                Please report any 'breakages' and supply me with an example SKP so I can see what's up...
                                Sorry this update took so long but I had to go to the grocery store... ๐Ÿ˜‰
                                  smicha
                                  ๐Ÿ‘
                                  • guanjinG Offline
                                    guanjin
                                    Can not fix this broken surface of the sphere๏ผ๏ผ
                                    This tool can do a very good repairใ€‚
                                    http://sketchucation.com/forums/viewtopic.php?f=323&t=48557
                                      Unfortunately that method to heal holes in a sphere creates internal partitions.
                                      I scrapped to to solve the 'coil' problem...
                                      I'll look into a reworking...
                                        Here's v2.0 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                                        It has some improved hole healing.
                                        I have successfully tested it on several non-solids - including the dreaded 'coil', 'holey spheres' etc, and some others with complex internal flaps and multiple partition faces, as well as holes etc...
                                        Sorry this update took so long but I had to combine code from the latest version with an earlier one so that the 'coil' and 'holey spheres' are both 'solved'... ๐Ÿ˜‰ ๐Ÿ˜’
                                        • pbacotP Offline
                                          The coil ? ๐Ÿ˜ฒ Thanks TIG!
                                          • jgbJ Offline
                                            jgb
                                            NOT obvious..... A damned good idea. โ˜€ โ˜€ โ˜€
                                            (good thing I thought of it) ๐Ÿคฃ
                                            jgb
                                            • 2 / 7
