    Shape on the curve surface
    43 Posts 7 Posters 3.0k Views 7 Watching
      cleaner
      Thank you for your answers. @pbacot that's it I want to achieve. Since I am a beginner, and my english is not my native language to me is now pending to study what you wrote, and I must find needed plugins. Radius isn't bigger at the top of the vault. Now I'm going to try to do by your instructions. Thanks again to all.
        cleaner
        I replied and thanked to Pilou and pbacot, but I do not see my post.
        • pbacotP Offline
          The picture you show looks like the joint push-pull in progress, and after that it should compute the shape and form faces. Try typing a distance in the process for the depth of the push. Certainly there are factors that can cause it to fail but this looks like it's getting close.
          When I referred to the follow-me tool: I used an arc as the "path", pick the tool then click on a FACE that has an arc as part of the outline. I am not sure if you are familiar with the tool. There are some tutorials on it, if you haven't learned it yet. There are requirements to set it up which would be easier to understand when you read the help sections and see the tutorials. It's in the Google help, since it is a standard SU tool.
          I turned on hidden geometry, and instead "follow me" I used the "line" tool to get the required shape.
          Yes, that is how I drew the recess shape (after making the vault surface with follow-me). I drew over the softened lines with the line tool. (You can also use the eraser with a key combination (Option-shift on the Mac) to Unsoften lines for the same result).
          Good luck. Looks like you have some progress on the model.
          • massimoM Offline
            massimo Moderator
            I would model only the ridges while for the pitches of the roof you could start with a texture like this maybe adding some dirt.
              cleaner
              It really looks very good, but I think that each tile has a rectangular shape with semicircular ends. This way more reminiscent of fish scales.
              • brookefoxB Offline
                brookefox
                Looks like it would be easy to model one roof tile, copy many times to make a square, and then take a pic of that and edit it, convert to png or whatever you need to make a render texture tile. I don't render, clearly.
                ~ Brooke
                • massimoM Offline
                  massimo Moderator
                  Ok, maybe this is better then.
                  • pbacotP Offline
                    Nice, Massimo. πŸ‘
                    And, cleaner: Good job. Looking forward to seeing more shots!
                      cleaner
                      Massimo well now you made ​​it exactly as it should. πŸ‘ Did you made tiles ​​in the SU, and how (rectangle + arc) they are multiplied and aligned? How are inflicted dirt and weathered, (with Photoshop maybe?
                      I can put more pictures, if you are interested, when I finish the model. I am not satisfied with a dome on the tower.
                      • massimoM Offline
                        massimo Moderator
                        Neither SU nor PS. I used PixPlant starting from a photo found on the net. It required a bit of work, no more that 10 min however, because the photo was not so good: deformed and crooked. PixPlant is a wonderful program, you can easily straighten, crop and set a pattern for the seed image. Then generate the seamless texture from the seed image. Also you can work easily locally on small details (add and remove parts of the seed image, generate local parts of the texture etc.) in order to correct the final image. And of course you can also generate normal, displacement and specular maps from the diffuse map.
                        Sure. πŸ‘
                          brookefox
                          Is this tenable, reasonable or not so much?
                          ~ Brooke
                            cleaner
                            I understand, but Massimo is so well done, and I have to ask him how he did it. His tile material is perfectly fit to the roof.
                              brookefox
                              No, I understand and appreciate your wanting to go with the easiest, best as judged by you. I was hoping 'they' might comment and help us both.
                              ~ Brooke
                              • pbacotP Offline
                                I'm not one of them, but I thought it was an interesting idea to use SU this way. It takes some artistry and patience (which I didn't apply). Hard to simulate the realism of the photo with soft shadows and all. So which is faster? I think the photograph is faster and nicer. A quick render, not really run long enough. Maybe they have more ideas on this method....picture.pngtile max.png
                                  brookefox
                                  I appreciate your weighing in. If you have the photo in hand, quicker, as you say, but if you don't (as he didn't), nice to know you can 'make' the photograph.
                                  Thank you, Peter.
                                  ~ Brooke
                                  • pbacotP Offline
                                    Cleaner,
                                    1. With Hidden Geo ON. select a face. Context menu "Texture" /Position, as well as possible. Choose "projected". Sample the texture with Materials eyedropper (command key on Mac--Windows=?). 2. Then: Hidden Geo OFF. Apply texture to whole face. See if that helps.
                                    It looks like your image is only part of the face, so not sure how you can fix that. I'd try expanding the field around the decoration in a photo editor.
                                    What is that dome made out of? Looks like it's coming out nice!
                                    Peter
                                    • jeff hammondJ Offline
                                      yeah.. it's reasonable.. i do it sometimes with decent results..
                                      (also allows you to make huge textures to avoid tiling in the render while avoiding all the geometry needing to be in the model itself)..
                                      it's circumstance based.. sometimes it will work, others it's won't..
                                        cleaner
                                        Thanks I will try. If that doesn't work, I see that there is a tool "shape on surface" and I will try with that. It seems that dome is made of ordinary metal sheet (tin), if I understand the question.
                                        No I didn't succeed, because it seems there is not one, but several areas, as seen from the picture with hidden geometry on.
                                        [xxl-img:1ep4luxz]http://i191.photobucket.com/albums/z126/ser_cleaner/1bcba3fa.jpg[/xxl-img:1ep4luxz]
                                        Sorry 😳 I have some pictures too large, I thought that there was a script on the forum, which reduces them to the default size.
                                          [off:23ye8z2z]
                                          You can either attach an image straight here (best solution as the forum software will create a clickabe thumbnailwhich loads easier) or use the [XXL-img] tag (I have now edited your post with this tag: it also "shrinks" the image to fit in and makes it clickable although it's still the original size so may load slower)[/off:23ye8z2z]
                                          • pbacotP Offline
                                            [xxl-img:1c3vk9op]http://i191.photobucket.com/albums/z126/ser_cleaner/1bcba3fa.jpg[/xxl-img:1c3vk9op]
                                            Cleaner-- post just the spire model and the image and maybe someone can figure it out. I don't see the problem from your description. Peter
                                            • 1 / 3
