    [Plugin] Lamella Roofs
    63 Posts 25 Posters 54.8k Views 25 Watching
      Interesting.
      Any chance you could fix the script to use model units and make it accessible from a menu so the console isn't required?
      • Paul RussamP
        Paul Russam
        As Dave said +
        If you run the script in an existing model the first thing it does is DELETE EVERYTHING!! 😲 😲 😲 and I do mean delete, not hide, not move, DELETE
        Not good, not good at all
        Paul Russam
        English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
        • GaieusG
          @escapeartist said:
          Reminds me of some of the beautiful wooden aircraft hangar roofs I've seen...
          And reminds me of "perpendicular style" English Gothic vaults. πŸ˜‰
            @paul russam said:
            As Dave said +
            That's because the OP [TimWarner] doesn't seem to realize that you can make your own Template that doesn't include Sang etc; so in line #50 he has
            ents.clear! # Get rid of Sang
            Which of course empties the model if you've already dome some modeling !
            A disaster !!
            BUT it's easily disabled to avoid it erasing your existing model 😲 - edit the file and change line #50 to read.
            **#**ents.clear! # Get rid of Sang
            so that it's now ignored β˜€
            To avoid the clunky 'First run from the Console to install a menu item' [every time!]... the closing ' end' can simply be moved above the ' if...' that makes the menu entry so the menu is made as the script is auto-loaded πŸ˜•
            Also it's best to make the dialogs' defaults dimensions as 'lengths' thus:
            values = [1200**.l**,6000**.l**,20.0,6,2]
            forcing it into 'inches', i.e. 100'x50' - which now displays in the current units.
            If you're metricyou could use: [30.m,15.m,... etc anyway
            Then you can leave those two 'lengths' alone as
            height = results[0] span = results[1]
            i.e. NO .to_f is needed as it already knows it's a 'length' !
            In the second dialog you can make the sizes directly in 'mm' with [38.mm,150.mm,2,10.mm] etc and then skip changing the results with .to_f and also later on no .mm is needed etc - that way anyone can use it inputing in mm or cm or inches etc, depending on their current unit settings...
            Also you should stop if the user 'cancels' a dialog thus:
            results = **inputbox**(prompts, values, "Roof Settings") **return nil unless results**
            Also some other 'tips' - wrap the whole 'creation' part after the dialog in a model.start_operation('lamella')...create... model.commit_operation at the end, to make an easy one-step undo !
            Also you can easily protect you code inside a module thus:
            **module TimWarner** def **self.**lamella_roof()
            rest of code
            ... adjust the closing menu item to use the now modularized method:
            plugins.add_item("Lamella roof") { **self.**lamella_roof() }
            [ruby:14pvbkvc]end#module[/ruby:14pvbkvc] goes after everything else...
            If you implement these general changes this has the basis of a useful toolset...
              I recommend you read the guidelines to SketchUp Ruby Plugin developement I wrote down so that your plugin play nice with the shared plugin environment it runs in. Avoiding potential conflicts.
              http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/
              • brookefoxB
                brookefox
                Will the routine allow the creation of in-line lamellas, without the slight offsets?
                Thank you much for sharing, Tim.
                (bmike, you didn't forget the bookmark feature here?)
                ~ Brooke
                • bmikeB
                  bmike
                  bookmark, what is that?
                  i usually post, then it is in my threads.
                  will have to try to bookmark...
                  πŸ˜„
                  πŸ‘
                  • bmikeB
                    bmike
                    reply to keep this in my list of threads.
                    i'll peek back once the ruby gets improved.
                    nice looking plugin.
                    • W
                      watkins
                      Dear Tim,
                      You and your colleagues are to be congratulated on your achievement. How long did it take start to finish, and did you have building experience before starting the project?
                      Kind regards,
                      Bob
                      • T
                        timwarner
                        Simple answer, no. The plugin assumes the use of dimensional lumber and common bolt connectors, as in the original Zollinger concept, and in recent examples like the Rural Studio dog shelter http://apps.cadc.auburn.edu/rural-studio/Default.aspx?path=Gallery%2fProjects%2f2006%2fhalecoanimalshelter%2f. But it's a natural option, and easier to model. Thx for the (implicit) suggestion.
                        PS I'm attaching a brief monograph on the underlying geometry.
                        The Geometry of a Lamella Roof
                        • T
                          timwarner
                          @watkins said:
                          Dear Tim,
                          Kind regards,
                          Bob
                          Thx Bob,
                          This is actually a one-man show. I built a lamella roof (the one shown at the top of the thread) some years back, based on a crude, and actually wrong Excel model, but only worked out the exact geometry last year. Writing a plugin involved learning Ruby (OK, it shows!), and grappling with the SU documentation, which I have to say I find opaque in many ways. The plugin probably took about three months to work out.
                          I'm not a builder at all, but I've done some simple construction work, if dry-stack walls count.
                          • pep75P
                            pep75
                            Great plugin Tim!!
                            πŸ˜‰
                            • T
                              timwarner
                              I've corrected the plugin to reflect the very helpful community comments, and fix some minor errors in the way curved surfaces were being generated. Both the revised plugin and documentation are embedded in the original post to make them easier to find.
                              I'm still puzzling over a couple of issues. First is the odd failure of the intersect_with method in at least one circumstance. (Posted elsewhere http://forums.sketchucation.com/viewtopic.php?f=180&t=46714). This wipes out a couple of faces in a lamella, but is rare, and easy to fix manually. Second, the geometry is off by a small (< 1mm) amount in terms of the components not lining up exactly. It doesn't feel like a rounding error, so my calculations may be incorrect. Practically this is not significant.
                              Thx all, and TIG and Thomthom especially, for your advice.
                              • KrisidiousK
                                Krisidious
                                Really appreicate the plugin... and even more so Tig and Thom for always checking all these plugins out for us and warning us before installing them.
                                By: Kristoff Rand
                                • T
                                  timwarner
                                  I've updated the plugin to allow the creation of a diagrid lamella roof, where the lamellas are co-planar, following brookefox's suggestion, and to add some error-checking and spinners on input. Updates are located with the original post.
                                  Under some circumstances the upper surface of the lamella is not created properly, for reasons I still don't understand. The cutting instructions are correct, regardless.
                                    Mra
                                    Thanks Tim, hope I get to do a project with this kind of roof one day!
                                    • V
                                      victor hugo
                                      I dropped the lamella_roof.rb to the plugins folder and nothing happens, restarted SU and is not on the list?
                                      Any one has the same issue.
                                      I also like the big hangars made of concrete by the designer an italian eng-arch Pier Luigi Nervi.
                                      Thanks.
                                        What did you expect to happen? Did "Lamella roof" show up in the Plugins menu?
                                        Go back to the Plugins folder and make sure lamella_roof.rb is there with the correct extension and that you didn't put it in some other Plugins folder.
                                        • V
                                          victor hugo
                                          pasted in the C:\Program Files\Google\Google SketchUp 8\Plugins.
                                            Let's see if I can drag some useful information out of you so we can help you. πŸ˜’
                                            And after you close and reopen SketchUp does the plugin show in the Plugins menu? Do you really have XP as your profile indicates?
                                            • 1 / 4
