    Do we have a Joke Thread goin here?
    630 Posts 94 Posters 187.2k Views 94 Watching
    • boofredlayB Offline
      boofredlay
      I changed my iPod name to Titanic . It's syncing now.
      • soloS Offline
        LMFAO, stolen
        • chrisglasierC Offline
          chrisglasier
          From local (likes CAPS) publican
          FIRST QUESTION:
          YOU ARE A PARTICIPANT IN A RACE. YOU OVERTAKE
          THE SECOND PERSON. WHAT POSITION ARE YOU IN?
          ANSWER :  IF YOU ANSWERED THAT YOU ARE FIRST,
           THEN YOU ARE  ABSOLUTELY WRONG! IF YOU OVERTAKE THE
           SECOND PERSON AND  YOU TAKE HIS PLACE, YOU ARE IN SECOND PLACE!
           TRY TO DO BETTER NEXT TIME.
           NOW ANSWER THE SECOND QUESTION,
           BUT DON'T  TAKE AS MUCH TIME AS
           YOU TOOK FOR THE FIRST QUESTION,  OK?
          SECOND QUESTION:
           IF YOU OVERTAKE THE LAST PERSON, THEN YOU ARE....?
          (SCROLL  DOWN)
          ANSWER: IF YOU ANSWERED THAT YOU ARE SECOND TO LAST, THEN YOU  ARE.....
            WRONG AGAIN. TELL ME SUNSHINE, HOW CAN YOU OVERTAKE THE LAST PERSON??
          YOU'RE  NOT VERY GOOD AT THIS, ARE YOU?
          THIRD QUESTION:
           VERY TRICKY ARITHMETIC! NOTE:
           THIS MUST BE DONE IN YOUR HEAD ONLY.
          DO NOT USE PAPER AND PENCIL OR A CALCULATOR.
           TRY IT.
           TAKE&nb sp;1000 AND ADD 40 TO IT. NOW ADD ANOTHER 1000 NOW ADD 30.
           ADD ANOTHER 1000. NOW ADD 20 .. NOW  ADD ANOTHER 1000.
           NOW ADD 10. WHAT IS THE TOTAL?
           SCROLL DOWN FOR THE CORRECT ANSWER.....
          DID YOU GET 5000?
          THE CORRECT ANSWER IS ACTUALLY 4100...
          IF YOU DON'T BELIEVE IT, CHECK IT WITH A CALCULATOR!
          TODAY IS DEFINITELY NOT YOUR DAY, IS IT?
          MAYBE  YOU'LL GET THE LAST QUESTION RIGHT....  MAYBE...
          FOURTH QUESTION:
          MARY'S FATHER HAS FIVE DAUGHTERS:
           1.      NANA, 2. NENE, 3. NINI,  4. NONO, AND ???
          2      WHAT IS THE NAME OF THE FIFTH DAUGHTER?
          DID YOU ANSWER NUNU? NO! OF COURSE IT ISN'T.
           HER NAME IS MARY! READ THE QUESTION AGAIN!
          OKAY, NOW THE BONUS ROUND,
           I.E., A FINAL CHANCE TO
           REDEEM YOURSELF:
          A MUTE PERSON GOES INTO A SHOP AND WANTS TO BUY A TOOTHBRUSH.
           BY IMITATING THE ACTION OF BRUSHING HIS TEETH HE
           SUCCESSFULLY EXPRESSES HIMSELF TO THE SHOPKEEPER AND THE  PURCHASE IS DONE.
           NEXT, A BLIND MAN COMES INTO THE SHOP WHO WANTS TO BUY A
           PAIR OF SUNGLASSES; HOW DOES  HE INDICATE WHAT HE WANTS?
          IT'S REALLY VERY SIMPLE
           HE OPENS HIS MOUTH AND ASKS FOR IT...
          DOES YOUR EMPLOYER ACTUALLY PAY YOU TO THINK??
           IF SO DO NOT LET THEM SEE YOUR ANSWERS FOR THIS TEST!
          PASS THIS ON TO FRUSTRATE THE
           SMART PEOPLE IN YOUR LIFE!
          HAVE A NICE DAY, ONE AND ALL.
          • brookefoxB Offline
            brookefox
            That math item has got me so confused....
            Is this the key phrase: "TAKE&nb sp;1000"? And what does it really mean?
            ~ Brooke
              [off:2vks7agi] &nbsp; means "non breakable space" and usually used in html code to insert a dummy space between two tags to make sure they are not empty (like <p>&nbsp;</p> to insert a "non empty still sort of empty" paragraph) or as "space holders" between (say) two buttons (although this should rather be done in CSS).
              Though it may have been confusing ("as if" there should have been something there but lost during coding), eventually there's no loss.
              Here are some examples from the forum's source code...
              nbsp.png[/off:2vks7agi]
              • david_hD Offline
                david_h
                @gaieus said:
                [off:vspliyy4] &nbsp; means "non breakable space" and usually used in html code to insert a dummy space between two tags to make sure they are not empty (like <p>&nbsp;</p> to insert a "non empty still sort of empty" paragraph) or as "space holders" between (say) two buttons (although this should rather be done in CSS).
                [attachment=0:vspliyy4]<!-- ia0 -->nbsp.png<!-- ia0 -->[/attachment:vspliyy4][/off:vspliyy4]
                ๐Ÿคฃ Great joke Gai!
                I got it anyway.
                  brookefox
                  I must insist ย  is very much on topic, both as being in the OP and in my smokescreen response...
