    [Plugin] SUClock - v3.1a - 02 Apr 24 - Tracking time in SU
    138 Posts 46 Posters 159.9k Views 46 Watching
    • COSEDIMARCOC Offline
      COSEDIMARCO
      Hi Fredo
      attached there's the Italian Translation for SuClock
      I think i've found a couple english mistakes:
      "Threshold when clock in displayed in warning mode" --> "Threshold when clock is displayed in warning mode
      "ERROR: you can import data from the same current project
      " --> "ERROR: you can't import data from the same current project
      Italian Translation
      [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
      • fredo6F Offline
        NEW RELEASE: SUCLOCK 1.3a - 08 Oct 11
        This release fixes problems encountered with Mac OSX Lion and Safari 5.1 (no images in the clock window)
        Update is published in main post.
        • KrisidiousK Offline
          Krisidious
          how does one go about adding time to a model? I already worked on it and forgot to hit the SUClock?
          is there a way to auto start SUClock with every new model?
          By: Kristoff Rand
            I have a'SUClock' related issue. 😒
            If I deactivate the 'SUClock' Extension and restart Sketchup then when I try to run some of your tools [BezierCurve and RoundCorner] - I get a Ruby Console error like this Error: #<NoMethodError: undefined methodregister_ruby' for SUClock:Module>
            C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:496:in activate' ... I deduce that this is because those two tools' test for the definition? of 'SUClock', which returns 'true', because IT IS defined, and partially loaded, but because it's inactive with the Extension being disabled, then the relevant 'register_ruby' method isn't available - so I get the error.
            If I have SUClock loading at all, then I must always have it active in the Extensions list, otherwise it breaks your other two tools when try to use them.
            Of course stopping SUClock loading all together avoids this, as then it's then never 'defined?'.
            But this is awkward, this Extension should be capable of being simply deactivated, as I do not use it that often: the whole point of an Extension is you load it as it is needed.
            Your two problem tools need their code recasting, for example using something like this that prevents the failure being an issue...
            **(begin;**SUClock.register_ruby('BezierSpline')**;rescue;end)**if defined?(SUClock) needed in two lines.
            **(begin;**SUClock.register_ruby('RoundCorner')**;rescue;end)**if defined?(SUClock) needed once.
            this works fine for me, but it really ought to be 'built-in' 😉
            • fredo6F Offline
              @tig said:
              If I deactivate the 'SUClock' Extension and restart Sketchup then when I try to run some of your tools [BezierCurve and RoundCorner] - I get a Ruby Console error like this [ruby]Error: #<NoMethodError: undefined method `register_ruby' for SUClock:Module>
              TIG,
              This is fixed (actually the method call is nomore to SUClock but to LibFredo6).
              However, I am not sure I published it for BezierSpline and RoundCorner. I'll check
              Thanks for signaling
                I also notice that when exporting to 'Tabbed Text' the '%%' column can be one tab off in certain columns.
                  Krisidious
                  ummm adding time to the clock?
                  By: Kristoff Rand
                  • guanjinG Offline
                    guanjin
                    Fredo Hello, statistics clock can join FredoTools1.1m you? Only an icon, taken together, easy to manage, thank you!
                      tomvokurka
                      Hi.
                      I have a small problem with this plugin. I found it really usefull, but somehow I can't set it up.
                      When I click on a clock icon, select "Attach to a New Project", then type a name of .suclock file and save it in a file with my SU model (with a same name as model) I can't see any .suclock file in explorer. It even doesn't start counting time, no clock appears at all. Can anyone help me? Some advices?
                      I've got SU 8 and Win 7.
                      Thanks a lot!
                      • fredo6F Offline
                        @tomvokurka said:
                        Hi.
                        Thanks a lot!
                        Strange. However on Windows 7 there are by default many security rules preventing to create files by script so it may just be that issue of security (actually the file may be created in a security zone, but not writable).
                        I would suggest that you redo the operation, opening before the Ruby console. Also, do you get a message from SuClock?
                          Fredo, have you found a solution to Vista, Win7 putting files you write out in SU Ruby into the Virtualstore?
                          • fredo6F Offline
                            No. From Ruby you don't see anything, except that the file is created or not created.
                            Actually, I don't understand very well how this virtualstore works and what is the intention.
                              I found I could detect if a file was in VirtualStore or not. But if I wanted to create a file I cannot work out in advance if it will appear in VirtualStore or not.
                              If I edit a file in the Plugins folder everything is fine, but creating new one will stuff it in VS. Very troublesome since I'm trying to make a plugin installer. Might I actually need to write a C Extension? ...might do, might make one that actually writes unicode files as well.
                                kierovnick
                                Oh my God! I mean.. oh my Fredo6!
                                How could i miss this one?
                                I was waiting for it so long and somehow it slipped past my nose until today.
                                There's not many plugins that are MUST HAVE for me, but most of them are of your autorship.
                                My plugin library will look like My plugin library +1 from now on 😄
                                I am sure i will donate, so you could buy some coffe to work on Your next plugins 😄
                                Thank You.
                                  Greetings Fredo,
                                  I just had an e-mail from a Mac user saying that despite downloading the new maintenance release of SketchUp, he's still getting black text boxes with this plugin. Thoughts or ideas?
                                  Thanks.
                                    mwm5053
                                    I'm using OSX 10.7.4 latest Lion release, SU 8 latest release and LIbFredo6 4.6 just so you could see I also just found this very useful Thanks
                                    2011 iMac
                                    SU 2015 Pro, 2017 Make
                                    V2 Twilight
                                    macOS Sierra 10.12.5
                                      rv1974
                                      Is there way to permanently hide 'check plugins for update' window (the small yellow one with ruby)?
                                        mwm5053
                                        You should only see it every 15 days or so, good to have if there have been updates, bug fixes and such.
                                        2011 iMac
                                        V2 Twilight
                                          That's part of LibFredo. Set the frequency to 999 to disable.
                                            If you really don't want to see it every 15 days, go to window>LibFredo6 Settings>Default Parameters and change it.
                                            As Walt says, though, it doesn't hurt to have it pop up. It makes it easy to check for updates.
                                            • 3 / 7
