    [Plugin] SUClock - v3.1a - 02 Apr 24 - Tracking time in SU
    138 Posts 46 Posters 158.5k Views 46 Watching
      SketchUpNoobie
      NEW RELEASE: SUCLOCK 1.2a - 03 May 11
      Nice! Thanks. πŸ‘
      It's June though. πŸ˜‰
      SketchUpNoobie: the complete noob in all things SketchUp.
      • fredo6F Offline
        NEW RELEASE: SUCLOCK 1.2a - 03 Jun 11
        This release adds some functional enhancements and problem fixing based on feedback received from users
        Alarm to Target:
        The principle is to set a target time and an alarm threshold for the project, so that you are warned when the effective time spent is close and then above the target time.
        The clock will indicate visually where you stand in the achievement of your target. Say that you set a target time at 4h, with a threshold of 75%:
        Statistics reports:
        I included the possibility to generate reports in several formats (I may add more).
        HTML is not implemented yet. I need to made changes to LibFredo6, so it will be available in a next release. You can set up the default format in the Default Parameters dialog box.
        Cropping of the clock window:
        As the exact rendering of the clock window depends from too many settings (Operating system, browser version, etc…), I simply made the height of the clock window a parameter that you can change in the Default Parameters dialog box. Default height is 50 pixels.
        Multi-user environment:
        If you wish several users to work on the same projects across the network, then you need to configure SUClock with a temporary directory located on a shared drive (as well as the suclock files indeed).
        You can set the network path of the temporary directory in the Default Parameters dialog box.
        Reset projects and Import data from another project:
        You can reset a project to Zero. This will erase all data irreversibly.
        You can import data from another project into the current project. Optionally, you can then reset to zero this other project.
        CAUTION: In version 1.2, I did not provision an Undo for these two functions. So please use with care!
        Update is published in main post.
        • spenceS Offline
          spence
          Fredo,
          Thank you for the plugin, this is fantastic πŸ˜„ This will come in very handy. This type of time tracking should be build into all productive software programs. It would be nice to be able to track your time, then again in some ways it's bad, It may prove I'm not that productive πŸ˜’
          Spence
            rastus127
            Great looking plugin Fredo!! But I'm having trouble loading it into S8 plugins folder. I keep getting an error that says "The item SUClock%201 can not be moved because "Sketchup" cannot be modified". But it loaded itself at the bottom of the list of folders. I'm on a Mac and have loaded other plugins most times with success, sometimes not. Maybe its just me. if you know what I'm doing wrong I'd rely appreciated any help you can give. Thanks.
                 Paul
            • fredo6F Offline
              Paul
              Paul,
              The presence of the "%20" indicates that you probably downloaded or unzipped the files with a tool that does not convert properly file names (%20 is the the replacement for Space). Can try with a different tool.
              You may also have some permission access issues on your Mac
                publied
                thank You! very nice and useful script!
                hire me@ http://www.publied.it !
                • COSEDIMARCOC Offline
                  COSEDIMARCO
                  Thanks for export! πŸ˜„
                  [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                  • halroachH Offline
                    halroach
                    Hi Fredo,
                    Now that the plugin works over the network, do you think it can be possible to assign, in the default parameters/in the main menu, a Username.
                    It could be username for each computer or you could even have multiple usernames for one computer, though I think that wouldn't be necessary.
                    The idea would be to track time for a project with the ability to see how much time each user spent on it and at what time during the project each user was involved... would be great for a gantt chart...
                    FlexTools - Super Quick Windows, Doors, Slats...
                      COSEDIMARCO
                      Hi Fredo
                      attached there's the Italian Translation for SuClock
                      I think i've found a couple english mistakes:
                      "Threshold when clock in displayed in warning mode" --> "Threshold when clock is displayed in warning mode
                      "ERROR: you can import data from the same current project
                      " --> "ERROR: you can't import data from the same current project
                      Italian Translation
                      • fredo6F Offline
                        NEW RELEASE: SUCLOCK 1.3a - 08 Oct 11
                        This release fixes problems encountered with Mac OSX Lion and Safari 5.1 (no images in the clock window)
                        • KrisidiousK Offline
                          Krisidious
                          how does one go about adding time to a model? I already worked on it and forgot to hit the SUClock?
                          is there a way to auto start SUClock with every new model?
                          By: Kristoff Rand
                            I have a'SUClock' related issue. πŸ˜’
                            If I deactivate the 'SUClock' Extension and restart Sketchup then when I try to run some of your tools [BezierCurve and RoundCorner] - I get a Ruby Console error like this Error: #<NoMethodError: undefined methodregister_ruby' for SUClock:Module>
                            C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:496:in activate' ... I deduce that this is because those two tools' test for the definition? of 'SUClock', which returns 'true', because IT IS defined, and partially loaded, but because it's inactive with the Extension being disabled, then the relevant 'register_ruby' method isn't available - so I get the error.
                            If I have SUClock loading at all, then I must always have it active in the Extensions list, otherwise it breaks your other two tools when try to use them.
                            Of course stopping SUClock loading all together avoids this, as then it's then never 'defined?'.
                            But this is awkward, this Extension should be capable of being simply deactivated, as I do not use it that often: the whole point of an Extension is you load it as it is needed.
                            Your two problem tools need their code recasting, for example using something like this that prevents the failure being an issue...
                            **(begin;**SUClock.register_ruby('BezierSpline')**;rescue;end)**if defined?(SUClock) needed in two lines.
                            **(begin;**SUClock.register_ruby('RoundCorner')**;rescue;end)**if defined?(SUClock) needed once.
                            this works fine for me, but it really ought to be 'built-in' πŸ˜‰
                            • fredo6F Offline
                              @tig said:
                              If I deactivate the 'SUClock' Extension and restart Sketchup then when I try to run some of your tools [BezierCurve and RoundCorner] - I get a Ruby Console error like this [ruby]Error: #<NoMethodError: undefined method `register_ruby' for SUClock:Module>
                              TIG,
                              This is fixed (actually the method call is nomore to SUClock but to LibFredo6).
                              However, I am not sure I published it for BezierSpline and RoundCorner. I'll check
                              Thanks for signaling
                                I also notice that when exporting to 'Tabbed Text' the '%%' column can be one tab off in certain columns.
                                  Krisidious
                                  ummm adding time to the clock?
                                  By: Kristoff Rand
                                  • guanjinG Offline
                                    guanjin
                                    Fredo Hello, statistics clock can join FredoTools1.1m you? Only an icon, taken together, easy to manage, thank you!
                                      tomvokurka
                                      Hi.
                                      I have a small problem with this plugin. I found it really usefull, but somehow I can't set it up.
                                      When I click on a clock icon, select "Attach to a New Project", then type a name of .suclock file and save it in a file with my SU model (with a same name as model) I can't see any .suclock file in explorer. It even doesn't start counting time, no clock appears at all. Can anyone help me? Some advices?
                                      I've got SU 8 and Win 7.
                                      Thanks a lot!
                                      • fredo6F Offline
                                        @tomvokurka said:
                                        Hi.
                                        Thanks a lot!
                                        Strange. However on Windows 7 there are by default many security rules preventing to create files by script so it may just be that issue of security (actually the file may be created in a security zone, but not writable).
                                        I would suggest that you redo the operation, opening before the Ruby console. Also, do you get a message from SuClock?
                                          Fredo, have you found a solution to Vista, Win7 putting files you write out in SU Ruby into the Virtualstore?
                                          • fredo6F Offline
                                            No. From Ruby you don't see anything, except that the file is created or not created.
                                            Actually, I don't understand very well how this virtualstore works and what is the intention.
                                            • 3 / 7
