    How to make it pls
    28 Posts 6 Posters 1.5k Views 6 Watching
      So Fredoscale 😉
      • E Offline
        erzane
        no I would like to resize the top but from the botoom to
        not only the last cake of the top
        I would like to make it like a pyramide, from botom to top of all the cake
        I used Ctrl but I cannot succeed to make it well
        I really dont understand why it doesnt do it
          Very more easy with the Fredo plug 😉(tool of the plug above : tapering with orientation box)
          You can make hundred levels and taper them in 2 clicks 😉
          Here only 16 levels 😉
          Green tubes are the special box , of course it disapears at the end of the process
          • E Offline
            erzane
            I tried to install it but it but installation failed...
            I dled the zip file
            selected all inside the file and pasted it to the ''plugin'' folder, and replaced all
            but it dont work, ''installation is failed''
            I read on th emanual that fredo scal work with ver.5-7 , but not 8??
            th emessage is this
            Erreur de chargement du fichier bootstrap_FredoScale.rb
            (eval):1: uninitialized constant FredoScale::T6Erreur de chargement du fichier ZLoader__FredoScale.rb
            no such file to load -- LibFredo6.rbErreur de chargement du fichier __loader.rb
            uninitialized constant Traductor
            I am a little bit tired now I will study it better tomorrw if it's ok for you
            anyway thanks for all
            I will comeback tomorrow
            good night
              You must read carrefully the indications of install 😉
              There is the folder of programm itself but there also a library to load!
              All are in the same first post of the thread!
              And see also the image of the same post, there is the arborescence that you must have!
              And carreful also: following the Zip program, unzip can produce a level more of folder!
              So in this case copy only that is inside the folder 😉
                Maybe I'm missing something but what's wrong with Follow Me? Seems to me like that would be the simplest approach.
                http://farm8.staticflickr.com/7133/7564914992_e089a46da6.jpg
                  Yes, but he wants a pyramide from an existing object! 😄
                    Where did you read that, Pilou? I don't see that anywhere in his original post.
                    What I drew tapers as it goes up.
                    • E Offline
                      erzane
                      Dave R your draw is correct, do you have another technic ?
                      http://img228.imageshack.us/img228/4174/ioioz.jpg
                      Philou are you french ?
                      p.s. si oui c plus simple de parler français car l'anglais ça va mais ça peine un peu dans ce genre d'explications
                      anyway I will try again to install fredo again
                        Excellent!
                        The thing your blue arrow is pointing at is the profile and the circle is the path for Follow Me.
                        http://farm9.staticflickr.com/8146/7566939162_3a11ff9a69.jpg
                        I started out with a rectangle on which to draw the profile.
                        I deleted the unneeded parts of the rectangle, selected the edge of the circle, got Follow Me and clicked on the profile.
                        It's sort of the reverse of making a section cut from the shape. Draw the section cut and make a shape.
                        • E Offline
                          erzane
                          WOW! is it so easy !!??
                          it makes it automaticly ?
                          pls wait a moment , I will try it
                            It is that easy, indeed!
                            And all done with the native tools. No plugins to install. 😉
                            • Mike LuceyM Offline
                              Mike Lucey
                              Well done Dave ..... 'up there for thinking and down there for dancing!' 👍
                              • E Offline
                                erzane
                                so, I made the basis but I didn't succeed to use the follow me tool
                                the truth is that I didn't understood your explanations well lol
                                http://img513.imageshack.us/img513/9172/capture01fa.jpg
                                  The profile needs to be aligned on the radius of the circular path.
                                  Start with the circular path centered on the origin and the rectangular face on a radius of the circle. I delete the face of the circle before running Follow Me because if you don't, there'll be no face created on the bottom of the extrusion.
                                  Thanks, Mike.
                                  • E Offline
                                    erzane
                                    I succeeded it
                                    but I didn't needed to erase the basis circle
                                    I just choosed the follow me tool and pushed ''Alt''
                                    http://img708.imageshack.us/img708/1589/capture01oy.jpg
                                    thanks for your help 😉
                                      Glad you got it to work.
                                      Now correct the face orientation so the back faces (blue) are inside and delete the circle for the path and you're finished.
                                      • E Offline
                                        erzane
                                        done
                                        now I would like to place it on the center of the circle but I dont know how to center it..
                                        http://img824.imageshack.us/img824/2113/capture01qi.jpg
                                          Probably the easiest way would be to add some temporary cross hairs at the bottom center of the thing. Then grab the thing at the center with the Move tool and move it to the center of that other circle. It would be best if you make that shape a component and change its axes so they are centered at its bottom center. then bring the component in from the Component browser. See this for reference.
                                          • E Offline
                                            erzane
                                            ok I see, this is the famous glue I learned last year
                                            I forget all about what I learned last year, it's terrific lol
                                            anyway during your reply I do it like this
                                            I erased the circle and created a new one from the basis with the offset tool
                                            http://img805.imageshack.us/img805/773/capture01r.jpg
