    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • fredo6F Offline
      @jgb
      Curviloft works with 4 contours (what is called a coon).
      When you have a single continuous contour, you need to define these 4 contours. As highlighted by Rich, one simple way to tell Curviloft is to put Break points, with small open segments. Then, you can Select All and proceed with Skinning.
      PS1: another way is to use the Edge by Edge selection, and press Return between each of the 4 contours.
      PS2: colors have no special meaning except to differentiate the selected contours
      PS3: error handling is not complete yet. This is why the plugin is still in Beta
        Aaah OK ! πŸ˜‰
        All is clear now! πŸ’š πŸ‘
        • I Offline
          ivreich
          How to soft/hide diagonals only??
          How does one generate a lofted surface with only the diagonals soft/hidden? This is useful if you want to use the loop/ring selection tools that come natively with thomthom's Quadfacetools...
          Currently you have to do it manually, generating two sets of intermediate profiles (in both U and V directions) and merging it with the quadface surface.
          joel
          Soft/Hidden diagonals only. Useful when selecting loops+rings using QuadFaceTools.
            Have you the Skp (V6) ?
              CurviLoft can generate Quad meshes for you if you just enable the option:
              It generates smooth meshes though, so if you want the grid type you have in your screenshot you need to use QuadFace Tools to unsmooth the CurviLoft surface.
              • jgbJ Offline
                jgb
                @rich o brien said:
                @Joel
                Try watching this...
                302 Found
                (www.screenr.com)
                Ah IZ simply blown away by this..
                I tried segmenting at the same corners, but it didn't work for me, and now I know why. But this and TT's explanation to Ivreich and Fredos "How-to" reply opened my eyes to why I found CL a bit unresponsive to many of my skinning attempts.
                Simply a lack of a basic tutorial for Curviloft left me without the tools needed to use CL effectively.
                Fredo, that really needs to be addressed. ❗ CL is NOT a simple intuitive tool to use.
                jgb
                • jgbJ Offline
                  jgb
                  Fredo; That explanation really opened my eyes. I NEVER knew the toolbar functions were only active in "blackface". I thought they were presets, and that is why it never worked for me.
                  One question though, when you added the 4 breakpoints (as also shown by Rich) it skinned when you selected all. This object is an extract from a drawing that had lines emanating straight up/down from each point, effectively each being a breakpoint. Many times in the past, if I had an extraneous line or fragmet in the perimeter selection, CL would go RED and not skin till the line was removed. Yet here you show they are included. When I tried this with the original model (a sink base) selecting 4 lines as breakpoints, again nothing happened.
                  Here is a series of screenshots of what happened.
                  Overall view of the sink, with the problem area in the base highlighted.
                  Overall view of model.
                  And a closeup....
                  Closeup (cropped) of the problem area.  The skin was manually created.
                  Skin area removed to redo solution.
                  Skin removed.
                  Perimeter only selected. No skinning. πŸ‘Ž
                  Perimeter only selected.  CL would not skin.
                  Added 4 breakpoint lines to perimeter selection. Again, no skinning. πŸ‘Ž
                  Added 4 breakpoint line to perimeter selection.  CL would not skin.
                  Selected 3 lines using CL Select, and
                  Curviloft selection of 3 line sets.
                  VOILA, a skin. πŸ‘ πŸ‘ πŸ‘
                  THAT worked!!!
                  So now I know a whole lot more about Curviloft, but my question now is why did my selection of breakpoint lines NOT work, but worked for you, and not cause an error with CL ❓ ❓
                  jgb
                  • fredo6F Offline
                    @jgb
                    It depends on your settings in the button palette
                    • the mode of selection (Follow <-->)
                    • the Break at Crossing button must be ON
                      The small segments must also be 'plain' edges.
                    Anyway, selecting each of the 3 or 4 contours is a good method too.
                      I have always thhought that this piece was a part of a secret space rocket due the warning text inserted πŸ˜„
                      πŸ˜†
                        I have always thought that this piece was a part of a secret space rocket due the warning text inserted πŸ˜„
                        • jgbJ Offline
                          jgb
                          The sink goes in the rocket cabin. 🀣
                          And I thought I was being clever at hiding its purpose by just extracting the problem part. β˜€
                          jgb
                            redmaya
                            i cant install... i followed the instruction.. i opened then extracted to plugin...
                              You have to give more than that for us to help you. πŸ˜’
                              Go back and reread the instructions. Do you have administrative permission to install files into Plugins? Did you get LibFredo 4.6 and install it? Did you maintain the footprint of the files when installing it? What happens exactly when you try to install it? What happens exactly when you open SketchUp after installing it?
                                redmaya
                                cant install libfredo... when i extract.. it says denied access.....
                                first i open it in winrar... then copy and paste libfredo6..rb and libfredo_dir_46 into googlesketchup plugin... then extract in winrar in the same location,,,, access denied
                                  You need to set up administrative rights to add files to the Plugins folder. This is one of the joys of Windows 7.
                                    Beto Ask
                                    I already downloaded the plugin and copied all the files to the SketchUp plugins directory but when I open SketchUp it says that there is an error loading several files from curviloft, so the plugin isn't installed. What can I do or what am I doing wrong? please help!
                                      @beto ask said:
                                      What can I do?
                                      Please, make sure to install everything correctly according to the instructions in the first post. If it still fails, make a screenshot of the ruby console when it displays those errors (or actually you can copy that text and paste it here).
                                        Read through this guide to how to install plugins: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                                        You might want to use the installer utility it links to.
                                          transamws6
                                          I'm getting errors trying to get this to run...
                                          I believe I have the Fredo package installed correctly, but the Curviloft plugin seems to not be working.
                                          I've read all of the install directions and i have un-zipped everything into the directories as instructed.
                                          What am I missing?
                                          Error Loading File bootstrap_Curviloft.rb
                                          uninitialized constant Curviloft::T6Error Loading File CurviloftAlgo.rb
                                          uninitialized constant Curviloft::T6Error Loading File CurviloftCurveMover.rb
                                          uninitialized constant Curviloft::T6Error Loading File CurviloftPalette.rb
                                          uninitialized constant Curviloft::T6Error Loading File CurviloftTool.rb
                                          uninitialized constant Curviloft::T6Error Loading File Lib6Config.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6EdgePicker.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Input.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Operation.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Palette.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Plugin.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6PluginDialogs.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Protractor.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Selmode.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Startup.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Tool.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Translate.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Upgrade.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6WebHtml.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6WebXTable.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6_txtmsg.rb
                                          uninitialized constant Traductor::T6Error Loading File __loader.rb
                                          undefined method `effective_load' for nil:NilClass
                                          • massimoM Offline
                                            massimo Moderator
                                            Do you also installed the LibFredo6? It's clearly written in the very first post.
                                            • 65
                                            • 66
                                            • 6 / 66
