    Shape on the curve surface
    43 Posts 7 Posters 3.0k Views 7 Watching
      cleaner
      It really looks very good, but I think that each tile has a rectangular shape with semicircular ends. This way more reminiscent of fish scales.
      • brookefoxB Offline
        brookefox
        Looks like it would be easy to model one roof tile, copy many times to make a square, and then take a pic of that and edit it, convert to png or whatever you need to make a render texture tile. I don't render, clearly.
        ~ Brooke
        • massimoM Offline
          massimo Moderator
          Ok, maybe this is better then.
          • pbacotP Offline
            Nice, Massimo. πŸ‘
            And, cleaner: Good job. Looking forward to seeing more shots!
              cleaner
              Massimo well now you made ​​it exactly as it should. πŸ‘ Did you made tiles ​​in the SU, and how (rectangle + arc) they are multiplied and aligned? How are inflicted dirt and weathered, (with Photoshop maybe?
              I can put more pictures, if you are interested, when I finish the model. I am not satisfied with a dome on the tower.
              • massimoM Offline
                massimo Moderator
                Neither SU nor PS. I used PixPlant starting from a photo found on the net. It required a bit of work, no more that 10 min however, because the photo was not so good: deformed and crooked. PixPlant is a wonderful program, you can easily straighten, crop and set a pattern for the seed image. Then generate the seamless texture from the seed image. Also you can work easily locally on small details (add and remove parts of the seed image, generate local parts of the texture etc.) in order to correct the final image. And of course you can also generate normal, displacement and specular maps from the diffuse map.
                Sure. πŸ‘
                  brookefox
                  Is this tenable, reasonable or not so much?
                  ~ Brooke
                    cleaner
                    I understand, but Massimo is so well done, and I have to ask him how he did it. His tile material is perfectly fit to the roof.
                      brookefox
                      No, I understand and appreciate your wanting to go with the easiest, best as judged by you. I was hoping 'they' might comment and help us both.
                      ~ Brooke
                      • pbacotP Offline
                        I'm not one of them, but I thought it was an interesting idea to use SU this way. It takes some artistry and patience (which I didn't apply). Hard to simulate the realism of the photo with soft shadows and all. So which is faster? I think the photograph is faster and nicer. A quick render, not really run long enough. Maybe they have more ideas on this method....picture.pngtile max.png
                          brookefox
                          I appreciate your weighing in. If you have the photo in hand, quicker, as you say, but if you don't (as he didn't), nice to know you can 'make' the photograph.
                          Thank you, Peter.
                          ~ Brooke
                          • pbacotP Offline
                            Cleaner,
                            1. With Hidden Geo ON. select a face. Context menu "Texture" /Position, as well as possible. Choose "projected". Sample the texture with Materials eyedropper (command key on Mac--Windows=?). 2. Then: Hidden Geo OFF. Apply texture to whole face. See if that helps.
                            It looks like your image is only part of the face, so not sure how you can fix that. I'd try expanding the field around the decoration in a photo editor.
                            What is that dome made out of? Looks like it's coming out nice!
                            Peter
                            • jeff hammondJ Offline
                              yeah.. it's reasonable.. i do it sometimes with decent results..
                              (also allows you to make huge textures to avoid tiling in the render while avoiding all the geometry needing to be in the model itself)..
                              it's circumstance based.. sometimes it will work, others it's won't..
                                cleaner
                                Thanks I will try. If that doesn't work, I see that there is a tool "shape on surface" and I will try with that. It seems that dome is made of ordinary metal sheet (tin), if I understand the question.
                                No I didn't succeed, because it seems there is not one, but several areas, as seen from the picture with hidden geometry on.
                                [xxl-img:1ep4luxz]http://i191.photobucket.com/albums/z126/ser_cleaner/1bcba3fa.jpg[/xxl-img:1ep4luxz]
                                Sorry 😳 I have some pictures too large, I thought that there was a script on the forum, which reduces them to the default size.
                                  [off:23ye8z2z]
                                  You can either attach an image straight here (best solution as the forum software will create a clickabe thumbnailwhich loads easier) or use the [XXL-img] tag (I have now edited your post with this tag: it also "shrinks" the image to fit in and makes it clickable although it's still the original size so may load slower)[/off:23ye8z2z]
                                  • pbacotP Offline
                                    [xxl-img:1c3vk9op]http://i191.photobucket.com/albums/z126/ser_cleaner/1bcba3fa.jpg[/xxl-img:1c3vk9op]
                                    Cleaner-- post just the spire model and the image and maybe someone can figure it out. I don't see the problem from your description. Peter
                                      cleaner
                                      Thx Gaieus, I will follow your instructions in the future.
                                      As pbacot advised, here are just attached only the top of the tower, with the (material) ornaments that I want to apply to the dome.
                                      church_spire.skp
                                        cleaner
                                        Peter loves challenges, πŸ˜„ showed us - this can be done with SketchUp, if you do not have an appropriate image or materials. Thanks
                                        As I said I did not like the dome, so I revised it today. Now it looks like in reality.
                                        [xxl-img:365gifsb]http://i191.photobucket.com/albums/z126/ser_cleaner/32b2fc65.jpg[/xxl-img:365gifsb]
                                        But when I wanted to put a picture of this ornament as projected material, didn't turn out well, as you can see.
                                        [xxl-img:365gifsb]http://i191.photobucket.com/albums/z126/ser_cleaner/3e88c730.png[/xxl-img:365gifsb]
                                        This is the best thing I could do it,
                                        [xxl-img:365gifsb]http://i191.photobucket.com/albums/z126/ser_cleaner/dd9fa0e0.jpg[/xxl-img:365gifsb]
                                        I colored in using only the closest shade of color. Is there a way to do it properly? And a background image is too dark and I don't know how to brighten. I apologize for my English.
                                          cleaner
                                          I tried, but I don't know how to use follow me arc tool. Can not be using both at once - "follow me" toggle "arc" tool. I turned on hidden geometry, and instead "follow me" I used the "line" tool to get the required shape. Then I turned off hidden geometry and used the "joint push pull" tool, but as you can see that tool just make a hole. πŸ˜•
                                          [xxl-img:1my17ov0]http://i191.photobucket.com/albums/z126/ser_cleaner/684090de.png[/xxl-img:1my17ov0]
                                            cleaner
                                            Thanks to the generous help of pbacot, I am bringing to the end my 3D model of the church.
                                            [xxl-img:2wksb6gk]http://i191.photobucket.com/albums/z126/ser_cleaner/eeb449d6.jpg[/xxl-img:2wksb6gk]
                                            I need a little polished roof with tile materials. The default roof tiles model from SU does not look nice. I looked in the 3D warehouse, but there is no such form
                                            [xxl-img:2wksb6gk]http://i191.photobucket.com/albums/z126/ser_cleaner/f9787533.jpg[/xxl-img:2wksb6gk]
                                            and I am certainly not able to crop an appropriate segment. This is not good [xxl-img:2wksb6gk]http://i191.photobucket.com/albums/z126/ser_cleaner/5b596b41.jpg[/xxl-img:2wksb6gk]
                                            Could you please help me, where to find this model of tile?
                                            • 1 / 3
