    How to make it pls
    28 Posts 6 Posters 1.5k Views 6 Watching
      Very more easy with the Fredo plug 😉(tool of the plug above : tapering with orientation box)
      You can make hundred levels and taper them in 2 clicks 😉
      Here only 16 levels 😉
      Green tubes are the special box , of course it disapears at the end of the process
      • E Offline
        erzane
        I tried to install it but it but installation failed...
        I dled the zip file
        selected all inside the file and pasted it to the ''plugin'' folder, and replaced all
        but it dont work, ''installation is failed''
        I read on th emanual that fredo scal work with ver.5-7 , but not 8??
        th emessage is this
        Erreur de chargement du fichier bootstrap_FredoScale.rb
        (eval):1: uninitialized constant FredoScale::T6Erreur de chargement du fichier ZLoader__FredoScale.rb
        no such file to load -- LibFredo6.rbErreur de chargement du fichier __loader.rb
        uninitialized constant Traductor
        I am a little bit tired now I will study it better tomorrw if it's ok for you
        anyway thanks for all
        I will comeback tomorrow
        good night
          You must read carrefully the indications of install 😉
          There is the folder of programm itself but there also a library to load!
          All are in the same first post of the thread!
          And see also the image of the same post, there is the arborescence that you must have!
          And carreful also: following the Zip program, unzip can produce a level more of folder!
          So in this case copy only that is inside the folder 😉
            Maybe I'm missing something but what's wrong with Follow Me? Seems to me like that would be the simplest approach.
            http://farm8.staticflickr.com/7133/7564914992_e089a46da6.jpg
              Yes, but he wants a pyramide from an existing object! 😄
                Where did you read that, Pilou? I don't see that anywhere in his original post.
                What I drew tapers as it goes up.
                • E Offline
                  erzane
                  Dave R your draw is correct, do you have another technic ?
                  http://img228.imageshack.us/img228/4174/ioioz.jpg
                  Philou are you french ?
                  p.s. si oui c plus simple de parler français car l'anglais ça va mais ça peine un peu dans ce genre d'explications
                  anyway I will try again to install fredo again
                    Excellent!
                    The thing your blue arrow is pointing at is the profile and the circle is the path for Follow Me.
                    http://farm9.staticflickr.com/8146/7566939162_3a11ff9a69.jpg
                    I started out with a rectangle on which to draw the profile.
                    I deleted the unneeded parts of the rectangle, selected the edge of the circle, got Follow Me and clicked on the profile.
                    It's sort of the reverse of making a section cut from the shape. Draw the section cut and make a shape.
                    • E Offline
                      erzane
                      WOW! is it so easy !!??
                      it makes it automaticly ?
                      pls wait a moment , I will try it
                        It is that easy, indeed!
                        And all done with the native tools. No plugins to install. 😉
                        • Mike LuceyM Offline
                          Mike Lucey
                          Well done Dave ..... 'up there for thinking and down there for dancing!' 👍
                          • E Offline
                            erzane
                            so, I made the basis but I didn't succeed to use the follow me tool
                            the truth is that I didn't understood your explanations well lol
                            http://img513.imageshack.us/img513/9172/capture01fa.jpg
                              The profile needs to be aligned on the radius of the circular path.
                              Start with the circular path centered on the origin and the rectangular face on a radius of the circle. I delete the face of the circle before running Follow Me because if you don't, there'll be no face created on the bottom of the extrusion.
                              Thanks, Mike.
                              • E Offline
                                erzane
                                I succeeded it
                                but I didn't needed to erase the basis circle
                                I just choosed the follow me tool and pushed ''Alt''
                                http://img708.imageshack.us/img708/1589/capture01oy.jpg
                                thanks for your help 😉
                                  Glad you got it to work.
                                  Now correct the face orientation so the back faces (blue) are inside and delete the circle for the path and you're finished.
                                  • E Offline
                                    erzane
                                    done
                                    now I would like to place it on the center of the circle but I dont know how to center it..
                                    http://img824.imageshack.us/img824/2113/capture01qi.jpg
                                      Probably the easiest way would be to add some temporary cross hairs at the bottom center of the thing. Then grab the thing at the center with the Move tool and move it to the center of that other circle. It would be best if you make that shape a component and change its axes so they are centered at its bottom center. then bring the component in from the Component browser. See this for reference.
                                      • E Offline
                                        erzane
                                        ok I see, this is the famous glue I learned last year
                                        I forget all about what I learned last year, it's terrific lol
                                        anyway during your reply I do it like this
                                        I erased the circle and created a new one from the basis with the offset tool
                                        http://img805.imageshack.us/img805/773/capture01r.jpg
                                          Good. Now correct the face orientation. Don't be sloppy in your modeling. 😉
                                            You right for the text 😉
                                            I had interpreted the images! And was right! 😉
                                            And sure your method is more speedy than the FredoScale when you start from the beginning! 😉
                                            But when you have yet the object, that is an another story! 😄
