    Dotted lines
    layout
    33 Posts 13 Posters 13.1k Views 13 Watching
    • ccaponigroC Offline
      ccaponigro
      Here is another idea. I draw lines in the model and use xline from smusterd.com to change them into guide lines which are dashed. Its crude but at least you can coordinate them right on your model. So if you’re not to persnickety about line type it works and you can place them on layers or hide then as you see fit.
      sketchup model
      layout view
      cfcaia.com
        mal
        Good idea CC, I may well use that method. I would also like to reserve the right to use the word "persnickerty" on all of my sketchup drawings.
        Thanks for the tips
        Mal
          I just though I'd add a better example of dotted lines in LayOut. The part indicated was originally lines in the model.
            sonder
            This thread is a good example of why I love the SU / LO combination. It is so customizable graphically. Really brings the fun back into what used to be the most miserable aspect of architecture. I love seeing all these different methods. Looking forward to basecamp!
              gabewill
              There is another way still...
              Make a scene with only the demo walls shown. Draw a plane that sits above your walls and is large enough to cover the extents of the scene. Put that plane on your demo layer.
              Create a style with BACK EDGES turned on. Set that scene to raster in layout, align a vector scene above it with the non-demo layers turned on.
              • TreblDT Offline
                TreblD
                Interesting approach Gabewill. To make the box clearer you gotta think outside the box πŸ˜„
                • heyitsmekyleH Offline
                  heyitsmekyle
                  Hi Guys -
                  Just posted a reply to this under 'dashed lines' in the SU side of the forum. Expanding on my post, I've used the approach to do demo walls that show up Red in LO and with dashed lines as shown. These are tied to the model no need to update/explode/trace over. See my other post for more info.
                  Cheers -
                  Kyle
                  1/8 Scale Demo
                  1/4 Scale Demo
                  • utilerU Offline
                    utiler
                    Hi guys, here's a few dashed line styles I've made for you to try out. Keep in might they are still only raster lines to in Layout they'll have to stay that way but they have been made as true straight lines....
                    Hope they help. πŸ‘
                    DASHED-Heavy.style
                    DASHED-Medium.style
                    DASHED-light.style
                    Just Curious...
                      heyitsmekyle
                      Thanks Utiler! These look great. Applied them quickly here to a model just to check out the style:
                      Sketchup - Dashed Lines
                      • utilerU Offline
                        utiler
                        No worries Kyle, glad you like them. πŸ‘
                        Just Curious...
                        • 2 / 2
