    What's this?
    65 Posts 15 Posters 4.9k Views 15 Watching
    • soloS Offline
      http://cdn.dornob.com/wp-content/uploads/2009/05/combined-wood-table-chairs-design.jpg
      • hellnbakH Offline
        hellnbak
        One possible solution to the seat-back
        Sorta looks like a toilet with the seat folded down πŸ˜†
        • hellnbakH Offline
          hellnbak
          Maybe a couple of padded armrests for comfort (they could flip up for extra storage)
          • Mike LuceyM Offline
            Mike Lucey
            Nice render Pete. But that a full size table. We are trying to figure out a dual coffee / dining table.
            Steve, yep! It does look like a commode ..... maybe an idea?
            • hellnbakH Offline
              hellnbak
              When the meal is just too good to interrupt.....
                Mike Lucey
                πŸ˜†
                  Mike Lucey
                  ...... now a sound proof private curtain πŸ˜‰
                  • hellnbakH Offline
                    hellnbak
                    Some cultures consider it a compliment to the cook when you belch at the table. This just takes the compliment to a whole new level.
                      Mike Lucey
                      .....may as well go the full hog and build in an air extractor πŸ’­
                        Here's v2 with a more stable table base and a seat back...
                        Sqhair2.skp
                          Here's v3 - it has a more logical base made from swastika dado lapped 'base-feet' and a simpler back made form the same thickness foam as the seat...
                          Sqhair3.skp
                          • hellnbakH Offline
                            hellnbak
                            Good idea to make the seat-back lower with the rest of the back. I enjoy seeing how a project develops.
                            Some questions -
                            Why not make the seat-back flush with the top of the L-shaped assembly? It's very low anyhow, this would give more support.
                            Are you going to round the edges of the wood?
                            Will there be some sort of handle/cutout to grasp to raise/lower the seat-back?
                            I'll go away now
                              Some questions -
                              I'll go away now
                              The top of the 'pad' is lower because it must fit under the table top in the lowered-position.
                              This small upstand gives something to hold when sliding the L-shaped-back upwards.
                              It could incorporate a routered 'internal' horizontal finger 'groove' for a grip - leaving the outside faces all similar and flush/flat.
                              The main external corners of the panels are shown rounded by 10mm, the other edges of the panels could be given a 'pencil-round' [3mm?]
                              We have yet to devise 'sliders/locking-catches' for the L-back, the chairs' castors/slides/glides, and the 'bottle-jack' to lift/lower the table-top from 'coffee' to 'dining' ???
                                Some questions -
                                I'll go away now
                                This small upstand gives something to hold when sliding the L-shaped back up.
                                  jsmith
                                  Beautiful thinking outside the box!
                                  • hellnbakH Offline
                                    hellnbak
                                    So.....not what you were looking for? 😞
                                      Mike Lucey
                                      Not quite Steve πŸ˜‰
                                      Anyway, did a bit more on it. I went with an octagonal top and used dowels to get around the Coffee and Dining heights. It would be a mater of lifting the table out from the coffee table position, turning it 45 degrees and popping it back into the slots for the dinging position. I imagine is these dowels were hardwood they would be reasonably ridged.
                                      I also figured out a simple way to hold the seat back in the upright position by having a drop down hinged prop.
                                      Non of this is high tech but again I wanted something that could be knocked out in a small workshop.
                                      ![Coffee-Dining-Storage (COFFEE POSITION] v3.jpg](/uploads/imported_attachments/4kt9_Coffee-Dining-StorageCOFFEEPOSITIONv3.jpg)
                                      Coffee-Dining-Storage v3.skp
                                      • hellnbakH Offline
                                        hellnbak
                                        Nice idea, but (me being me) I do have one or two observations --
                                        Don't know how much the top might weigh, but seems it might be difficult aligning the dowels into the holes once the top was lifted. You would be unable to actually see the holes because you would be looking down at the table top. Unless you went with your original idea and used a glass tabletop, but then you've got the weight problem again. Also it seems like the dowels would have to be pretty long to provide stability once it's in the raised position, requiring it to be lifted even higher, and they would have to fit very snugly in the holes or the top would wobble. I would also be a bit concerned that this appears to be a two-person operation. Would be much preferable (to me) and more appealing to those that might be interested in your design, to have just one person be able do the transformation from coffee table to dining table, and back again.
                                        Just my thoughts, playing Devil's advocate here
                                        am I becoming a pain yet?
                                        • hellnbakH Offline
                                          hellnbak
                                          Just downloaded your model, and after raising the top noticed that you had tapered the ends of the dowels. This would indeed make the insertion easier. Also noticed after raising it that it might not be as difficult as I first thought to see what you were doing during the operation.
                                          My bad 😳
                                          Really liked the way you designed the hinged props to fold down sideways and the seat back fits neatly around them.
                                          One final question - does the average home workshop have the capability to drill holes that diameter, that deep?
                                          I'm going to bed now
                                            Here's a way to make a back-slider.
                                            A groove in the moving part and a HW strip runner on the fixed part with the bottom part half 'bent' inwards as a 'spring-catch'. It then catches when the back is up max, to lower press them in and the back slides down...
                                            Sprung hw strip catch.skp
                                            • 2 / 4
