    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.0m Views 345 Watching
    • pbacotP Offline
      I am not sure of the question but the stretching tool alters the component itself,unlike the scale tool.
      If more than one instance of the component is in drawing, stretching creates a new component definition--so the original component is unchanged.
      • pjbazelP Offline
        pjbazel
        Hello all,
        This is my first post, but I have spent countless hours reading this forum and it has been the the most amazing SU resource. Im just learning, and I would have a fraction of my current knowledge/ability without this forum, not to mention the developers who make scripts for SU (thank you Fredo!!!) Im amazed how much effort and energy the individuals in this community are willing to give. Truly amazing!
        I now have my first question, or at least a question I could not answer simply by reading. I tried to search for the answer, I did not find it, but im sure its simple.
        Using Fredo scale box scaling, when I grab/drag a handle and scale it jumps from 1.0 to 1.05, and I can not get it to scale in this range (1.0-1.05) without typing the values. It would be very nice to stop this, and have it scale in this range without it jumping from 1.0 to 1.05.
        Is there a way to change this?
        thanks...
          Hm. I tried both with the native Scale tool and FredoScale and I can easily move my mouse in a way that it smoothly "grows" the numbers by 0.01 increments.
          • pjbazelP Offline
            pjbazel
            When I use the native scale tool it scales by .01 increments. But, when using Fredo Scale it jumps to 1.05, and then scales up from there at .01 increments. Very frustrating. There is a similar issue when using target mode with small (not minute, but small) distances.When using scaling handles I can type in the values between 1 and 1.05, but with target mode there is no way to get the scaling through the small distance.
            If anyone has any ideas please tell me what you think. There didn't seem to be anything in the settings to correct this.
              Can you share the model file (or at least the problematic part) you are working with?
                I see it too on a simple box. When the scale handle first moves it is either to 1.05 or 0.95. That's really no a big deal, though. If you want a precise scale factor, just type the desired value including 1.01 or whatever you really want.
                • pjbazelP Offline
                  pjbazel
                  I could upload a file, but Im not sure it would help. This is the behavior all the time. There is not particular file or problem area. It behaves like that all the time.
                  Should I upload a file? Will that help?
                  Again, its only with the Fredo Scale, not the native scale.
                  Let me know if you think it will help ill post one, but it appears to be the script, not a particular file/operation.
                  Thanks for the help guys
                  • pjbazelP Offline
                    pjbazel
                    Exactly, yes that's what mine does. Very frustrating.
                    yes, I can type it in, but this is not as useful as there is no real-time feedback/deformation. If its possible to change it I would love to know how.
                    Also, possibly more urgent is that fact that in target mode this 'jump' prevents the operation from occurring at all. Neither draging the handle, or typing in parameters produces a result when scaling in this small range.
                    Perhaps its a script issue?
                    • fredo6F Offline
                      @pjbazel
                      There is a parameter for fixing the minimum amount of scaling when dragging. Unfortunately, I did not make available for setting in the Default Parameters...dialog box.
                      I think I will in a next release.
                      In the meantime, you can modify the line 180 of file bootstrap_FredoScale.rb, which is:
                      LIMIT_InferenceScale = 0.05
                      Just change the value, for instance 0.01.
                      • pjbazelP Offline
                        pjbazel
                        @pjbazel
                        Ahhhhh, thank you so much Fredo! And thanks for all the wonderful toys!
                        One question, I tried to edit the .rb in a text editor but I was "denied permission". Can anyone tell me how should I go about editing the bootstrap_FredoScale.rb???
                        Thanks for the help.
                          You should be able to edit it in your text editor. What program did you try to use to open?
                          • pjbazelP Offline
                            pjbazel
                            Got it!
                            It was a security issue. I did not have full read/write access for the file. Just had to give myself permission, which i graciously did.
                              mac1
                              The attched skp files shows a very simple case using FredoScale 2.2a in the free rotate line inference mode. The plugin seems to declar an intersect point by changing the line color but when one double clicks on the line it shows no division until the base of the triangle is conneted with the line tool. Then intersect happens. All snapping has been deactivated for this case.Using Fredo6 4.5 lib.
                              free roate artifact or issue.skp
                              Is this normal ??
                              • fredo6F Offline
                                [attachment=0:1s75sq9r]<!-- ia0 -->free roate artifact or issue.skp<!-- ia0 -->[/attachment:1s75sq9r]
                                Is this normal ??
                                You are right. The extremity is well positioned, but the target segment is not divided.
                                Actually Fredoscale does nothing else than perform the rotation to the right angle and let Sketchup do the rest as with the native Rotate tool).
                                Should FredoScale force the Divide?
                                  mac1
                                  One of the first checks I do is double click the line and if does not divide I conclude some thing is wrong. However, this functionality is not high use ,at least for me, and knowing the artifact I cannot say it is a make play to make a program chage just for that. Maybe some high use users will comment. Otherwise I would suggest to make it a planned change( with other chages) if it isn't a big program impact.
                                  The cases I run into, although few, are 3d and so I use the sphere line intersect spread sheet I have.
                                  Your tool which is great and that cover all I need . πŸ‘ πŸ‘
                                  • cottyC Offline
                                    cotty
                                    I've seen a different looking toolbar in Richs Tutorial, do someone know a source for these icons?
                                    my SketchUp gallery
                                    • Rich O BrienR Online
                                      Fredo packages 2 icon types with FredoScale. Dig through the setting under Tools and pick Daniels icon set.
                                      Also I tend to change most of my icons
                                      • cottyC Offline
                                        cotty
                                        Thanks, I found it ...
                                        my SketchUp gallery
                                          thall26
                                          Hi!
                                          I am really excited to use your tools in Sketchup. However, I ran into a problem while starting up Sketchup. Attached is an image of the error box that I see upon starting Sketchup. Let me know what can be done. Thanks!
                                          • fredo6F Offline
                                            @thall26
                                            I think you did not install LibFredo6 companion library, as specified in the main post.
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 58
                                            • 59
                                            • 37 / 59
