    Mini-challenge
    328 Posts 26 Posters 91.7k Views 26 Watching
      I can't make it snap to the endpoint when I rotate...
        You don't need to snap to a point, click on the originally horizontal guide line, then it suggests an inference 'parallel to edge outside active', when you are approximately over the long edge in the sibling instance [as the ends are approximating to 'square'], click to accept that.
        πŸ’­
        EDIT: As Pilou shows in his screenshot - pipped at the post!
          Seems there is not #4, ( there are two #5) and I can't obtain your last result 😞
          I have snap on Parallel but not at "point"
          • gillesG
            gilles
            Did you take the alignment point at the end of the line?
            • oganocaliO
              oganocali
              In Step 5 while snapping, my sketchup refuses to snap "exactly" on the endpoint no matter where I pick, are you sure it is exact?
              • gillesG
                gilles
                I change the component axis location then it works better even with the end point.
                Mini-challenge3-2_v6.skp
                  The horizontal point of the end of the line don't work (on the right of the last red point on the blue line)
                  OK that works only if you take the click point under your arrey drawing! Very curious!!! 😲
                  Luck ? πŸ˜„
                    Right - now I see that it infer from itself. But I get no snapping from the end-point.
                      You have not made the last file "save as V6" πŸ˜‰
                        Use free SU8 to convert back to SU6?
                        • gillesG
                          gilles
                          V6 for Pilou.
                          • gillesG
                            gilles
                            Pilou works with a Minitel. 🀣
                            ( private joke for frenchies )
                              Ok now that work from the middle to the end of line! πŸ‘
                              The two #5 and the #4 absent were not modified ! πŸ˜‰
                              Your method is very very tricky! 😎
                              I must find a solution with the offset tool πŸ€“
                              PS My Minitel works like a charm πŸ’š
                              • gillesG
                                gilles
                                Any hint? πŸŽ‰
                                  Gilles, you're a genius! I finally had a chance to get back to look at this and your method works very nicely. I wonder if I'll be able to remember it the next time I need it.
                                    any Hint
                                    Normaly practical for make some parallels πŸ˜‰
                                    • jeff hammondJ
                                      @gilles said:
                                      Here we go!
                                      amazing!
                                      you're a genius!
                                      it's perfect.
                                      • andybotA
                                        andybot
                                        Dat is *&^$@# genius!! 😲 nice work gilles πŸ˜„
                                          Seems too simple! πŸ˜„
                                          Only PushPull ! πŸ˜‰
                                          But why there is a mini glitch ? 😲
                                          Jeffpush.skp
                                          • jason_marantoJ
                                            jason_maranto
                                            Very clever gilles -- makes perfect sense and needs no math to execute πŸ‘ πŸ‘
                                            Best,
                                            Jason.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
