    Probably no solution but what the hey
    32 Posts 12 Posters 2.4k Views 12 Watching
      Triangulate before you autfold...
      Here's a 15 segment internal and 8 external
      • daleD
        dale
        Yeah, I always do this with my laundry πŸ˜„
        • hellnbakH
          hellnbak
          [attachment=0:3oxfudex]<!-- ia0 -->PickPic 21.png<!-- ia0 -->[/attachment:3oxfudex]
          So you're saying I should draw in the lines before I move the circle?
          BTW, I rarely use the move tool for this (or anything else). I use Nudge, so I can't invoke autofold (at least I don't think I can, never tried).
            Or use a plugin. SketchUp is good but it can't read our minds yet so it doesn't know how to 'fold' the mesh. If you triangulate the outer ring then use move it'll will go smoothly.
            Never heard of Nudge.
            • hellnbakH
              hellnbak
              Ok, thanks, I'll give it a try
              It's a Smustard plugin. I use it all the time, it's one of those plugins that if I didn't have it I wouldn't want to use SU anymore.
              You can nudge a group, a component, a face, a line, anything, or if you want to nudge a point just draw a line from it and nudge the line. Any distance you want, any direction you want. Highly underrated.
              • MarianM
                Marian
                You should try the curviloft plug-in.http://forums.sketchucation.com/viewtopic.php?f=323&t=28586&hilit=curviloft It's nothing to it, select the lines and push a button and voila. πŸ˜„
                • ely862meE
                  ely862me
                  If the circles are brand new, usually they don't do that . It happens at time with other exploded ones, and with circles who don't have the same amount of segments. I sometimes divide the surfaces in four so you will get only triangles .
                  The only thing(when this happens) is to delete the messed geometry and create a new one or if they are not that much twisted use the Flip edge from the Sandbox tools .
                  I have now tried to recreate the scenario and I couldn't except with very misaligned circles.
                  Meanwhile let your frustration go ..
                  [flash=640,360:gmtdmmdi]http://www.youtube.com/v/mJ_fkw5j-t0?list=UUmKurapML4BF9Bjtj4RbvXw&amp;hl=en_US[/flash:gmtdmmdi]
                  Elisei (sketchupper)
                  Come and See EliseiDesign
                    Out of curiosity, why not use the same number of segments for all the circles? Then AutoFold would work just fine.
                    • hellnbakH
                      hellnbak
                      Well, as I make the concentric circles, I know that the smaller circles don't require as many segments to still look good when everything is smoothed out. Just trying to keep the poly count down.
                      • hellnbakH
                        hellnbak
                        Yeah, I know that using Curviloft would get rid of the problem in question, but many times when I'm doing something like this I'm using a texture, and I like to see what the object is looking like as I move the circles in and out till I get it just right. And yes, I know I could just apply the texture after I've used Curviloft and then make adjustments as needed, but doing that would require me to admit that I'm stupid πŸ˜†
                        • pbacotP
                          @hellnbak said:
                          [attachment=0:35n1l3kl]<!-- ia0 -->PickPic 21.png<!-- ia0 -->[/attachment:35n1l3kl]
                          Sorry to be dense, but if you didn't use autofold, how did you create the shape in question--that gives the bad transitions?
                            Peter, if you triangulate the surface, you don't need AutoFold which puts the "creases" in for you automatically.
                            Steve, I appreciate your desired to keep entity counts low but in this case, you're actually increasing the entity count because you have to have triangular faces instead of quadrilaterals.
                            • pbacotP
                              Thanks, I see that Dave. But Steve said he didn't use auto-fold so I wondered how could he have created the problem shape. Perhaps he just doesn't call it that.
                              Good point about the poly count!
                                I suppose since he's not using Move, he couldn't use AutoFold since it's sort of a modification of the Move tool. πŸ˜‰
                                • hellnbakH
                                  hellnbak
                                  I hate you
                                  • hellnbakH
                                    hellnbak
                                    πŸ˜†
                                      @hellnbak said:
                                      I hate you
                                      A "doh!" moment? πŸ˜„
                                        @Steve, πŸ˜†
                                        @Thom, doh moment when he realized he hates me or when he figured out the entity count thing? πŸ˜‰
                                          Double-win? πŸ˜„
                                          • hellnbakH
                                            hellnbak
                                            I hate both of you
