    Probably no solution but what the hey
    32 Posts 12 Posters 2.4k Views 12 Watching
    • hellnbakH
      hellnbak
      @dave r said:
      Out of curiosity, why not use the same number of segments for all the circles? Then AutoFold would work just fine.
      Well, as I make the concentric circles, I know that the smaller circles don't require as many segments to still look good when everything is smoothed out. Just trying to keep the poly count down.
      • hellnbakH
        hellnbak
        @marian said:
        You should try the curviloft plug-in.http://forums.sketchucation.com/viewtopic.php?f=323&t=28586&hilit=curviloft It's nothing to it, select the lines and push a button and voila. ๐Ÿ˜„
        Yeah, I know that using Curviloft would get rid of the problem in question, but many times when I'm doing something like this I'm using a texture, and I like to see what the object is looking like as I move the circles in and out till I get it just right. And yes, I know I could just apply the texture after I've used Curviloft and then make adjustments as needed, but doing that would require me to admit that I'm stupid ๐Ÿ˜†
        • pbacotP
          @hellnbak said:
          @rich o brien said:
          Triangulate before you autfold...
          [attachment=0:35n1l3kl]<!-- ia0 -->PickPic 21.png<!-- ia0 -->[/attachment:35n1l3kl]
          Here's a 15 segment internal and 8 external
          So you're saying I should draw in the lines before I move the circle?
          BTW, I rarely use the move tool for this (or anything else). I use Nudge, so I can't invoke autofold (at least I don't think I can, never tried).
          Sorry to be dense, but if you didn't use autofold, how did you create the shape in question--that gives the bad transitions?
            Peter, if you triangulate the surface, you don't need AutoFold which puts the "creases" in for you automatically.
            Steve, I appreciate your desired to keep entity counts low but in this case, you're actually increasing the entity count because you have to have triangular faces instead of quadrilaterals.
            • pbacotP
              Thanks, I see that Dave. But Steve said he didn't use auto-fold so I wondered how could he have created the problem shape. Perhaps he just doesn't call it that.
              Good point about the poly count!
                I suppose since he's not using Move, he couldn't use AutoFold since it's sort of a modification of the Move tool. ๐Ÿ˜‰
                • hellnbakH
                  hellnbak
                  I hate you
                  • hellnbakH
                    hellnbak
                    ๐Ÿ˜†
                      @hellnbak said:
                      I hate you
                      A "doh!" moment? ๐Ÿ˜„
                        @Steve, ๐Ÿ˜†
                        @Thom, doh moment when he realized he hates me or when he figured out the entity count thing? ๐Ÿ˜‰
                          Double-win? ๐Ÿ˜„
                          • hellnbakH
                            hellnbak
                            I hate both of you
                            • hellnbakH
                              hellnbak
                              How do I go about deleting this entire embarrassing thread?
                                Don't let it embarrass you. Someone else is sure to learn from it.
                                • hellnbakH
                                  hellnbak
                                  Where do I go to get back all the time I wasted fixing things I didn't need to fix? Some sort of form to fill out?
                                    I don't know but when you find it, let me know. I need the same thing.
                                    • mitcorbM
                                      mitcorb
                                      Back there a ways, somebody said they never heard of Nudge. The only thing in the Index is nudgeOrbit by TIG. Is there another tool?
                                        mwm5053
                                        File Not Found
                                        (www.smustard.com)
                                        2011 iMac
                                        SU 2015 Pro, 2017 Make
                                        V2 Twilight
                                        macOS Sierra 10.12.5
                                        • pbacotP
                                          Yeah, Nudge is good. I wouldn't say it replaces Move. I checked-- I guess it has "auto-fold" built in.
                                          Where do you get auto-fold for the laundry function?
                                            It's right next to the Iron tool. I always have difficulty with the Bleach tool. ๐Ÿ˜„
