    Depth of field with physical camera
    renderpluginsextensions
    15 Posts 8 Posters 6.3k Views 8 Watching
      No, if it is a V-ray question, this would be the right place. Hopefully someone more knowledgeable than me will see the post and can answer.
      • andybotA Offline
        andybot
        hi giulia,
        DOF can be tricky. In exterior scenes where you are far away, DOF is deep by its nature. It will only show up if there are objects very close to you (for example 1 meter or less) Also, you can turn down the GI and background multiplier so you can have a small f-number. You can override the focal length to use a larger length (achieve shallower DOF)
        • ATLAStudioA Offline
          ATLAStudio
          Trying to get the hang of these settings just now and found your post, you can unlock the DoF aperture parameter by switching off the physical camera at the 'On' button. After you change the aperture switch the camera back on, the setting is preserved. There's probably a good reason for this but I certainly don't know what it is. Test is hdr GI with exposure turned off, DoF aperture 0.5, focal distance 40.0.
          http://www.atlas-studio.co.uk
          • fuzzionF Offline
            fuzzion
            Beautiful answer. I have actually given up on DOF with outdoor scenes 😒
            "Only the dead have seen the end of war" - Plato
            • panixiaP Offline
              panixia
              i strongly suggest to render the z-depht channel and then put it in the alpha channel spot in photoshop so you can use it as an alpha channel for lens blur.
              simple and effective.
              moreover it seriously decrease the render time, and most important to me is that this workaround allows you to do a single render and quickly create countless variation in PS without having to render it countless time.
              in photoshop also you have a real-time preview of what are you doing in terms of strenght and radius of blurriness.
              • V Offline
                valerostudio
                +1 on ZDepth channel. Much more flexible and faster render times.
                • andybotA Offline
                  andybot
                  except for the slight problem of reflections...
                  • panixiaP Offline
                    panixia
                    mmm.. why? πŸ˜•
                    • andybotA Offline
                      andybot
                      Take a look at the countertop in this example. The doors and trees beyond are not blurred when using the mask because the reflection is not calculated in the zdepth pass.
                      • V Offline
                        valerostudio
                        Oh, that's a good one. This is very interesting.
                        • panixiaP Offline
                          panixia
                          ah ok.. never noticed it before.. 😳
                          very intersting..
                            monkers
                            Has anyone managed to work this out for large scenes?
                            I have a job in large scene and I would like to blur out the background in Vray.
                            I have tried the Z-depth work around but it blurs out details in the foreground - I know with a bit of photoshopping this could be fixed. But I would rather just batch render over night.
                            Heres some images of my scenes
                            Without DOF
                            http://imgur.com/n4tByGb
                            With DOF from zdepth see how the crane detail blurs out.
                            http://imgur.com/Abimfzg
                              monkers
                              I managed to figure this out if anyone is interested here's the settings i used
                              http://i.imgur.com/MWydbaf.png
                              the result.
                              http://i.imgur.com/PKgtDaU.jpg
