    [Plugin] Material Renamer
    29 Posts 12 Posters 35.3k Views 12 Watching
      Requires at least SU8M1:
      Sketchup.active_model.materials.each_with_index { |m,i| m.name = "mat#{'%03d' % i}" }
      • CadFatherC
        CadFather
        Good Gracious! thanks master thom, i am as grateful as i am shocked! 😲 😄
        EDIT: and i caught that! 😎
          Undo-able in one step:
          Sketchup.active_model.start_operation('Rename Materials',true); Sketchup.active_model.materials.each_with_index { |m,i| m.name = "mat#{'%03d' % i}"; p m.name };Sketchup.active_model.commit_operation
          • G
            greatoe
            Does this plugin work on a Mac?
              It should... try it...
              • bagateloB
                bagatelo
                This lines works fine in the ruby console. But the plugin script not.
                I loved!!!
                • bagateloB
                  bagatelo
                  I have a large collection of materials. Many of these are repeated,
                  and the names are all messed up.
                  I wish I could organize my these materials, permanently.
                  It would be possible to create a function that creates a number X of planes or squares,
                  according to the amount of material in the scene, and apply each material
                  in each box? Or just put a material in each plan? Create plans
                  is very simple.
                  After we can use the plugin "Material consolidator" to eliminate repeated.
                    is very simple.
                    CleanUp can merge material with identical properties.
                    • bagateloB
                      bagatelo
                      But it works only in applied geometry or can works in the material editor also?
                        Materials in the current model.
                        • bagateloB
                          bagatelo
                          It would be possible that the name of the material received something from RGB code and the level of opacity?
                          • bagateloB
                            bagatelo
                            Could you make a window that allowed us to enter the base name and the number of digits materials renamed?
                              Just edit mat#{'%03d' % i} >>> "mat001" to be say my_mat#{'%06d' % i} >>> "my_mat000001"
                              • bagateloB
                                bagatelo
                                I had seen it, just wanted to not have to edit these items. But that's okay.
                                It would be possible to get the base name for the materials from file skp name automatically?
                                  If you want to rename all of the materials by their RGBA then it's doable, just more awkward in a one-liner...
                                  mo=Sketchup.active_model;mo.start_operation('Rename Materials',true);ms=[];mo.materials.each_with_index{|m,i|n=m.color.red.to_s+'-'+m.color.green.to_s+'-'+m.color.blue.to_s+'-'+m.alpha.to_s;n=n+'#1' if ms.include?(n);(n.next!)while(ms.include?(n));ms<<n;m.name=n;p n};mo.commit_operation
                                  So you'll get "123-45-67-0.8". If two materials share exactly the same RGBA the second material will get a '#1' suffix to keep them uniquely named.
                                    ...it would be possible to get the base name for the materials from file skp name automatically?
                                    Yes, where the earlier code says
                                    change it to read
                                    m.name = "#{Sketchup.active_model.title}#{'%03d' % i}"
                                    • bagateloB
                                      bagatelo
                                      change it to read
                                      GREAT!!! Thanks...
                                      Sketchup.active_model.start_operation('Rename Materials',true); Sketchup.active_model.materials.each_with_index { |m,i| m.name = "#{Sketchup.active_model.title}#{'%03d' % i}"; p m.name };Sketchup.active_model.commit_operation
                                      • shannakaeS
                                        shannakae
                                        Not sure this has been brought up in this thread or in another, but I am looking for a way to organize my materials within each project. It would be so great to be able to organize them into folders or some sort of system that lets me group items together... I have a ton of materials in the project i am currently working on and have been trying to keep track of them by renaming them etc... but it becomes very daunting to look through them all. For example I downloaded a sketchup 3d file of books for my bookshelves in a family room I am designing... obviously I don't want to re paint all the books with colors in my model... and when I add the component into my model it also brings in all the new generic colors that further clutter up my materials library. It would be so great to create a folder or file system to group all the colors that are in the books together so that I don't get them mixed up with my other materials... needless to say it is a hot mess in my materials library. Please tell me someone has created a cool plugin for this or has a solution for me : ) Or am I missing something very obvious???
                                        • jolranJ
                                          jolran
                                          and when I add the component into my model it also brings in all the new generic colors that further clutter up my materials library..
                                          I hate to ask. You do do know you can purge unused materials ?
                                          In case not. In the Materialpalette, click the house to get to modelmaterials.
                                          The icons furthest to the right(blueish) click and choose purge unused.
                                          Otherwise there is maybe this:
                                          404 Not Found
                                          (sketchucation.com)
                                          or this ?
                                          404 Not Found
                                          (sketchucation.com)
                                          Take care.
                                          • shannakaeS
                                            shannakae
                                            404 Not Found
                                            (sketchucation.com)
                                            or this ?
                                            404 Not Found
                                            (sketchucation.com)
                                            Take care.
                                            Thanks, i will look those up. I do know about purge un-used (but I did just learn about it the other day so you are not so far off 😉 )Thanks! I will look up the two topics and see if there is something there that works for me... I was looking at the open or create a collection section... and was going to explore how that might work for what I am trying to do...
