    [Plugin] SolidSolver
    129 Posts 40 Posters 113.1k Views 40 Watching
      Sergio Morera
      Brilliant as usual!
        Here's v1.6 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
        It has:
        • Improved internal partition removal, even when they are not full width etc.
          [It is still fool-able though!]
        • A context-menu item is now available if there is an appropriate selection.
        • Its progress ... is now indicated in the status-bar.
        • pbacotP Offline
          Thanks TIG. This is something I am looking at daily--ways to make solids.
          Probably an obvious idea to many: I was getting a shape that had way too many interior faces. I decided that with smoothing, I had very few outside surfaces to deal with. So I selected the outside surfaces one by one (double click) and grouped--and had a solid rather quickly, without fussing about the center.
          Your work on this is really appreciated.
          • cottyC Offline
            cotty
            Thank you for the update!
            my SketchUp gallery
              smicha
              Thank you TIG.
                Here's v1.7 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                It has some speed improvements.
                It has a better/harder-to-fool internal-partition removal algorithm.
                The removal of coplanar-edges [if any] is now a final option.
                  Here's v1.8 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                  It has some more speed improvements.
                  It has an even better/harder-to-fool internal-partition removal algorithm.
                  You can repeat the process once if it's still not solid.
                  You may also need to try processing again 'manually' - if there are several internal-partitions facing each other etc...
                  • cottyC Offline
                    cotty
                    15 minutes between updates, that is fast ๐Ÿ˜‰
                    Thank you!
                    my SketchUp gallery
                      smicha
                      Thank you!
                      Fast and accurate ๐Ÿ˜„ This is how TIG works ๐Ÿ˜„
                      Thank you again TIG.
                      • guanjinG Offline
                        guanjin
                        Updated version too fast, thank you
                          Here's v1.9 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                          Internal partition removal is again improved, multiple parallel face to face partitions now removed [up to ~10,000 per near-normal].
                          I have successfully tested it on several non-solids - including the dreaded 'coil' and some others with complex internal flaps and multiple partition faces, as well as holes etc...
                          Please report any 'breakages' and supply me with an example SKP so I can see what's up...
                          Sorry this update took so long but I had to go to the grocery store... ๐Ÿ˜‰
                            smicha
                            ๐Ÿ‘
                            • guanjinG Offline
                              guanjin
                              Can not fix this broken surface of the sphere๏ผ๏ผ
                              This tool can do a very good repairใ€‚
                              http://sketchucation.com/forums/viewtopic.php?f=323&t=48557
                                Unfortunately that method to heal holes in a sphere creates internal partitions.
                                I scrapped to to solve the 'coil' problem...
                                I'll look into a reworking...
                                  Here's v2.0 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                                  It has some improved hole healing.
                                  I have successfully tested it on several non-solids - including the dreaded 'coil', 'holey spheres' etc, and some others with complex internal flaps and multiple partition faces, as well as holes etc...
                                  Sorry this update took so long but I had to combine code from the latest version with an earlier one so that the 'coil' and 'holey spheres' are both 'solved'... ๐Ÿ˜‰ ๐Ÿ˜’
                                  • pbacotP Offline
                                    The coil ? ๐Ÿ˜ฒ Thanks TIG!
                                    • jgbJ Offline
                                      jgb
                                      NOT obvious..... A damned good idea. โ˜€ โ˜€ โ˜€
                                      (good thing I thought of it) ๐Ÿคฃ
                                      jgb
                                        Bertier
                                        great man TIG
                                          Ye all be donating to this lad, yes? Feed the man some cookies!
                                          • guanjinG Offline
                                            guanjin
                                            Thank you for TIG:
                                            Get a good fix on the different complex surfaceใ€‚
                                            ๐Ÿ˜
                                            • 2 / 7
