    Mini-challenge
    328 Posts 26 Posters 99.4k Views 26 Watching
    • jeff hammondJ
      @gilles said:
      Here we go!
      amazing!
      you're a genius!
      it's perfect.
      • andybotA
        andybot
        Dat is *&^$@# genius!! 😲 nice work gilles πŸ˜„
          Seems too simple! πŸ˜„
          Only PushPull ! πŸ˜‰
          But why there is a mini glitch ? 😲
          Jeffpush.skp
          • jason_marantoJ
            jason_maranto
            Very clever gilles -- makes perfect sense and needs no math to execute πŸ‘ πŸ‘
            Best,
            Jason.
              VERY clever Pilou !
              Bravo to you too.
              Here's my slight reworking of your brilliant ideas, with some explanatory notes.
              I think this way is a little simpler and easier to see what's happening.
              PilouRakingRailAlt.skp
                @TIG
                Cool but there is a little mystery πŸ˜‰
                In your file (from the mine modified) tichkness is not 1.000000m but 0.997509m
                CD = 1.320818 m
                Or you don't change the drawing and just type the text's explanations for only the theory?
                In a nurbs modeler with the Technic of circle (first example of Jeff video) (with of course sames measures)
                CD = 1.3239127 m & angle 40.945192Β°
                The adventure is not finished! πŸ˜„
                [flash=560,315:2erysmt0]http://www.youtube.com/v/ww17dNJt_LQ[/flash:2erysmt0]
                File nurbs format 3dm
                tig_jeff.zip
                • pbacotP
                  Gilles,
                  I Have no idea how you figured that out 😲 One snaps to a line that is not there until the execution. That's wild!
                  Peter
                  • pbacotP
                    In the example, why push pull up on the face? The whole point seems to be to find Point 'B'. (diagram THAT clause πŸ˜› )
                    Maybe this is beyond my maths. True: the center cut line in the first picture does describe the center of the final board, call it point 'X'. B is a right angle from 'X' but it's a right angle from the board's diagonal, not from the final axis of the board. Still it lies on the edge of the board a distance d/2 from point X?brace - 1.png
                    • gillesG
                      gilles
                      Good try but... πŸ’š
                        Pilou's version appears to work...
                        But when I reproduce it there's inaccuracy again πŸ˜•
                        Logic [initially] says that offsetting [pushpulling] a face that is coplanar with the known diagonal by width/2 and then adding the new sloping lines through the points ought to make them along the rail's raking edges ???
                        BUT the offset is perpendicular to the diagonal NOT the rails sides !
                        Hence the errors... very much like all other approximation methods πŸ˜•
                        • pbacotP
                          TIG,
                          To me the problem is that d/2 should be measured perpendicular to the final edge, not the diagonal.
                          Peter
                            @pbacot said:
                            TIG,
                            Peter
                            Exactly right - I was adding that to my last post as you posted...
                            The difference between offsetting the diagonal and the sides is the error. πŸ˜’
                            • andybotA
                              andybot
                              @pbacot said:
                              Gilles,
                              Peter
                              Indeed - components interacting with each other during manipulation has always been baffling to me. Some things work and some don't (for example try to move a line in a mirrored component so that it's on the mirror plane - it won't snap to the other side, it'll just keep going past the mirror plane)
                                I have yet another 'drawn' solution...
                                I can't fault it... but then again... you might... πŸ˜’
                                RakingRailDrawnSolution999.skp
                                • bmikeB
                                  bmike
                                  @tig said:
                                  I have yet another drawn solution... I can't fault it but then again... πŸ˜’
                                  that appears to work... instead of copying the line up by the thickness of the brace, i +rotated about the center of the original line 180d. then traced over everything to get my shape.
                                  except, when i use the tape, with 0.000000 accuracy, i get 5.995197, instead of what should be 6" in my example.
                                  copying the bottom line up 6" (2x the measurement i used for 1/2w) should yield better results, but then i'd guess that the top or bottom would be off. or the rotate tool is inherently inaccurate.
                                  • gillesG
                                    gilles
                                    I Have no idea how you figured that out One snaps to a line that is not there until the execution. That's wild!
                                    The line was not here but exist so you can interact with, I use this technic frequently.
                                      A slight variation on TIG's
                                      http://www.screenr.com/7VC8
                                        Move+Ctrl to copy the bottom long-side lines up to 'T' [as there are two lines, split by the width/2 perpendicular line...] moved up to the top of the right-hand post [T]...
                                          Another working solution [I think!]... but it uses a script 😞
                                            A script that should be a default tool πŸ‘
                                            If only Google accepted sketchUcation's offer to buy Sketchp that time πŸ˜’
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
