    Mini-challenge
    328 Posts 26 Posters 74.1k Views 26 Watching
      You have not made the last file "save as V6" πŸ˜‰
        Use free SU8 to convert back to SU6?
        • gillesG Offline
          gilles
          V6 for Pilou.
          Mini-challenge3-2_v6.skp
          • gillesG Offline
            gilles
            Pilou works with a Minitel. 🀣
            ( private joke for frenchies )
              Ok now that work from the middle to the end of line! πŸ‘
              The two #5 and the #4 absent were not modified ! πŸ˜‰
              Your method is very very tricky! 😎
              I must find a solution with the offset tool πŸ€“
              PS My Minitel works like a charm πŸ’š
              • gillesG Offline
                gilles
                Any hint? πŸŽ‰
                  Gilles, you're a genius! I finally had a chance to get back to look at this and your method works very nicely. I wonder if I'll be able to remember it the next time I need it.
                    any Hint
                    Normaly practical for make some parallels πŸ˜‰
                    • jeff hammondJ Offline
                      @gilles said:
                      Here we go!
                      amazing!
                      you're a genius!
                      it's perfect.
                      • andybotA Offline
                        andybot
                        Dat is *&^$@# genius!! 😲 nice work gilles πŸ˜„
                          Seems too simple! πŸ˜„
                          Only PushPull ! πŸ˜‰
                          But why there is a mini glitch ? 😲
                          Jeffpush.skp
                          • jason_marantoJ Offline
                            jason_maranto
                            Very clever gilles -- makes perfect sense and needs no math to execute πŸ‘ πŸ‘
                            Best,
                            Jason.
                              VERY clever Pilou !
                              Bravo to you too.
                              Here's my slight reworking of your brilliant ideas, with some explanatory notes.
                              I think this way is a little simpler and easier to see what's happening.
                              PilouRakingRailAlt.skp
                                @TIG
                                Cool but there is a little mystery πŸ˜‰
                                In your file (from the mine modified) tichkness is not 1.000000m but 0.997509m
                                CD = 1.320818 m
                                Or you don't change the drawing and just type the text's explanations for only the theory?
                                In a nurbs modeler with the Technic of circle (first example of Jeff video) (with of course sames measures)
                                CD = 1.3239127 m & angle 40.945192Β°
                                The adventure is not finished! πŸ˜„
                                [flash=560,315:2erysmt0]http://www.youtube.com/v/ww17dNJt_LQ[/flash:2erysmt0]
                                File nurbs format 3dm
                                tig_jeff.zip
                                • pbacotP Offline
                                  Gilles,
                                  I Have no idea how you figured that out 😲 One snaps to a line that is not there until the execution. That's wild!
                                  Peter
                                  • pbacotP Offline
                                    In the example, why push pull up on the face? The whole point seems to be to find Point 'B'. (diagram THAT clause πŸ˜› )
                                    Maybe this is beyond my maths. True: the center cut line in the first picture does describe the center of the final board, call it point 'X'. B is a right angle from 'X' but it's a right angle from the board's diagonal, not from the final axis of the board. Still it lies on the edge of the board a distance d/2 from point X?brace - 1.png
                                    • gillesG Offline
                                      gilles
                                      Good try but... πŸ’š
                                        Pilou's version appears to work...
                                        But when I reproduce it there's inaccuracy again πŸ˜•
                                        Logic [initially] says that offsetting [pushpulling] a face that is coplanar with the known diagonal by width/2 and then adding the new sloping lines through the points ought to make them along the rail's raking edges ???
                                        BUT the offset is perpendicular to the diagonal NOT the rails sides !
                                        Hence the errors... very much like all other approximation methods πŸ˜•
                                        • pbacotP Offline
                                          TIG,
                                          To me the problem is that d/2 should be measured perpendicular to the final edge, not the diagonal.
                                          Peter
                                            @pbacot said:
                                            TIG,
                                            Peter
                                            Exactly right - I was adding that to my last post as you posted...
                                            The difference between offsetting the diagonal and the sides is the error. πŸ˜’
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
