    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.3m Views 329 Watching
    • N
      nebin asharaf
      error: #<typeerror: no implicit conversion from nil to integer>
      C:/PROGRA~1/Google/GOOGLE~4/Plugins/clf_shape_bender.rb:168:in set_cursor' C:/PROGRA~1/Google/GOOGLE~4/Plugins/clf_shape_bender.rb:168:in onSetCursor'
      C:/PROGRA~1/Google/GOOGLE~4/Plugins/clf_shape_bender.rb:233:in `onLButtonUp'
      sombody help me please....
        I already cover this in a recent post [replying to you] http://forums.sketchucation.com/viewtopic.php?p=418523#p418523
        That error means it can't set the cursor it needs.
        This is almost certainly because it can't find the image file it needs.
        This is then because you have not installed the tool correctly!
        Please reread it and ensure that you have installed the loader file and the subfolder of helper files exactly as specified.
        Note also that if you have moved files out of the subfolder into the Plugins folder it will break things, so compare the 'correctly installed files' within the tool's subfolder and remove any files from the Plugins folder that are duplicated...
        The tool must have the subfolder of files in the standard Plugins folder - this is returned when you type/copy+paste this in the Window>Ruby Console:
        Sketchup.find_support_file("Plugins")
        You cannot have these files in another folder even if it is on the $LOAD_PATH - e.g. if you were using Fredo's alternative-folder tool...
        Unless you change the three lines of code in the main tool's file **clf_shape_bender.rb** that calls them...
        line_cursor_path = Sketchup.find_support_file("line_pointer.png", "Plugins/clf_shape_bender")
        becoming
        line_cursor_path = File.join(File.dirname(__FILE__), "line_pointer.png")
        and so on for the other two... then the toolset can go anywhere - provided that the loader and intact subfolder are together and on the $LOAD_PATH.
        • N
          nebin asharaf
          how can i post it
          mail id??
            @nebin asharaf said:
            how can i post it
            mail id??
            Post what ?
            If you follow the simple steps that be outlined you will get a working installation.
            It will not work until you fix the mis-located cursor files etc...
            If you want to attach an image [or file] etc onto your post then you use the 'Upload attachment' button below the panel into which you are typing your message... ๐Ÿ˜’
            • N
              nebin asharaf
              how to post
                Write a letter, put it in an envelope and put a stamp on it. Put it in the mail. Wait a few days and amazing things can happen. Job offers come, overcharges are returned, articles are accepted, contests are won. Results that could not come any other way. The power of a simple envelope is amazing.
                When you write a letter, someone on the other end will open it and read it. Unlike e-mail, a written letter is not easily deleted from the system. In todays technological world with e-mail, voice mail, and many web based apps, the written letter stands out from the crowd. Most people will not take the time to send one anymore.
                You can increase the effectiveness of your letter with some customization. A high quality letter on parchment paper, sent in a linen envelope will say volumes about the sender. Just like a business suit with a power tie, a classy envelope with a powerful font and a custom postage stamp exudes style and power. You can send this Lexus of envelopes for just a few dollars, and the results can be amazing.
                  Nebin, please ignore Rich he's being 'funny' ๐Ÿ˜’
                  BUT you are being too cryptic... post what? ๐Ÿ˜•
                  You are posting messages here, we are reading them.
                  You can post files and images, which you attach to them using the buttons below the typing-pane.
                  You can sens Private Messages to other users by clicking the PM button below their name or making a message in your own user-control-panel...
                  If you want to email someone [or send them something in the mail] then ask them for their details via a PM; they are unlikely to publish it to the world in the forums. ๐Ÿ˜’
                  • C
                    Convta98
                    When I load Sketchup 8 i get an error message telling me that I need parametric.rb. Where can I get that file?
                      IF you follow the advice in the main tool's download page... you'd know it's at http://www.Smustard.com - 'progressbar.rb'.
                      http://www.smustard.com/script/ProgressBar
                      ๐Ÿ˜ฎ
                      I think 'parametric.rb' isn't needed by this specific tool - but that's readily available from the main Sketchup plugins page... http://sketchup.google.com/intl/zh-CN/download/rubyscripts.html
                      Perhaps you have also installed some other tools that need that ?
                        As far as I can tell, Shape Bender doesn't need parametric.rb but you should probably have it anyway because other plugins do use it. Get it here.
                          Jspro
                          Yes, is there anyone out there that can help me with the plugin Shape Bender by Chris Fullmer ? I believe I loaded it correctly but maybe not I'm getting an load error message , when I go into sketchup. When I downloaded the file I unziped it, I copied the file and pasted it into the plugins folder, restarted windows and when it came back on and i started sketchup with this Load Error ( Error Loading File clf_shape_bender_loader.rb no such file to load -- progressbar.rb ) . Can anyone help me? I tried this twice w/no luck I would like to get this to work. Thank you john
                          • GaieusG
                            You also need to install progressbar.rb for here: http://www.smustard.com/script/ProgressBar
                            (The installation instructions clearly say this)
                              sherwood11
                              Well, I found a remedy .. kind of.
                              I commented out all the lines updating the progress bar with a comment character, #
                              . . . . #pb.update(i) . . .there are 7 of them.
                              Unfortunately, I had to do that with clf_color_by_slope, clf_color_by_z and clf_greeble_2
                              My system doesn't seem to like the progress bar. Even after downloading a fresh copy from smustard
                              yesterday.
                              If I find out why (it's a mystery), I'll post it.
                              Again, it's a great Plug-in. ... hope this helps anyone w/ the same problem.
                                Hasn't that nil error been repeated a few times along in this thread? Might be worth adding a note in the first post about it. No one is going to find it dug into n-number of pages.
                                  sherwood11
                                  I agree it's not the best .... just a trouble shooting remedy.
                                  I'll try your approach.
                                  TIG has suggested a few things also ... (my post on one of the other plug-ins)
                                  Appreciate your input.
                                    sherwood11
                                    Plugin looks great . . . but, i'm getting this feedback :
                                    it seems to lock-up at 7% or 20%
                                    any suggestions ?
                                    I posted a temporary trouble shooting remedy, just after this post.
                                    http://forums.sketchucation.com/viewtopic.php?f=323&t=18210&start=1020#p422479
                                    (is that what you mean ?, TT)
                                      darksoft
                                      Grate one ! THNX
                                      • B
                                        BenBo
                                        Hi all,
                                        Using the plugin with dynamic component it crashes.
                                        Has anyone successfully bent a DC?
                                        Otherwise, it works fine.
                                          Since the Component [DC] is copied to make the bent version it may well conflict with a DC as there is generally only one instance of each variant.
                                          You can copy the DC off to one side and explode it down to its raw geometry and then make a group of that, and then bend that group - it will have lost all of it's DC-ness, so those issues should be avoided...
                                          It's a good idea to do complex operations, like bending, on an object located in a relatively empty SKP, and recombine things into a combo-model afterwards - so exploding the DC in these circumstances seems quite possible.
                                          You can't expect a DC to retain its DC-ness/properties after bending it, as all of its axes etc will be messed up, even if it were to make it through the processing... ๐Ÿ˜’
                                          • gullfoG
                                            gullfo
                                            grab TIG's "undc" script and run that before doing the bend.
                                            Glenn
                                            http://www.runnel.com
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 63
                                            • 64
                                            • 52 / 64
