    What's this?
    65 Posts 15 Posters 4.0k Views 15 Watching
      The table-top could have a concealed hydraulic ram - like a hatchback car's door, or even some 'springs to assist you in lifting it up easily. To lower it you'd release the 'catch' and it is damped as it settles down too...
      OR 'Ratchet' strips could also allow an incremental lift and lower using a simple sprung 'catch' [that could all be wooden]
      OR how about a 'lever' system in one of the legs [with a flip down/up pedal that is accessed when a chair is slid out] - that can then 'jack' the table up [like a car bottle-jack?] and when released it lets the top slowly settle back down... πŸ€“
      • Mike LuceyM Offline
        Mike Lucey
        Great suggestions TIG. I will play around with those.
        • hellnbakH Offline
          hellnbak
          Hey Mike, I got to thinking about the seat back problem, and this is something I came up with.
          Adding the extra layer would let you increase the thickness of the seat back. This could also work with the wooden dowels.
          Probably not the look you were going for, with all the curves, I just started having fun with it πŸ˜† But you get the idea
          Anyhow, just an idea.
            Mike Lucey
            That works Steve, well done πŸ‘
            I am moving towards doing even a more straightforward design that doesn't involve curved plywood.
            This is great as it turning into a collaboration πŸ‘
              A square table and 4 square chairs ? 🀣
                Mike Lucey
                Now there's an idea 😲
                  The Sqhair
                  Economical on material too.
                  Simply table-sawn and router rounded-corners etc as needed etc.
                  The table can use a simple foot-operated bottle-jack mechanism to lift it up and on release lower down.
                  The storage under the seats is set back a little to avoid heel-clashes.
                  The seat-back half 'L' slides up/down on dado friction glides [Γ  la draw-slides] with a catch to it lock 'up' ?
                  When the seats are removed from the assembly they are set around the table at 45 degrees on the sides of the square. The seats are on castors.
                  Sqhair.skp
                  • hellnbakH Offline
                    hellnbak
                    Nice, but those seat-backs don't look very comfortable
                      Mike Lucey
                      Now we are getting places.
                      TIG, would that table have a bit of wobble potential? Also I think Steve might be right about the backs not being too comfy.
                      Have you a pic of a 'foot-operated bottle-jack mechanism'? I'm curious about that.
                      I'm not so sure about the seats being on casters but they could be lockable. I think slides might work better.
                        ArCAD-UK
                        An octagonal shape applied to TIG's design would sort out the seat backs.
                        • soloS Offline
                          http://cdn.dornob.com/wp-content/uploads/2009/05/combined-wood-table-chairs-design.jpg
                          • hellnbakH Offline
                            hellnbak
                            One possible solution to the seat-back
                            Sorta looks like a toilet with the seat folded down πŸ˜†
                            • hellnbakH Offline
                              hellnbak
                              Maybe a couple of padded armrests for comfort (they could flip up for extra storage)
                                Mike Lucey
                                Nice render Pete. But that a full size table. We are trying to figure out a dual coffee / dining table.
                                Steve, yep! It does look like a commode ..... maybe an idea?
                                • hellnbakH Offline
                                  hellnbak
                                  When the meal is just too good to interrupt.....
                                    Mike Lucey
                                    πŸ˜†
                                      Mike Lucey
                                      ...... now a sound proof private curtain πŸ˜‰
                                      • hellnbakH Offline
                                        hellnbak
                                        Some cultures consider it a compliment to the cook when you belch at the table. This just takes the compliment to a whole new level.
                                          Mike Lucey
                                          .....may as well go the full hog and build in an air extractor πŸ’­
                                            Here's v2 with a more stable table base and a seat back...
                                            Sqhair2.skp
                                            • 2 / 4
