    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.5m Views 329 Watching
      @convta98 said:
      When I load Sketchup 8 i get an error message telling me that I need parametric.rb. Where can I get that file?
      IF you follow the advice in the main tool's download page... you'd know it's at http://www.Smustard.com - 'progressbar.rb'.
      http://www.smustard.com/script/ProgressBar
      ๐Ÿ˜ฎ
      I think 'parametric.rb' isn't needed by this specific tool - but that's readily available from the main Sketchup plugins page... http://sketchup.google.com/intl/zh-CN/download/rubyscripts.html
      Perhaps you have also installed some other tools that need that ?
        As far as I can tell, Shape Bender doesn't need parametric.rb but you should probably have it anyway because other plugins do use it. Get it here.
          Jspro
          Yes, is there anyone out there that can help me with the plugin Shape Bender by Chris Fullmer ? I believe I loaded it correctly but maybe not I'm getting an load error message , when I go into sketchup. When I downloaded the file I unziped it, I copied the file and pasted it into the plugins folder, restarted windows and when it came back on and i started sketchup with this Load Error ( Error Loading File clf_shape_bender_loader.rb no such file to load -- progressbar.rb ) . Can anyone help me? I tried this twice w/no luck I would like to get this to work. Thank you john
          • GaieusG
            You also need to install progressbar.rb for here: http://www.smustard.com/script/ProgressBar
            (The installation instructions clearly say this)
              sherwood11
              Well, I found a remedy .. kind of.
              I commented out all the lines updating the progress bar with a comment character, #
              . . . . #pb.update(i) . . .there are 7 of them.
              Unfortunately, I had to do that with clf_color_by_slope, clf_color_by_z and clf_greeble_2
              My system doesn't seem to like the progress bar. Even after downloading a fresh copy from smustard
              yesterday.
              If I find out why (it's a mystery), I'll post it.
              Again, it's a great Plug-in. ... hope this helps anyone w/ the same problem.
                Hasn't that nil error been repeated a few times along in this thread? Might be worth adding a note in the first post about it. No one is going to find it dug into n-number of pages.
                  sherwood11
                  I agree it's not the best .... just a trouble shooting remedy.
                  I'll try your approach.
                  TIG has suggested a few things also ... (my post on one of the other plug-ins)
                  Appreciate your input.
                    sherwood11
                    Plugin looks great . . . but, i'm getting this feedback :
                    it seems to lock-up at 7% or 20%
                    any suggestions ?
                    I posted a temporary trouble shooting remedy, just after this post.
                    http://forums.sketchucation.com/viewtopic.php?f=323&t=18210&start=1020#p422479
                    (is that what you mean ?, TT)
                      darksoft
                      Grate one ! THNX
                      • B
                        BenBo
                        Hi all,
                        Using the plugin with dynamic component it crashes.
                        Has anyone successfully bent a DC?
                        Otherwise, it works fine.
                          Since the Component [DC] is copied to make the bent version it may well conflict with a DC as there is generally only one instance of each variant.
                          You can copy the DC off to one side and explode it down to its raw geometry and then make a group of that, and then bend that group - it will have lost all of it's DC-ness, so those issues should be avoided...
                          It's a good idea to do complex operations, like bending, on an object located in a relatively empty SKP, and recombine things into a combo-model afterwards - so exploding the DC in these circumstances seems quite possible.
                          You can't expect a DC to retain its DC-ness/properties after bending it, as all of its axes etc will be messed up, even if it were to make it through the processing... ๐Ÿ˜’
                          • gullfoG
                            gullfo
                            grab TIG's "undc" script and run that before doing the bend.
                            Glenn
                            http://www.runnel.com
                              I'd forgotten I made that ๐Ÿ˜’
                              http://forums.sketchucation.com/viewtopic.php?p=382224#p382224
                              • T
                                tonkolan
                                it was awesome plugin tools
                                thanks for sharing
                                • gullfoG
                                  gullfo
                                  it's one of my most important tools now โ˜€ - i can use a huge number of DC in my models then "un-DC" them and ship the model out without worrying that my DC will be distributed...
                                  Glenn
                                    It's not even a 'tool'... just a 'code snippet'...
                                    Glad it was useful ๐Ÿ˜„
                                      maladzien
                                      Hey everyone? How do I run this script? I have no idea how to get this "tool" to show up in Sketchup to use it ๐Ÿ˜ž
                                        See if this article helps you: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                                        • G
                                          Geveltje
                                          Hello all,
                                          First I want to say that my english writing is not very good, so sorry for the mistakes.
                                          I have a little help from google ๐Ÿ‘
                                          I am very excited about the plugin, I just can not get it working properly.
                                          I select my component.
                                          Select the straight line
                                          Select the curve line
                                          I see that both lines a start and an end appears
                                          but that's all, nothing further happened. I can use the up and down arrow keys to change the start and end.
                                          Also when I press enter then nothing happens.
                                          the straight line is equal to the red axis, the curved line i tried on all axes.
                                          I really do not know what I'm doing wrong
                                          I hope I have explained clearly
                                          Thanks for the response
                                            Roy
                                            Have you installed the additional helper script progressbar.rb, which is download-able free from Smustard.com.
                                            It's a common issue with less experienced members forgetting about addition helpers like this for the more complex tools - although it is clearly mentioned and linked in the tool's download page.
                                            Also make sure that the 'line' is parallel to the X[red] axis and that it touches no other geometry, also note that the 'curve' must not touch other geometry either.
                                            Also don't try to bend tiny or enormous objects [most day-to-day sized things should be OK, but tiny parts for swiss-watches or entire cities will create issues]...
                                            If you are still getting issues then try running the tool after you've opened the Ruby Console. Post any error messages you get in it, this might give us a better clue as to what you have inadvertently done wrong ๐Ÿ˜’
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 63
                                            • 64
                                            • 52 / 64
