    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.2m Views 329 Watching
      Hasn't that nil error been repeated a few times along in this thread? Might be worth adding a note in the first post about it. No one is going to find it dug into n-number of pages.
        sherwood11
        I agree it's not the best .... just a trouble shooting remedy.
        I'll try your approach.
        TIG has suggested a few things also ... (my post on one of the other plug-ins)
        Appreciate your input.
          sherwood11
          Plugin looks great . . . but, i'm getting this feedback :
          it seems to lock-up at 7% or 20%
          any suggestions ?
          I posted a temporary trouble shooting remedy, just after this post.
          http://forums.sketchucation.com/viewtopic.php?f=323&t=18210&start=1020#p422479
          (is that what you mean ?, TT)
            darksoft
            Grate one ! THNX
              BenBo
              Hi all,
              Using the plugin with dynamic component it crashes.
              Has anyone successfully bent a DC?
              Otherwise, it works fine.
                Since the Component [DC] is copied to make the bent version it may well conflict with a DC as there is generally only one instance of each variant.
                You can copy the DC off to one side and explode it down to its raw geometry and then make a group of that, and then bend that group - it will have lost all of it's DC-ness, so those issues should be avoided...
                It's a good idea to do complex operations, like bending, on an object located in a relatively empty SKP, and recombine things into a combo-model afterwards - so exploding the DC in these circumstances seems quite possible.
                You can't expect a DC to retain its DC-ness/properties after bending it, as all of its axes etc will be messed up, even if it were to make it through the processing... πŸ˜’
                • gullfoG Offline
                  gullfo
                  grab TIG's "undc" script and run that before doing the bend.
                  Glenn
                  http://www.runnel.com
                    I'd forgotten I made that πŸ˜’
                    http://forums.sketchucation.com/viewtopic.php?p=382224#p382224
                      tonkolan
                      it was awesome plugin tools
                      thanks for sharing
                      • gullfoG Offline
                        gullfo
                        it's one of my most important tools now β˜€ - i can use a huge number of DC in my models then "un-DC" them and ship the model out without worrying that my DC will be distributed...
                        Glenn
                          It's not even a 'tool'... just a 'code snippet'...
                          Glad it was useful πŸ˜„
                            maladzien
                            Hey everyone? How do I run this script? I have no idea how to get this "tool" to show up in Sketchup to use it 😞
                              See if this article helps you: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                                Geveltje
                                Hello all,
                                First I want to say that my english writing is not very good, so sorry for the mistakes.
                                I have a little help from google πŸ‘
                                I am very excited about the plugin, I just can not get it working properly.
                                I select my component.
                                Select the straight line
                                Select the curve line
                                I see that both lines a start and an end appears
                                but that's all, nothing further happened. I can use the up and down arrow keys to change the start and end.
                                Also when I press enter then nothing happens.
                                the straight line is equal to the red axis, the curved line i tried on all axes.
                                I really do not know what I'm doing wrong
                                I hope I have explained clearly
                                Thanks for the response
                                  Roy
                                  Have you installed the additional helper script progressbar.rb, which is download-able free from Smustard.com.
                                  It's a common issue with less experienced members forgetting about addition helpers like this for the more complex tools - although it is clearly mentioned and linked in the tool's download page.
                                  Also make sure that the 'line' is parallel to the X[red] axis and that it touches no other geometry, also note that the 'curve' must not touch other geometry either.
                                  Also don't try to bend tiny or enormous objects [most day-to-day sized things should be OK, but tiny parts for swiss-watches or entire cities will create issues]...
                                  If you are still getting issues then try running the tool after you've opened the Ruby Console. Post any error messages you get in it, this might give us a better clue as to what you have inadvertently done wrong πŸ˜’
                                    Geveltje
                                    Hello TIG,
                                    Sometimes is the solution so simple that you overlook them
                                    I have the plugin and the progressbar removed and reinstalled and now it works perfectly πŸ˜„
                                    Thanks you for your answer
                                      pustko
                                      Hello everybody!first time posting.
                                      Yesterday I installed some ruby plugins for sketchup (8)and tried out the Chris Fullmer Shape Bender. After a while, I managed to make it work succesfully, bending the rqmp Im working at (architecture digital model). Everything fine and happy as hell.
                                      Then, this morning, same file, same computer, doing exactly the same steps, the bender tool doest work:
                                      I draw the figure, group it up, draw the line along red axis, same length, and the single curve. select group, open the tool,select the line,select the curve. the signs "start" "end" appear, I can change their position, but thats it! no green shape, no final bended figure.
                                      Maybe the answer is alreqdy somewhere in the forum, but theres a lot of posts, and i have so little time, i got a delivery today and have to finish the model as soon as possible.
                                      thanx in advance
                                        pustko
                                        I got the progressbar installed, etc
                                        Yesterday it was working neatly!! that's what buggin me the most.
                                        found this:
                                        n draw' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:671 Error: #<NoMethodError: undefined method /' for nil:NilClass>
                                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:671:in draw' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:671 Error: #<NoMethodError: undefined method /' for nil:NilClass>
                                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:671:in `draw'
                                          Pustko.
                                          The important part of any error message is the beginning...
                                          Please don't trim them.
                                          OK let's assume that the progressbar.rb is installed and called by this tool.
                                          After which step does this error appear?
                                          After picking the line, the curve or other ?
                                          Are you doing the other steps correctly ?
                                          axis?
                                          Is it freestanding and not touching any other geometry - faces, edges, curves etc?
                                          Is the 'curve' freestanding and not touching any other geometry - faces, edges, curves etc?
                                          If you still have issues try attaching a simple SKP you are having issues with...
                                          Or even some images...
                                          A picture paints a thousand words.
                                            pustko
                                            Hello TIG, thanx for the feed back:
                                            The error appears after selecting the curve. The process bar freezes at 2% or 5%
                                            The object is a "group", the line is in the red axis and doesnt touche anything, the curve doesn't either
                                            first time it worked perfectly πŸ‘ next dqy stopped working πŸ‘Ž
                                            the model is the simplest possible; I attach it.
                                            Yesterday I read the first 20 pages in this forum 😲 I think it might be a problem with compspray.rb or maybe SketchyFFD. At the office I have no "administrator acces" to remove them, but I will ask and try to remove them as soon as possible.
                                            Thank you.
                                            here' the beggining of the error message:
                                            Error: #<ArgumentError: comparison of Float with nil failed>
                                            (eval):44:in >' (eval):44:in update'
                                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:533:in exploder' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:526:in each'
                                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:526:in exploder' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:244:in onLButtonUp'
                                            Error: #<NoMethodError: undefined method /' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:671:in draw'
                                            (eval):44
                                            Sans titre.skp
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 63
                                            • 64
                                            • 53 / 64
