    How to make it pls
    28 Posts 6 Posters 1.6k Views 6 Watching
    • E
      erzane
      hi,
      pls I need help for make this
      http://img3.imageshack.us/img3/5883/exemplepc.jpg
      thanks a lot !!
      • boofredlayB
        boofredlay
        Circle, Push/Pull, Offset, Push/Pull.
        Repeat as necessary.
        • E
          erzane
          Great!!! how could I did not think about it
          it's been a very log time I didnt use sketchup
          thanks
          p.s. problem now is that
          I cannot resize only the top like my draw because the red point dont want to go in the center
          http://img193.imageshack.us/img193/1495/capture01ma.jpg
            Don't worry of that! Select all !
            It is at the middle of the birthday's cake (?), it's just an perspective effect!
            Try it and if the result is not good
            You can Make CTRl + Z 😉
            If not good result select all right click, Explode till all the cake is explosed
            Reselect all the cake and resize it 😄
              If you want to resize just the top disc then select just that face.
              The Scale will then become 2d with fewer green-handles.
              Use Ctrl to scale about the center point, type in a factor - e.g. 1.75 - or a dimension - e.g. 200mm...
              • E
                erzane
                it don't work lol
                it's not a spacecake haha
                impossible to put it on the middle, I dont know why
                usualy it works fine but I never tryed this type of cake before, perhaps there is something wrong in the building ?
                I would like this
                http://img641.imageshack.us/img641/6594/capture01makljlkj.jpg
                but it make this only ( I dont know how to change )
                http://img715.imageshack.us/img715/6003/capture01macopie.jpg
                  So Fredoscale 😉
                  • E
                    erzane
                    no I would like to resize the top but from the botoom to
                    not only the last cake of the top
                    I would like to make it like a pyramide, from botom to top of all the cake
                    I used Ctrl but I cannot succeed to make it well
                    I really dont understand why it doesnt do it
                      Very more easy with the Fredo plug 😉(tool of the plug above : tapering with orientation box)
                      You can make hundred levels and taper them in 2 clicks 😉
                      Here only 16 levels 😉
                      Green tubes are the special box , of course it disapears at the end of the process
                      • E
                        erzane
                        I tried to install it but it but installation failed...
                        I dled the zip file
                        selected all inside the file and pasted it to the ''plugin'' folder, and replaced all
                        but it dont work, ''installation is failed''
                        I read on th emanual that fredo scal work with ver.5-7 , but not 8??
                        th emessage is this
                        Erreur de chargement du fichier bootstrap_FredoScale.rb
                        (eval):1: uninitialized constant FredoScale::T6Erreur de chargement du fichier ZLoader__FredoScale.rb
                        no such file to load -- LibFredo6.rbErreur de chargement du fichier __loader.rb
                        uninitialized constant Traductor
                        I am a little bit tired now I will study it better tomorrw if it's ok for you
                        anyway thanks for all
                        I will comeback tomorrow
                        good night
                          You must read carrefully the indications of install 😉
                          There is the folder of programm itself but there also a library to load!
                          All are in the same first post of the thread!
                          And see also the image of the same post, there is the arborescence that you must have!
                          And carreful also: following the Zip program, unzip can produce a level more of folder!
                          So in this case copy only that is inside the folder 😉
                            Maybe I'm missing something but what's wrong with Follow Me? Seems to me like that would be the simplest approach.
                            http://farm8.staticflickr.com/7133/7564914992_e089a46da6.jpg
                              Yes, but he wants a pyramide from an existing object! 😄
                                Where did you read that, Pilou? I don't see that anywhere in his original post.
                                What I drew tapers as it goes up.
                                • E
                                  erzane
                                  Dave R your draw is correct, do you have another technic ?
                                  http://img228.imageshack.us/img228/4174/ioioz.jpg
                                  Philou are you french ?
                                  p.s. si oui c plus simple de parler français car l'anglais ça va mais ça peine un peu dans ce genre d'explications
                                  anyway I will try again to install fredo again
                                    Excellent!
                                    The thing your blue arrow is pointing at is the profile and the circle is the path for Follow Me.
                                    http://farm9.staticflickr.com/8146/7566939162_3a11ff9a69.jpg
                                    I started out with a rectangle on which to draw the profile.
                                    I deleted the unneeded parts of the rectangle, selected the edge of the circle, got Follow Me and clicked on the profile.
                                    It's sort of the reverse of making a section cut from the shape. Draw the section cut and make a shape.
                                    • E
                                      erzane
                                      WOW! is it so easy !!??
                                      it makes it automaticly ?
                                      pls wait a moment , I will try it
                                        It is that easy, indeed!
                                        And all done with the native tools. No plugins to install. 😉
                                        • Mike LuceyM
                                          Mike Lucey
                                          Well done Dave ..... 'up there for thinking and down there for dancing!' 👍
                                          • E
                                            erzane
                                            so, I made the basis but I didn't succeed to use the follow me tool
                                            the truth is that I didn't understood your explanations well lol
                                            http://img513.imageshack.us/img513/9172/capture01fa.jpg
