    What's this?
    65 Posts 15 Posters 5.5k Views 15 Watching
    • Mike LuceyM
      Mike Lucey
      That works Steve, well done πŸ‘
      I am moving towards doing even a more straightforward design that doesn't involve curved plywood.
      This is great as it turning into a collaboration πŸ‘
        A square table and 4 square chairs ? 🀣
        • Mike LuceyM
          Mike Lucey
          Now there's an idea 😲
            The Sqhair
            Economical on material too.
            Simply table-sawn and router rounded-corners etc as needed etc.
            The table can use a simple foot-operated bottle-jack mechanism to lift it up and on release lower down.
            The storage under the seats is set back a little to avoid heel-clashes.
            The seat-back half 'L' slides up/down on dado friction glides [Γ  la draw-slides] with a catch to it lock 'up' ?
            When the seats are removed from the assembly they are set around the table at 45 degrees on the sides of the square. The seats are on castors.
            Sqhair.skp
            • hellnbakH
              hellnbak
              Nice, but those seat-backs don't look very comfortable
              • Mike LuceyM
                Mike Lucey
                Now we are getting places.
                TIG, would that table have a bit of wobble potential? Also I think Steve might be right about the backs not being too comfy.
                Have you a pic of a 'foot-operated bottle-jack mechanism'? I'm curious about that.
                I'm not so sure about the seats being on casters but they could be lockable. I think slides might work better.
                  ArCAD-UK
                  An octagonal shape applied to TIG's design would sort out the seat backs.
                  • soloS
                    http://cdn.dornob.com/wp-content/uploads/2009/05/combined-wood-table-chairs-design.jpg
                    • hellnbakH
                      hellnbak
                      One possible solution to the seat-back
                      Sorta looks like a toilet with the seat folded down πŸ˜†
                      • hellnbakH
                        hellnbak
                        Maybe a couple of padded armrests for comfort (they could flip up for extra storage)
                        • Mike LuceyM
                          Mike Lucey
                          Nice render Pete. But that a full size table. We are trying to figure out a dual coffee / dining table.
                          Steve, yep! It does look like a commode ..... maybe an idea?
                          • hellnbakH
                            hellnbak
                            When the meal is just too good to interrupt.....
                            • Mike LuceyM
                              Mike Lucey
                              πŸ˜†
                              • Mike LuceyM
                                Mike Lucey
                                ...... now a sound proof private curtain πŸ˜‰
                                • hellnbakH
                                  hellnbak
                                  Some cultures consider it a compliment to the cook when you belch at the table. This just takes the compliment to a whole new level.
                                  • Mike LuceyM
                                    Mike Lucey
                                    .....may as well go the full hog and build in an air extractor πŸ’­
                                      Here's v2 with a more stable table base and a seat back...
                                      Sqhair2.skp
                                        Here's v3 - it has a more logical base made from swastika dado lapped 'base-feet' and a simpler back made form the same thickness foam as the seat...
                                        Sqhair3.skp
                                        • hellnbakH
                                          hellnbak
                                          Good idea to make the seat-back lower with the rest of the back. I enjoy seeing how a project develops.
                                          Some questions -
                                          Why not make the seat-back flush with the top of the L-shaped assembly? It's very low anyhow, this would give more support.
                                          Are you going to round the edges of the wood?
                                          Will there be some sort of handle/cutout to grasp to raise/lower the seat-back?
                                          I'll go away now
                                            Some questions -
                                            I'll go away now
                                            The top of the 'pad' is lower because it must fit under the table top in the lowered-position.
                                            This small upstand gives something to hold when sliding the L-shaped-back upwards.
                                            It could incorporate a routered 'internal' horizontal finger 'groove' for a grip - leaving the outside faces all similar and flush/flat.
                                            The main external corners of the panels are shown rounded by 10mm, the other edges of the panels could be given a 'pencil-round' [3mm?]
                                            We have yet to devise 'sliders/locking-catches' for the L-back, the chairs' castors/slides/glides, and the 'bottle-jack' to lift/lower the table-top from 'coffee' to 'dining' ???
                                            • 2 / 4
