    Getting Started
    75 Posts 45 Posters 194.8k Views 45 Watching
    • V
      victor hugo
      Thanks TIG ruby console duplicates are kaput now!!
      I'm new with sketchup, is there a plug in to intall plug-ins?
        Unfortunately there are still a few rogue scripts around that install out of date things in the wrong places... BUT very few...
        To simplify installation I suggest that you install Thomthom's 'Simple Installer' available in the 'Plugins Index' link...
          Jim
          Another victim of the Quarr-IT plugin compilations...
          • V
            victor hugo
            Could not find the Twilight post but I've installed the 1.5 version and when I try to render an image it crashes everytime.
            Has anyone had this problem?
            Thanks.
            • V
              victor hugo
              This maybe simple but I don't know why when I draw a rectangle it shows the face reversed, is there a setting to draw all new to front faces?
              Thanks.
                When you draw a rectangle flat on the ground it always faces down [reversed] because Sketchup assumes you'll want to PushPull it into a solid box - if it did face the other way you might end up with a box, but with no bottom face.
                When you draw rectangles in any other plane the direction [clockwise/ccws] determines which way a face is oriented. However, flat faces on the ground always face down irrespective of their 'loop' direction.
                BUT all is not lost - it's dead easy to reverse a face - use the Select tool and click the face so that it's highlighted - now right-click context-menu 'Reverse' to flip the face to be the other way round.
                The Orient tool is similar, but then you select a face that's the right way round and all other faces connected to it will flip to match that face's orientation, if they can - it's not always possible if any edge has more than two faces it'll fail somewhere, as there'll always be one face 'out of step' with it's neighbors...
                • SimFonIA_teamS
                  SimFonIA_team
                  Hello All,
                  I am not sure it is the right place to ask this question, sorry if I am wrong.
                  So, I would like to know if a personal-message is really sent when it appears in the "outbox" of my profile?
                  Give life to your ideas : http://www.simfonia.fr/SAT/
                  • GaieusG
                    If it's in the outbox, it is sent but not read yet. If it's under "Sent messages", it has already been delivered and read by the recipient.
                    • SimFonIA_teamS
                      SimFonIA_team
                      Perfect, thank you for your answer Gaieus.
                        Jehphg
                        Hi guys, my name is Jéssica, i'm a newbie and i am loving the forum already!
                        • G
                          Gundulph1
                          Hello everybody - I'm a newbie to the site and (currently) the most casual of casual users. Am intending to change that over the next few years before leaving my current employer to go it alone (small scale infrastructure engineering). I have a feeling I'm going to be asking the assorted wise heads here a lot of questions in the meantime... thanks in advance!
                            mehimu
                            • V
                              vanesscast
                              thank you so much for all the helpful tips! it really helps a beginner like me out!
                              • picsP
                                pics
                                A newbie question: I never used SU before (2017 make) and I read online somewhere that it's better to start in 2d and get to know the tools. Do you agree that this is a good way to start learning SketchUp? Any suggestions are appreciated. Thanks
                                Dave
                                  Dave
                                  I wouldn't agree at all. SketchUp is a 3D modeling tool. You should learn it in 3D.
                                    jmdiazfranco
                                    Hi, I have an question but it seems that I can't write in the forums (yet?). So apologies if I am dumping the question in the wrong place...
                                    How can I reduce line width when exporting 2D drawings (.dwg format) from Sketchup to be used in CNC software (specifically in Enroute)?
                                    I realized that without controlling the line width, small perforations or arches are heavily segmented which gives problems when loading the files.
                                    Hopefully someone can help.
                                    Warm regards!
                                    Jose
                                      Line weight has nothing to do with the segmentation of arcs, circles, and curves. They will always be segmented in SketchUp. If you export the 2D file using the 3D .dwg exporter instead, the acrs, circles, and curves will be smoothed as you want them to be.
                                      FWIW, SketchUp doesn't have real line weight control. You can set a thickness for Profile edges but that's not the same. You could change the line weight in LayOut, however.
                                      • K
                                        keithver
                                        I have just bought 2021 and am trying to load the Sketchucation plugin. I have downloaded it from the site, but when i click on it in my Downloads, it open SKup and gives a message "this does not appear to be a Sketchup model"
                                        Where am i going wrong. I remember it being very easy in Ver.18
                                        • BoxB
                                          From within Sketchup, Go Extensions/Extension Manager/Install Extension navigate to the RBZ file in your Downloads folder and click open.
                                          This will install the extension automatically.
                                          • K
                                            keithver
                                            Fantastic. Thanks very much. I've got it loaded now, along with the rest 😎 😄
                                            • 4 / 4
