    [Plugin] WireTool (Catenary) (1.4.1) – updated 06.03.2013
    54 Posts 26 Posters 60.4k Views 26 Watching
      @aerilius said:
      Type a length to set a fixed arc length:
      !!! I tried on this a couple of years ago! Never worked out how to do a fixed length curve. I need to snoop around in your code. I wanted to make a tool that would anchor the end point to other geometry so when you moved of the the object it was attached it the curve would update.
      • iichiversiiI Offline
        iichiversii
        Now this is a great plugin, thanks πŸ‘
        Bring on the Rain...
        • gullfoG Offline
          gullfo
          very cool! this is one of the more useful shapes in acoustics!
          Glenn
          http://www.runnel.com
            That I wasn't aware of. Guess I need to read up on it again.
            • mitcorbM Offline
              mitcorb
              Another good tool concept. By the way, Remus Knowles has another version in the Plugins Index.
                iichiversii
                Any idea what his version is called?
                  Aerilius
                  Remus' plugin is the Simple Catenary Curve. It "just" calculates the curve for a given set of 17 points but it put me on the right path to look on Wikipedia after I had a paper full of integrals that didn't want get further simplified.
                  • urgenU Offline
                    urgen
                    HA!...cool idea.thanks Aerilius πŸ‘
                    --pupil forever...------
                    • N Offline
                      nektares
                      I always did this with splines, this is a much better and precise way to do it, Thank you!
                      • sdmitchS Offline
                        sdmitch
                        When I tried the plugin, I kept getting a canatnary drawn from the origin to my first pick point. Adding a @state = 0 to the def initialize method fixed this problem.
                        http://sdmitch.blogspot.com/
                          Aerilius
                          Hi Sam,
                          thanks for the tip. I wonder why this happens, although the initialize method does not have @state=0, this should be set when the activate method calls reset.
                          Is someone else having this problem?
                          • massimoM Offline
                            massimo Moderator
                            Yes the same here. Thanks for the plugin btw. πŸ‘
                              create_geometry and draw_geometry can be refactored into one method that returns an array of point3d objects - the only difference between these methods are the final statement. DRY
                                I didn't experience the same thing that Sam reported.
                                • gullfoG Offline
                                  gullfo
                                  i added the @state=0 and it made a difference in terms of being able to select the first point. very nice tool!
                                  Glenn
                                    So why don't I have this same problem? I didn't modify the script and it works fine for me.
                                    • wind-borneW Offline
                                      wind-borne
                                      Which version are you using?
                                      initial version works fine for me, updated version moves to origin.
                                      "To read between the lines was easier than to follow the text."OSX 10.11.6
                                      %(#BF80BF)[SU 8 pro
                                        That would explain it. I didn't catch that there was an update because the thread title wasn't edited to show that as is SOP here.
                                          So now I've updated the plugin and added the line as mentioned. I get some rather strange behavior now. See the video.
                                          [flash=420,315:13s7e1sa]http://www.youtube.com/v/7IJXmgk8lio?version=3&hl=en_US[/flash:13s7e1sa]
                                            I have the original version [that works] if anyone wants it... πŸ˜•
                                            • 1 / 3
