Can this be done in SU?
If the intersections lead to very small edges and/or faces, you can try to scale the model (e.g. x1000) before the intersections...
I think twan is looking for a filleted connection.
[edit]..
maybe something like this?
[it's just an exploratory go at it.. too fast/confusing to explain at this point.. if it's what you're after, i can maybe explain it in a simple manner.. and draw it more cleanly
- Tools on surface
- arcs
- Curviloft (Skinning)
right.. sort of similar to what i did except i used bezier splines instead of arcs & tools on surface
Jeff is right. i'm looking for a way to fillet the edge. Curviloft might be a option. I hadn't thought of that. going to give it a try.
@cotty said:
- Tools on surface
- arcs
[attachment=0:26kuj4gg]<!-- ia0 -->espresso.jpg<!-- ia0 -->[/attachment:26kuj4gg]
Once you have made 'square' junctions for the cup and handle [as I set out using Intersect etc] then you could use RoundCorners [Fredo] to make the rounded 'fillet' of any desired radius [there are several threads about making 'weld-fillets' for metal tubular structures that way].
Also as has been said, to avoid small facet issues scale it up x1000, to do the round-filleting before scaling back down again... -
Very nice suggestions, leading to terrible topology.
Don't try it if some real displacement gonna happen.
For exactly the same reason don't import it in zbrush or sculptris.There's only one decent way to model such things and it's not supported in SU.
...yet!
Well, I tried with artisan,
Not practical though.
Subdivisions based on quads is missing. (catmull-clark)
Thanx for al the good tips and feedback. I know that this can be better done in another app like MOI, Blender or 3dmax, and I've tried modeling it in blender. eventually I wil get it done in Blender but My modeling skills and speed are very poor with blender. I just want to do this in SU where I know all my shortcuts and where modeling is very intuitive.
Greetz Twan
Yeah, blender.
Don't forget to delete possible internal faces (non manifolds) and ctrl+N for normals.
...yet!
What do you have in mind thomthom?
...yet!
@ThomThom: This is THE tool that wil make product modeling in SU a whole lot easier and cleaner. Especially since nowadays everything in design is beveled, smoothed and aerodynamic.
Don't know if it will be a part of the plugin you are working on but the ideal tool in my opinion is a plugin that lets you weld geometry together and the plugin calculates the best option to weld the geometry together automatically adjusting the geometry where the two objects meet. But maybe this is Utopia in SU. Hope that the work on the plugin is coming along nicely and that we may welcome this plugin to the sketchucation family soon
PS: I'm hoping to finaly model this espresso cup tonight. Will post the result when ready. Then maybe I can finaly finish the scene it's supposed to be in.
Greetz Twan
@ThomThom
This is a great work but what we need to model a cup of coffee is just box modeling. Meaning quads not tris. Just extruding, welding and subsurfing (catmull clark). -
@ThomThom
This is a great work but what we need to model a cup of coffee is just box modeling. Meaning quads not tris. Just extruding, welding and subsurfing (catmull clark).Bezier Surface will let you create parametric Quad and Tri Surfaces.
why not nurbs?
[edit]
here's another approach for keeping it in sketchup.. using the loft tool in curviloft.
Jeff,
Nice to see videos on curviloft, there'll probably never be enough for me.
Now, how to resolve the dent these intersections put into the surface?Peter
Yes, thanks, Jeff.
I think you should drop a copy of you vid over in the one or all of the curvi threads.
Probably not exactly what you need, but still this is an interesting Kito Raupp's approach (especially the last example). All SU native tools.
[flash=853,480:2e3zhf4v]http://www.youtube.com/v/sQvGUzA2g5Q?version=3&hl=it_IT&rel=0[/flash:2e3zhf4v]
