    Dotted lines
    layout
    33 Posts 13 Posters 13.8k Views 13 Watching
    • pbacotP Offline
      OK then. πŸ˜„
        mal
        @dave r said:
        In LO, I would create two, overlapping view ports one for each of those scenes. I would render as vector or and then explode the one showing the demolition. After that, the lines can be turned into dashed/dotted lines using the Shape inspector box.
        Hi Dave, thanks so much for your suggestions on the Dave Method. Ive been trying to put it into action and managed the easy bits in SU but Im struggling a bit with everything that came after "in LO". Drawing new dotted lines in LO seems easy enough but I wonder if you could elaborate a bit on your comment. What I would like to know is: How do I render as vector? And how do I explode and change the lines to dashed? I spent quite a bit of time trying to figure it out and the only thing that exploded was my tiny mind lol.
        It seems quite an interesting method, and any suggestions you have would be much appreciated
        Mal
          Mal, let's see if this helps.
          http://farm9.staticflickr.com/8005/7681405418_76dcd4e095.jpg
          With a SketchUp viewport selected, click on the button in the SketchUp Model inspector labeled "Raster" and choose "Vector".
          http://farm8.staticflickr.com/7122/7681405698_c8c45ec03f.jpg
          After rendering as Vector, right click on the viewport and choose Explode. Note: it will no longer be tied to the SketchUp model.
          http://farm9.staticflickr.com/8021/7681405186_852792a7c0.jpg
          After exploding the viewport, the lines themselves will be highlighted. In the Shape Style inspector, choose the desired dashed line style, set the thickness and dash scale as desired.
          http://farm9.staticflickr.com/8434/7681405530_dde5804835.jpg
          Finished.
            mal
            Dave!!
            That is amazing, and so easy! Thanks for the seamless instructions. Just what I needed.
            Much appreciated!
            Mal
              mal
              By the way, I had a go at the Sonder Method, thanks Nick πŸ‘ , and it was just a breeze. Just push pull and poche, and thats it. The jobs done. Maybe if Im going to use SU, I should use its strongest attribute (3D graphics), rather than trying to bang it into shape to suit my old technique.
              I did the door swings in layout using the arc tool but they turned out like potato wedges... Any tips on avoiding that?
              Cheers
              Mal
              • pbacotP Offline
                Mal,
                Thanks for asking the right questions. I think the Dave and Sonder "methods" should be codified. I'm going to have to review them as well.
                I think the potato wedges come from the arc objects having a white fill. Remove the fill by toggle /clicking the "Fill" button in the Shape Style window (at least that's how it works on Mac--when I see the Windows screenshots it looks so different to me I'm not sure).
                Peter
                • emerald15E Offline
                  emerald15
                  Ahhh! I didn't know LO could do that! Thanks!
                    mal
                    Thanks Peter pbacot, the wedges are gone. I even have some dotted arcs showing doors to be removed.. Happy Days πŸ‘
                    Mal
                    • EdsonE Offline
                      Edson
                      Cheers
                      Mal
                      of course, you can do it later in LO but then you would have to it once for each door. my own way of doing this is: when I model a door component in SU I always create a hidden layer named 2D and place the door swing there. when saving a scene that shows a plan for exporting to LO I switch it on and save. thus you do it only once for each door. that is it.
                      http://www.mahfuz.arq.br
                        mal
                        Thanks for the tip Edson. Sounds like a good plan. Cheers
                        • ccaponigroC Offline
                          ccaponigro
                          Here is another idea. I draw lines in the model and use xline from smusterd.com to change them into guide lines which are dashed. Its crude but at least you can coordinate them right on your model. So if you’re not to persnickety about line type it works and you can place them on layers or hide then as you see fit.
                          sketchup model
                          layout view
                          cfcaia.com
                            mal
                            Good idea CC, I may well use that method. I would also like to reserve the right to use the word "persnickerty" on all of my sketchup drawings.
                            Thanks for the tips
                            Mal
                              I just though I'd add a better example of dotted lines in LayOut. The part indicated was originally lines in the model.
                                sonder
                                This thread is a good example of why I love the SU / LO combination. It is so customizable graphically. Really brings the fun back into what used to be the most miserable aspect of architecture. I love seeing all these different methods. Looking forward to basecamp!
                                  gabewill
                                  There is another way still...
                                  Make a scene with only the demo walls shown. Draw a plane that sits above your walls and is large enough to cover the extents of the scene. Put that plane on your demo layer.
                                  Create a style with BACK EDGES turned on. Set that scene to raster in layout, align a vector scene above it with the non-demo layers turned on.
                                  • TreblDT Offline
                                    TreblD
                                    Interesting approach Gabewill. To make the box clearer you gotta think outside the box πŸ˜„
                                    • heyitsmekyleH Offline
                                      heyitsmekyle
                                      Hi Guys -
                                      Just posted a reply to this under 'dashed lines' in the SU side of the forum. Expanding on my post, I've used the approach to do demo walls that show up Red in LO and with dashed lines as shown. These are tied to the model no need to update/explode/trace over. See my other post for more info.
                                      Cheers -
                                      Kyle
                                      1/8 Scale Demo
                                      1/4 Scale Demo
                                      • utilerU Offline
                                        utiler
                                        Hi guys, here's a few dashed line styles I've made for you to try out. Keep in might they are still only raster lines to in Layout they'll have to stay that way but they have been made as true straight lines....
                                        Hope they help. πŸ‘
                                        DASHED-Heavy.style
                                        DASHED-Medium.style
                                        DASHED-light.style
                                        Just Curious...
                                          heyitsmekyle
                                          Thanks Utiler! These look great. Applied them quickly here to a model just to check out the style:
                                          Sketchup - Dashed Lines
                                          • utilerU Offline
                                            utiler
                                            No worries Kyle, glad you like them. πŸ‘
                                            Just Curious...
                                            • 2 / 2
