    What's this?
    65 Posts 15 Posters 3.7k Views 15 Watching
    • hellnbakH Offline
      hellnbak
      Hey Mike, I got to thinking about the seat back problem, and this is something I came up with.
      Adding the extra layer would let you increase the thickness of the seat back. This could also work with the wooden dowels.
      Probably not the look you were going for, with all the curves, I just started having fun with it πŸ˜† But you get the idea
      Anyhow, just an idea.
      • Mike LuceyM Offline
        Mike Lucey
        That works Steve, well done πŸ‘
        I am moving towards doing even a more straightforward design that doesn't involve curved plywood.
        This is great as it turning into a collaboration πŸ‘
          A square table and 4 square chairs ? 🀣
            Mike Lucey
            Now there's an idea 😲
              The Sqhair
              Economical on material too.
              Simply table-sawn and router rounded-corners etc as needed etc.
              The table can use a simple foot-operated bottle-jack mechanism to lift it up and on release lower down.
              The storage under the seats is set back a little to avoid heel-clashes.
              The seat-back half 'L' slides up/down on dado friction glides [Γ  la draw-slides] with a catch to it lock 'up' ?
              When the seats are removed from the assembly they are set around the table at 45 degrees on the sides of the square. The seats are on castors.
              Sqhair.skp
              • hellnbakH Offline
                hellnbak
                Nice, but those seat-backs don't look very comfortable
                  Mike Lucey
                  Now we are getting places.
                  TIG, would that table have a bit of wobble potential? Also I think Steve might be right about the backs not being too comfy.
                  Have you a pic of a 'foot-operated bottle-jack mechanism'? I'm curious about that.
                  I'm not so sure about the seats being on casters but they could be lockable. I think slides might work better.
                    ArCAD-UK
                    An octagonal shape applied to TIG's design would sort out the seat backs.
                    • soloS Offline
                      http://cdn.dornob.com/wp-content/uploads/2009/05/combined-wood-table-chairs-design.jpg
                      • hellnbakH Offline
                        hellnbak
                        One possible solution to the seat-back
                        Sorta looks like a toilet with the seat folded down πŸ˜†
                        • hellnbakH Offline
                          hellnbak
                          Maybe a couple of padded armrests for comfort (they could flip up for extra storage)
                            Mike Lucey
                            Nice render Pete. But that a full size table. We are trying to figure out a dual coffee / dining table.
                            Steve, yep! It does look like a commode ..... maybe an idea?
                            • hellnbakH Offline
                              hellnbak
                              When the meal is just too good to interrupt.....
                                Mike Lucey
                                πŸ˜†
                                  Mike Lucey
                                  ...... now a sound proof private curtain πŸ˜‰
                                  • hellnbakH Offline
                                    hellnbak
                                    Some cultures consider it a compliment to the cook when you belch at the table. This just takes the compliment to a whole new level.
                                      Mike Lucey
                                      .....may as well go the full hog and build in an air extractor πŸ’­
                                        Here's v2 with a more stable table base and a seat back...
                                        Sqhair2.skp
                                          Here's v3 - it has a more logical base made from swastika dado lapped 'base-feet' and a simpler back made form the same thickness foam as the seat...
                                          Sqhair3.skp
                                          • hellnbakH Offline
                                            hellnbak
                                            Good idea to make the seat-back lower with the rest of the back. I enjoy seeing how a project develops.
                                            Some questions -
                                            Why not make the seat-back flush with the top of the L-shaped assembly? It's very low anyhow, this would give more support.
                                            Are you going to round the edges of the wood?
                                            Will there be some sort of handle/cutout to grasp to raise/lower the seat-back?
                                            I'll go away now
                                            • 2 / 4
