    How to make it pls
    28 Posts 6 Posters 1.0k Views 6 Watching
      If you want to resize just the top disc then select just that face.
      The Scale will then become 2d with fewer green-handles.
      Use Ctrl to scale about the center point, type in a factor - e.g. 1.75 - or a dimension - e.g. 200mm...
      • E Offline
        erzane
        it don't work lol
        it's not a spacecake haha
        impossible to put it on the middle, I dont know why
        usualy it works fine but I never tryed this type of cake before, perhaps there is something wrong in the building ?
        I would like this
        http://img641.imageshack.us/img641/6594/capture01makljlkj.jpg
        but it make this only ( I dont know how to change )
        http://img715.imageshack.us/img715/6003/capture01macopie.jpg
          So Fredoscale 😉
          • E Offline
            erzane
            no I would like to resize the top but from the botoom to
            not only the last cake of the top
            I would like to make it like a pyramide, from botom to top of all the cake
            I used Ctrl but I cannot succeed to make it well
            I really dont understand why it doesnt do it
              Very more easy with the Fredo plug 😉(tool of the plug above : tapering with orientation box)
              You can make hundred levels and taper them in 2 clicks 😉
              Here only 16 levels 😉
              Green tubes are the special box , of course it disapears at the end of the process
              • E Offline
                erzane
                I tried to install it but it but installation failed...
                I dled the zip file
                selected all inside the file and pasted it to the ''plugin'' folder, and replaced all
                but it dont work, ''installation is failed''
                I read on th emanual that fredo scal work with ver.5-7 , but not 8??
                th emessage is this
                Erreur de chargement du fichier bootstrap_FredoScale.rb
                (eval):1: uninitialized constant FredoScale::T6Erreur de chargement du fichier ZLoader__FredoScale.rb
                no such file to load -- LibFredo6.rbErreur de chargement du fichier __loader.rb
                uninitialized constant Traductor
                I am a little bit tired now I will study it better tomorrw if it's ok for you
                anyway thanks for all
                I will comeback tomorrow
                good night
                  You must read carrefully the indications of install 😉
                  There is the folder of programm itself but there also a library to load!
                  All are in the same first post of the thread!
                  And see also the image of the same post, there is the arborescence that you must have!
                  And carreful also: following the Zip program, unzip can produce a level more of folder!
                  So in this case copy only that is inside the folder 😉
                    Maybe I'm missing something but what's wrong with Follow Me? Seems to me like that would be the simplest approach.
                    http://farm8.staticflickr.com/7133/7564914992_e089a46da6.jpg
                      Yes, but he wants a pyramide from an existing object! 😄
                        Where did you read that, Pilou? I don't see that anywhere in his original post.
                        What I drew tapers as it goes up.
                        • E Offline
                          erzane
                          Dave R your draw is correct, do you have another technic ?
                          http://img228.imageshack.us/img228/4174/ioioz.jpg
                          Philou are you french ?
                          p.s. si oui c plus simple de parler français car l'anglais ça va mais ça peine un peu dans ce genre d'explications
                          anyway I will try again to install fredo again
                            Excellent!
                            The thing your blue arrow is pointing at is the profile and the circle is the path for Follow Me.
                            http://farm9.staticflickr.com/8146/7566939162_3a11ff9a69.jpg
                            I started out with a rectangle on which to draw the profile.
                            I deleted the unneeded parts of the rectangle, selected the edge of the circle, got Follow Me and clicked on the profile.
                            It's sort of the reverse of making a section cut from the shape. Draw the section cut and make a shape.
                            • E Offline
                              erzane
                              WOW! is it so easy !!??
                              it makes it automaticly ?
                              pls wait a moment , I will try it
                                It is that easy, indeed!
                                And all done with the native tools. No plugins to install. 😉
                                • Mike LuceyM Offline
                                  Mike Lucey
                                  Well done Dave ..... 'up there for thinking and down there for dancing!' 👍
                                  • E Offline
                                    erzane
                                    so, I made the basis but I didn't succeed to use the follow me tool
                                    the truth is that I didn't understood your explanations well lol
                                    http://img513.imageshack.us/img513/9172/capture01fa.jpg
                                      The profile needs to be aligned on the radius of the circular path.
                                      Start with the circular path centered on the origin and the rectangular face on a radius of the circle. I delete the face of the circle before running Follow Me because if you don't, there'll be no face created on the bottom of the extrusion.
                                      Thanks, Mike.
                                      • E Offline
                                        erzane
                                        I succeeded it
                                        but I didn't needed to erase the basis circle
                                        I just choosed the follow me tool and pushed ''Alt''
                                        http://img708.imageshack.us/img708/1589/capture01oy.jpg
                                        thanks for your help 😉
                                          Glad you got it to work.
                                          Now correct the face orientation so the back faces (blue) are inside and delete the circle for the path and you're finished.
                                          • E Offline
                                            erzane
                                            done
                                            now I would like to place it on the center of the circle but I dont know how to center it..
                                            http://img824.imageshack.us/img824/2113/capture01qi.jpg
