    What's this?
    65 Posts 15 Posters 4.9k Views 15 Watching
      @mike lucey said:
      That works Steve, well done πŸ‘
      I am moving towards doing even a more straightforward design that doesn't involve curved plywood.
      This is great as it turning into a collaboration πŸ‘
      A square table and 4 square chairs ? 🀣
      • Mike LuceyM Offline
        Mike Lucey
        Now there's an idea 😲
          The Sqhair
          Economical on material too.
          Simply table-sawn and router rounded-corners etc as needed etc.
          The table can use a simple foot-operated bottle-jack mechanism to lift it up and on release lower down.
          The storage under the seats is set back a little to avoid heel-clashes.
          The seat-back half 'L' slides up/down on dado friction glides [Γ  la draw-slides] with a catch to it lock 'up' ?
          When the seats are removed from the assembly they are set around the table at 45 degrees on the sides of the square. The seats are on castors.
          Sqhair.skp
          • hellnbakH Offline
            hellnbak
            Nice, but those seat-backs don't look very comfortable
              Mike Lucey
              Now we are getting places.
              TIG, would that table have a bit of wobble potential? Also I think Steve might be right about the backs not being too comfy.
              Have you a pic of a 'foot-operated bottle-jack mechanism'? I'm curious about that.
              I'm not so sure about the seats being on casters but they could be lockable. I think slides might work better.
                ArCAD-UK
                An octagonal shape applied to TIG's design would sort out the seat backs.
                • soloS Offline
                  http://cdn.dornob.com/wp-content/uploads/2009/05/combined-wood-table-chairs-design.jpg
                  • hellnbakH Offline
                    hellnbak
                    One possible solution to the seat-back
                    Sorta looks like a toilet with the seat folded down πŸ˜†
                    • hellnbakH Offline
                      hellnbak
                      Maybe a couple of padded armrests for comfort (they could flip up for extra storage)
                        Mike Lucey
                        Nice render Pete. But that a full size table. We are trying to figure out a dual coffee / dining table.
                        Steve, yep! It does look like a commode ..... maybe an idea?
                        • hellnbakH Offline
                          hellnbak
                          When the meal is just too good to interrupt.....
                            Mike Lucey
                            πŸ˜†
                              Mike Lucey
                              ...... now a sound proof private curtain πŸ˜‰
                              • hellnbakH Offline
                                hellnbak
                                Some cultures consider it a compliment to the cook when you belch at the table. This just takes the compliment to a whole new level.
                                  Mike Lucey
                                  .....may as well go the full hog and build in an air extractor πŸ’­
                                    Here's v2 with a more stable table base and a seat back...
                                    Sqhair2.skp
                                      Here's v3 - it has a more logical base made from swastika dado lapped 'base-feet' and a simpler back made form the same thickness foam as the seat...
                                      Sqhair3.skp
                                      • hellnbakH Offline
                                        hellnbak
                                        Good idea to make the seat-back lower with the rest of the back. I enjoy seeing how a project develops.
                                        Some questions -
                                        Why not make the seat-back flush with the top of the L-shaped assembly? It's very low anyhow, this would give more support.
                                        Are you going to round the edges of the wood?
                                        Will there be some sort of handle/cutout to grasp to raise/lower the seat-back?
                                        I'll go away now
                                          Some questions -
                                          I'll go away now
                                          The top of the 'pad' is lower because it must fit under the table top in the lowered-position.
                                          This small upstand gives something to hold when sliding the L-shaped-back upwards.
                                          It could incorporate a routered 'internal' horizontal finger 'groove' for a grip - leaving the outside faces all similar and flush/flat.
                                          The main external corners of the panels are shown rounded by 10mm, the other edges of the panels could be given a 'pencil-round' [3mm?]
                                          We have yet to devise 'sliders/locking-catches' for the L-back, the chairs' castors/slides/glides, and the 'bottle-jack' to lift/lower the table-top from 'coffee' to 'dining' ???
                                            Some questions -
                                            I'll go away now
                                            This small upstand gives something to hold when sliding the L-shaped back up.
                                            • 2 / 4