                  After 15 or so attempts I was able to make the complex addition and get the 'approved' answer, without a calculator....
                  but I may well have added incorrectly.
                  ~ Brooke
                    tim
                    I was once an IBM Research Fellow in the UK. I worked with an experimental CAD terminal - real high-resolution, a whole 1024x1204 8bpp, but this was after all in 1981 - which was developed as part of an internal company competition to produce the next IBM CAD hardware product. It was called the Titanic because everyone knew it would never cross the Atlantic...
                    • BoxB Offline
                        What are the names of the children of Einstein?
                        Zweistein and Dreistein... ๐Ÿ˜’
                        • MarianM Offline
                          Marian
                          ๐Ÿ˜†
                          • jeff hammondJ Offline
                            i admit.. i don't get this joke at all ๐Ÿ˜†
                              Ole and Lena were sitting in church. During the sermon Lena passed Ole a note. It said, "I yust let a silent fart. Vhat should I do?" Ole turned the paper over and wrote, "Vell, da first ting is change da battery in yer hearing aid."
                                ๐Ÿ˜†
                                In German language,
                                Ein = 1
                                Zwei = 2
                                Drei = 3
                                (Stein = stone but that has nothing to do with the joke)
                                  @gaieus said:
                                  :lol:
                                  In German language,
                                  Ein = 1
                                  Zwei = 2
                                  Drei = 3
                                  ha! nice
                                  thanks for clearing that up
                                    An Alsatian went to a telegram office, took out a blank form and wrote, โ€œWoof. Woof. Woof. Woof. Woof. Woof. Woof. Woof. Woof.โ€
                                    The clerk examined the paper and politely told the dog: โ€œThere are only nine words here. You could send another โ€˜Woofโ€™ for the same price.โ€
                                    โ€œBut,โ€ the dog replied, โ€œthat would make no sense at all.โ€
                                      There was a small phone company in Minnesota many years ago that was going to hire one team of telephone pole installers, and the boss had to choose between a team of two Norwegian guys and a team of two Irish guys.
                                      So the boss met with both teams and said, "Here's what we'll do. Each team will be installing poles out on the new road for a day. The team that installs the most phone poles gets the job."
                                      Both teams headed right out. At end of the shift the Norwegian guys, came back, and the boss asked them how many they had installed.
                                      They said that it was tough going, but they'd put in twelve.
                                      Forty-five minutes later the Irish guys came back in, and they were totally exhausted.
                                      The boss asked, "Well, how many poles did you guys install?"
                                      The team leader, wiped his brow and sighed, "O'Malley and me, we got three in."
                                      The boss gasped, "Three? Those two Norwegian guys put in twelve!"
                                      "Yeah," said O'Malley, "but you should see how much they left stickin' out of the ground."
                                      • david_hD Offline
                                        david_h
                                        1. Where there's a will, I want to be in it.
                                        2. The last thing I want to do is hurt you. But it's still on my list.
                                        3. Since light travels faster than sound, some people appear bright until you hear them speak.
                                        4. If I agreed with you, we'd both be wrong
                                        5. We never really grow up, we only learn how to act in public.
                                        6. War does not determine who is right - only who is left.
                                        7. Knowledge is knowing a tomato is a fruit. Wisdom is not putting it in a fruit salad.
                                        8. They begin the evening news with 'Good Evening,' then proceed to tell you why it isn't.
                                        9. To steal ideas from one person is plagiarism. To steal from many is research.
                                        10. Buses stop in bus stations. Trains stop in train stations. On my desk is a work station.
                                        11. I thought I wanted a career. Turns out I just wanted paychecks.
                                        12. In filling out an application, where it says, 'In case of
                                          emergency, notify:' I put 'DOCTOR.'
                                        13. I didn't say it was your fault, I said I was blaming you.
                                        14. Women will never be equal to men until they can walk down the street with a bald head and a beer gut, and still think they are sexy.
                                        15. Behind every successful man is his woman. Behind the fall of a successful man is usually another woman.
                                        16. A clear conscience is the sign of a fuzzy memory.
                                        17. You do not need a parachute to skydive. You only need a parachute to skydive twice.
                                        18. Money can't buy happiness, but it sure makes misery easier to live with.
                                        19. There's a fine line between cuddling and holding someone down so they can't get away.
                                        20. I used to be indecisive. Now I'm not so sure.
                                        21. You're never too old to learn something stupid.
                                        22. To be sure of hitting the target, shoot first and call whatever you hit the target.
                                        23. Nostalgia isn't what it used to be.
                                        24. Change is inevitable, except from a vending machine
                                        25. Going to church doesn't make you a Christian any more than standing in a garage makes you a car.
                                        26. Where there's a will, there are relatives.
                                        • soloS Offline
                                          A Farmer walks into his bedroom holding a Sheep under his arm and says to his Wife... "This is the Pig I've been having Sex with whenever You have a Headache". His wife angrily responds, "You asshole... that's not a Pig... that's a Sheep" ... The Farmer replies... "I was talking to the Sheep."
                                          • soloS Offline
                                            The Pope is handing out miracles to sick kids in Liverpool.
                                            Billy walks on stage and asks him, "can you help me with my hearing?"
                                            The Pope says, "yes," and puts his hands on Billy's ears and prays, removes his hands and says, "how is your hearing now?"
                                            Billy says, "I don't know, it's not until next Wednesday."
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 27 / 32
