    Getting Started
    75 Posts 45 Posters 194.8k Views 45 Watching
    • emerald15E
      emerald15
      As ever, I learn so much here. However, I still have difficulty, when I've found a useful thread - to find it a second time. I'm making a note of titles etc. & have tried typing the viewtopic codes in... but still haven't found an obvious route. Is there something I'm missing & is there a way to save a record of thread titles?
      • BoxB
        At the bottom of the page you will find, Subscribe topic and Bookmark topic.
        • emerald15E
          emerald15
          Ah Haaa! Thankyou!
          • GaieusG
            You can always bookmark a topic.
            Then here you can manage your bookmerks:
            http://forums.sketchucation.com/ucp.php?i=main&mode=bookmarks
            • T
              tireboy
              thanks this really helps
              • F
                FoamHeadMike
                This helps a lot Thanks
                C Ya Round Like A Doughnut
                • V
                  victor hugo
                  HELLO CAN ANYONE TELL ME HOW TO REMOVE THE MULTIPLE OR REPEATED "RUBY CONSOLE" FROM THE WINDOW DROP DOWN MENUS?
                  GRACIAS.
                    GRACIAS.
                    It's related to plugins you have installed. Can you post a screenshot of your plugins folder?
                    (Also, please do not use all CAPS. It's usually read as if you are shouting and generally considered bad manners on most forums. Of you do not care for proper capitalisation of word then use lower caps instead of upper caps.)
                    • V
                      victor hugo
                      Sorry for the CAPS, I was doing also Autocad and forgot to change it, but attached is the list.
                      Gracias.
                        You should NOT have 'sketchup.rb' in Plugins, the current one is installed with Sketchup and it's in Tools.
                        Remove it from Plugins.
                        There are one or two other files I don't recognize, but nothing that should cause an issue...
                        • V
                          victor hugo
                          Thanks TIG ruby console duplicates are kaput now!!
                          I'm new with sketchup, is there a plug in to intall plug-ins?
                            Unfortunately there are still a few rogue scripts around that install out of date things in the wrong places... BUT very few...
                            To simplify installation I suggest that you install Thomthom's 'Simple Installer' available in the 'Plugins Index' link...
                              Jim
                              Another victim of the Quarr-IT plugin compilations...
                              • V
                                victor hugo
                                Could not find the Twilight post but I've installed the 1.5 version and when I try to render an image it crashes everytime.
                                Has anyone had this problem?
                                Thanks.
                                • V
                                  victor hugo
                                  This maybe simple but I don't know why when I draw a rectangle it shows the face reversed, is there a setting to draw all new to front faces?
                                  Thanks.
                                    When you draw a rectangle flat on the ground it always faces down [reversed] because Sketchup assumes you'll want to PushPull it into a solid box - if it did face the other way you might end up with a box, but with no bottom face.
                                    When you draw rectangles in any other plane the direction [clockwise/ccws] determines which way a face is oriented. However, flat faces on the ground always face down irrespective of their 'loop' direction.
                                    BUT all is not lost - it's dead easy to reverse a face - use the Select tool and click the face so that it's highlighted - now right-click context-menu 'Reverse' to flip the face to be the other way round.
                                    The Orient tool is similar, but then you select a face that's the right way round and all other faces connected to it will flip to match that face's orientation, if they can - it's not always possible if any edge has more than two faces it'll fail somewhere, as there'll always be one face 'out of step' with it's neighbors...
                                    • SimFonIA_teamS
                                      SimFonIA_team
                                      Hello All,
                                      I am not sure it is the right place to ask this question, sorry if I am wrong.
                                      So, I would like to know if a personal-message is really sent when it appears in the "outbox" of my profile?
                                      Give life to your ideas : http://www.simfonia.fr/SAT/
                                      • GaieusG
                                        If it's in the outbox, it is sent but not read yet. If it's under "Sent messages", it has already been delivered and read by the recipient.
                                        • SimFonIA_teamS
                                          SimFonIA_team
                                          Perfect, thank you for your answer Gaieus.
                                            Jehphg
                                            Hi guys, my name is Jéssica, i'm a newbie and i am loving the forum already!
                                            • 3 / 4
