    [Plugin] Material Renamer
    29 Posts 12 Posters 33.2k Views 12 Watching
    • CadFatherC Offline
      CadFather
      is there any script that can change the name of all the materials? say into 'mat001', 'mat002' etc..?
      EDIT: here it is, courtesy of ThomThom 👍 (you'll find it under the edit menu)
      TT_materials_renamer.rb
        Requires at least SU8M1:
        Sketchup.active_model.materials.each_with_index { |m,i| m.name = "mat#{'%03d' % i}" }
          CadFather
          Good Gracious! thanks master thom, i am as grateful as i am shocked! 😲 😄
          EDIT: and i caught that! 😎
            Undo-able in one step:
            Sketchup.active_model.start_operation('Rename Materials',true); Sketchup.active_model.materials.each_with_index { |m,i| m.name = "mat#{'%03d' % i}"; p m.name };Sketchup.active_model.commit_operation
              greatoe
              Does this plugin work on a Mac?
              • TIGT Online
                It should... try it...
                • bagateloB Offline
                  bagatelo
                  This lines works fine in the ruby console. But the plugin script not.
                  I loved!!!
                  • bagateloB Offline
                    bagatelo
                    I have a large collection of materials. Many of these are repeated,
                    and the names are all messed up.
                    I wish I could organize my these materials, permanently.
                    It would be possible to create a function that creates a number X of planes or squares,
                    according to the amount of material in the scene, and apply each material
                    in each box? Or just put a material in each plan? Create plans
                    is very simple.
                    After we can use the plugin "Material consolidator" to eliminate repeated.
                      is very simple.
                      CleanUp can merge material with identical properties.
                      • bagateloB Offline
                        bagatelo
                        But it works only in applied geometry or can works in the material editor also?
                          Materials in the current model.
                          • bagateloB Offline
                            bagatelo
                            It would be possible that the name of the material received something from RGB code and the level of opacity?
                            • bagateloB Offline
                              bagatelo
                              Could you make a window that allowed us to enter the base name and the number of digits materials renamed?
                              • TIGT Online
                                Just edit mat#{'%03d' % i} >>> "mat001" to be say my_mat#{'%06d' % i} >>> "my_mat000001"
                                • bagateloB Offline
                                  bagatelo
                                  I had seen it, just wanted to not have to edit these items. But that's okay.
                                  It would be possible to get the base name for the materials from file skp name automatically?
                                  • TIGT Online
                                    If you want to rename all of the materials by their RGBA then it's doable, just more awkward in a one-liner...
                                    mo=Sketchup.active_model;mo.start_operation('Rename Materials',true);ms=[];mo.materials.each_with_index{|m,i|n=m.color.red.to_s+'-'+m.color.green.to_s+'-'+m.color.blue.to_s+'-'+m.alpha.to_s;n=n+'#1' if ms.include?(n);(n.next!)while(ms.include?(n));ms<<n;m.name=n;p n};mo.commit_operation
                                    So you'll get "123-45-67-0.8". If two materials share exactly the same RGBA the second material will get a '#1' suffix to keep them uniquely named.
                                    • TIGT Online
                                      ...it would be possible to get the base name for the materials from file skp name automatically?
                                      Yes, where the earlier code says
                                      change it to read
                                      m.name = "#{Sketchup.active_model.title}#{'%03d' % i}"
                                      • bagateloB Offline
                                        bagatelo
                                        change it to read
                                        GREAT!!! Thanks...
                                        Sketchup.active_model.start_operation('Rename Materials',true); Sketchup.active_model.materials.each_with_index { |m,i| m.name = "#{Sketchup.active_model.title}#{'%03d' % i}"; p m.name };Sketchup.active_model.commit_operation
                                        • shannakaeS Offline
                                          shannakae
                                          Not sure this has been brought up in this thread or in another, but I am looking for a way to organize my materials within each project. It would be so great to be able to organize them into folders or some sort of system that lets me group items together... I have a ton of materials in the project i am currently working on and have been trying to keep track of them by renaming them etc... but it becomes very daunting to look through them all. For example I downloaded a sketchup 3d file of books for my bookshelves in a family room I am designing... obviously I don't want to re paint all the books with colors in my model... and when I add the component into my model it also brings in all the new generic colors that further clutter up my materials library. It would be so great to create a folder or file system to group all the colors that are in the books together so that I don't get them mixed up with my other materials... needless to say it is a hot mess in my materials library. Please tell me someone has created a cool plugin for this or has a solution for me : ) Or am I missing something very obvious???
                                          • jolranJ Offline
                                            jolran
                                            and when I add the component into my model it also brings in all the new generic colors that further clutter up my materials library..
                                            I hate to ask. You do do know you can purge unused materials ?
                                            In case not. In the Materialpalette, click the house to get to modelmaterials.
                                            The icons furthest to the right(blueish) click and choose purge unused.
                                            Otherwise there is maybe this:
                                            http://sketchucation.com/forums/viewtopic.php?t=17587
                                            or this ?
                                            http://sketchucation.com/forums/viewtopic.php?t=48933
                                            Take care.
