    [Plugin] SUClock - v3.1a - 02 Apr 24 - Tracking time in SU
    138 Posts 46 Posters 162.8k Views 46 Watching
    • fredo6F
      @tig said:
      I have a'SUClock' related issue. 😒
      If I deactivate the 'SUClock' Extension and restart Sketchup then when I try to run some of your tools [BezierCurve and RoundCorner] - I get a Ruby Console error like this [ruby]Error: #<NoMethodError: undefined method `register_ruby' for SUClock:Module>
      C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:496:
      TIG,
      This is fixed (actually the method call is nomore to SUClock but to LibFredo6).
      However, I am not sure I published it for BezierSpline and RoundCorner. I'll check
      Thanks for signaling
        I also notice that when exporting to 'Tabbed Text' the '%%' column can be one tab off in certain columns.
        • KrisidiousK
          Krisidious
          ummm adding time to the clock?
          By: Kristoff Rand
          • guanjinG
            guanjin
            Fredo Hello, statistics clock can join FredoTools1.1m you? Only an icon, taken together, easy to manage, thank you!
            • T
              tomvokurka
              Hi.
              I have a small problem with this plugin. I found it really usefull, but somehow I can't set it up.
              When I click on a clock icon, select "Attach to a New Project", then type a name of .suclock file and save it in a file with my SU model (with a same name as model) I can't see any .suclock file in explorer. It even doesn't start counting time, no clock appears at all. Can anyone help me? Some advices?
              I've got SU 8 and Win 7.
              Thanks a lot!
              • fredo6F
                @tomvokurka said:
                Hi.
                Thanks a lot!
                Strange. However on Windows 7 there are by default many security rules preventing to create files by script so it may just be that issue of security (actually the file may be created in a security zone, but not writable).
                I would suggest that you redo the operation, opening before the Ruby console. Also, do you get a message from SuClock?
                  Fredo, have you found a solution to Vista, Win7 putting files you write out in SU Ruby into the Virtualstore?
                  • fredo6F
                    No. From Ruby you don't see anything, except that the file is created or not created.
                    Actually, I don't understand very well how this virtualstore works and what is the intention.
                      I found I could detect if a file was in VirtualStore or not. But if I wanted to create a file I cannot work out in advance if it will appear in VirtualStore or not.
                      If I edit a file in the Plugins folder everything is fine, but creating new one will stuff it in VS. Very troublesome since I'm trying to make a plugin installer. Might I actually need to write a C Extension? ...might do, might make one that actually writes unicode files as well.
                      • K
                        kierovnick
                        Oh my God! I mean.. oh my Fredo6!
                        How could i miss this one?
                        I was waiting for it so long and somehow it slipped past my nose until today.
                        There's not many plugins that are MUST HAVE for me, but most of them are of your autorship.
                        My plugin library will look like My plugin library +1 from now on 😄
                        I am sure i will donate, so you could buy some coffe to work on Your next plugins 😄
                        Thank You.
                          Greetings Fredo,
                          I just had an e-mail from a Mac user saying that despite downloading the new maintenance release of SketchUp, he's still getting black text boxes with this plugin. Thoughts or ideas?
                          Thanks.
                            mwm5053
                            I'm using OSX 10.7.4 latest Lion release, SU 8 latest release and LIbFredo6 4.6 just so you could see I also just found this very useful Thanks
                            2011 iMac
                            SU 2015 Pro, 2017 Make
                            V2 Twilight
                            macOS Sierra 10.12.5
                              rv1974
                              Is there way to permanently hide 'check plugins for update' window (the small yellow one with ruby)?
                                mwm5053
                                You should only see it every 15 days or so, good to have if there have been updates, bug fixes and such.
                                2011 iMac
                                V2 Twilight
                                  That's part of LibFredo. Set the frequency to 999 to disable.
                                    If you really don't want to see it every 15 days, go to window>LibFredo6 Settings>Default Parameters and change it.
                                    As Walt says, though, it doesn't hurt to have it pop up. It makes it easy to check for updates.
                                      JFought
                                      really having a problem installing this. I could use some help.
                                        Is there any chance you could describe the problem?
                                        • KrisidiousK
                                          Krisidious
                                          Love the plugin updater...
                                          By: Kristoff Rand
                                          • LanaL
                                            Lana
                                            It's is new for me. Thankssssssss 😍
                                            • 3 / 7
