    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • P
      Pherim
      I know this is still beta but I think the included features are supposed to work in the current version (sorry if I am wrong). However, the option to generate the junction edges of the skinning tool does not work for me. It only generates the first one and then does nothing any more, although the cursor still shows the hourglass symbol. Generating intermediate edges works fine, however. Can you confirm this problem? And if yes, when will this be fixed?
      • jeff hammondJ
        this feature Does work for me.. can you post the .skp you're having problems with?
        • P
          Pherim
          What I didn't mention is that I want to use it for a flat surface. With contours that would generate a bent surface it works for me, too. But I would like to use it to divide a flat surface in many small faces that match the contours. In the preview it looks just the way I want it but when trying to generate it doesn't work.
            As Jeff asked, post the SKP file where it doesn't work.
            • jgbJ
              jgb
              In my experience, CL does not handle perfectly flat surfaces very well. It will surface a "flat" plane if at least 1 vertex is at least .001 in out of planar, and may not show diagonal line(s), up to a point.
              The latest version is much better, πŸ‘ but the older versions resulted in an empty group when surfacing a very flat perimeter.
              As far as dividing the surface into some sort of mesh, that would be a hit/or/miss depending on how "flat" the perimeter is.
              jgb
              • P
                Pherim
                I'm sorry I was in a hurry when I wrote my last reply and I was unable to look into the forums for the last few days. I have attached a sample file with explaining notes. However, this appears to happen with every flat surface, at least the ones I tried.
                Problem with Curviloft Skinning
                  I fail to see why you need to use this tool to do this...
                  If you select one or more edges in the coplanar set... and run one of the several 'add-faces' tools available... it faces almost instantly...Capture.PNG If you want to 'mesh' the 'flat' one face then my ExtrudeEdgesByRails will do it thus.Capture1.PNGNo smoothing etc to show messy mesh because of uneven vertices distribution in the two original wavy curves...
                  • P
                    Pherim
                    Yes I tried to do what your ExtrudeEdgesByRails appears to do. Will try it in a minute! I realize that the edges are not perfect for that purpose, but it's just an example file.
                    edit: It works. Thank you!
                    • jeff hammondJ
                      [attachment=0:xnznwx1c]<!-- ia0 -->Skin_test.skp<!-- ia0 -->[/attachment:xnznwx1c]
                      a workaround you can do at this time is:
                      select the edges / choose curviLoft 'skinning of shapes'
                      under Geometry in curviloft, click 'Generate the Junctions as SU Curves' (the last icon in geometry)
                      this will give you the lines you're seeking, albeit they are softened..
                      (for purposes of this example, explode the curviloft generated group at this time)
                      select everything then right-click -> Soften/Smooth edges
                      set the slider to zero which will unhide the lines..
                      switch to wireframe mode then select all the lines and copy/move them to a new location..
                      switch back to a shaded mode and only your curves/junction edges will in the copied set of geometry..
                      (and maybe the way i described it there sounds worse than doing it in reality.. πŸ˜„ .. it's pretty quick/painless )
                      • P
                        Pherim
                        Thank you, that worked!
                        • brookefoxB
                          brookefox
                          Just a quick note of thanks to Fredo. Here's a pic of a modest result which well pleases me.
                          Merci, monsieur.
                          ~ Brooke
                          • brookefoxB
                            brookefox
                            The pic shows two arc profiles desired to be swept along an arc path in red. Though the two profiles are separate curves, 'loft along path' makes them one when picked. One should be a beginning transitioning to the other as an ending.
                            ~ Brooke
                            • fredo6F
                              It depends on the edge selection you choose (follow or curve) and also you need to click in the empty space to force the separation of the 2 contours since they are contiguous
                              • brookefoxB
                                brookefox
                                I guess there is no way as even if the two arcs are perpendicular to each other it treats them as one.
                                ~ Brooke
                                • brookefoxB
                                  brookefox
                                  I got the profiles distinguished as you said, but have had no success with the sweep, no matter the settings. But it is a complex tool and I do not have a solid grasp of the variables, to say the least. Merci, Fredo.
                                  ~ Brooke
                                  • brookefoxB
                                    brookefox
                                    It depends on the edge selection you choose (follow or curve) and also you need to click in the empty space to force the separation of the 2 contours since they are contiguous.
                                    OK, I thought I had tried that. I will now for sure. Thank you. For me a work around is to make it in two moves with 'skinning'. Pic shows the desired and thusly achieved results.
                                    ~ Brooke
                                    • brookefoxB
                                      brookefox
                                      Cross post from elsewhere to here, where it may be of some use...model here with Fredo's Curviloft tools and TIG's Extrusion Tools.
                                      ~ Brooke
                                        artcrazy1313
                                        Hi Guys
                                        I am new in this scetchup world and I need some help.
                                        I am trying to download .rb in my scetchup8. I do everything it was asked and put in scetchup plugin foldr but for some reason nothing comes out.. Please have someone help me out.
                                        I am also tring to download this .rb for round corners , but cand find a link for download.
                                          @artcrazy1313 said:
                                          Hi Guys
                                          The download link is almost always on the first post in any tools thread [it also has '[Plugin]' at the start of the thread's title]. The Plugins Idex red-button takes you to a page that in turn links off to all plugins available here, and a few elsewhere too...
                                          Be sure to read the tool's download page - sometimes you need to get and install a help file or a library of helpers [like this tool] that are kept in their own subfolder.
                                          Be sure to follow the tool's instructions for download, extraction and placement in the Plugins folder.
                                          If the tool comes in a zip file ensure that the 'loose' files go into the Plugins folder and that any helper files zipped inside a subfolder are put into Plugins still INSIDE that subfolder - never move files around as the tool will break.
                                          You are on a MAC so ensure you are using the right root-level 'HD' library Plugins folder and NOT a 'user' one...
                                          There are several helpful threads about installing scripts/plugins - do a forum Search.
                                          Thomthom has also made a 'Simple Installer' tool [>=v8M2 only] that will automatically install scripts and extract/install from archives of scripts - look for that in the Plugins Index...
                                          Note that some tools [like this one] are Extensions that need activating [one-time-only] from the Window > Preferences dialog, then the tool's Toolbar probably needs activating from the View...menu item...
                                          Note also how each tool is activated/used...
                                          Many new tools do appear in the Plugins-menu... BUT many do not - for example the menu items for this very tool are found in Tools > Fredo Collection > CurviLoft submenu !!!
                                          • bazB
                                            baz
                                            Off topic.
                                            Tig, you are so patient and helpful. I saw this post and my first thought was has he tried 'search', has he looked at the 'how to download plugins' tut, has he made any effort at all? Or is he a first poster who needs some direction about how to help him/her self
                                            I guess what I'm trying to say is that you and others on this forum contribute so much, I worry that you get overloaded with things that don't really help to progress SU.
                                            Your call though, I'm inclined to 'tough love' myself.
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 65
                                            • 66
                                            • 35 / 66
