    [Plugin] Honeycomber
    91 Posts 21 Posters 63.1k Views 21 Watching
      Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=395061#p395061
      It now has a 3 sided option making equilateral perforations, which assemble into hexagons etc thus
        SUFractal
        TIG:
        Just downloaded the new version (w/ 3-sided option). Same issues as before. Tool appears to begin working, TIG::Honeycomber: Perforating appears in status bar ......... appears, then spinning wheel of death appears and refuses to go away.
          Be patient !
          How many perforations are you making ?
          If there are many hundreds it will take a looong time !
          Try it with a small number and see if it works then.
          If, before running the tool, you open the Ruby Console do you get any error messages in it ?
          Works fine for me and many others...
          You do have SUp v8M2 ?
          Must be something you are doing ??
            SUFractal
            @tig said:
            Be patient !
            TIG:
            No error message in ruby console prior to tool. Running current version (you reminded me to upgrade remember?) of SU. Trying default setting that pops up. 30+ minutes later and the spinning wheel of death remains. Am I doing anything wrong?
            BTW ... the previous version (w/o the 3-sided option) seems to work fine.
              Try with a 4" cube it'd take a fraction of the time! [with ~125+ perforations, each with 8 faces etc]
              I replicated your 8" cube on my PC and it eventually made it in ~150 minutes 😲 .
              There are ~729+ perforations, each with 8 faces etc... It all adds up...
              So it is not just 10x slower, because the more entities you add to a context the slower Sketchup runs disproportionately... each extra step adds exponentially, time-wise.
              I think you don't need so many holes ???
              If you open Task Manager when running a looooong process you will see that Sketchup is still working.
              It's just taking a-g-e-s to process all of the needed geometry...
              In passing... please adjust your default Template's, Model Info > Units to show some decimal inches !
                SUFractal
                This one took ~2 minutes.[attachment=0:97y792mn]<!-- ia0 -->Capture4.PNG<!-- ia0 -->[/attachment:97y792mn]
                4" cube with simple perforation offers no change in operation.
                I'll continue to work in the units I need, thanks.
                • guanjinG
                  guanjin
                  Complex point of the porous,the generation process is very slow.
                    Guanjin
                    The more geometry there is the slower the processing.
                    It's inevitable. 😕
                    Set it running and make some tea...
                    • guanjinG
                      guanjin
                      @tig said:
                      Guanjin
                      It's inevitable. 😕
                      Set it running an make some tea...
                      Thank you of TIG: you have worked hard, so many good tools for free use, you are great! 👍 👍
                      • EscapeArtistE
                        EscapeArtist
                        Awesome plugin. I have enjoyed using it so far, just experimenting.
                        I have noticed it will hang if I breathe wrong when applying a large number of perforations. I can't tab to another program, it will simply lock SU up.
                        An idea - would it be possible to add a "random" or mathematical feature to the spacing and size? I.e., between 1" to 1'? Add a rotation feature, i.e. each new unit rotates 10 degrees "X", 5 "Y" and 12 "Z" (all 3 axis?), and finally to use one's own model as the subtracted shape?
                        I realize this may be completely prohibitive by SU's single core use and the added complexity of any intersections, but just a thought. One could come up with almost fractal-like iterations in a medium with these options.
                          It's almost certainly not 'hanging'.
                          It just takes ages to process and left to its own devices it will complete [eventually!]
                          Use the Task Manager to see that Sketchup is still processing away, although the screen has a 'white-out' - it's one of the quirks of SUp, when it's doing intensive calculations it looses the screen...
                          It does take a while to make all of the changes to the geometry - have patience...
                          I do have some recoding ideas to speed it up [a little], but testing takes time too...
                          • I
                            ideas_arte
                            @tig said:
                            It is for v8-Pro only.
                            😳 "Free" users will have any chance of using this excellent tool?
                            Best regards!
                              v8-Pro only because it uses several API techniques only accessible to Pro - sorry...
                                Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=395061#p395061
                                The speed has been improved by ~4x.
                                The 'shell' version still takes ~4x longer than an un-shelled version because of the many extra steps required - but while ~15 minutes is worse that ~4minutes, it is better than ~60 minutes !!
                                Some minor glitches have also been fixed with 3-sided setting out centrally.
                                • I
                                  ideas_arte
                                  @tig said:
                                  sorry...
                                  I understand. 😒 Thank you for all the good work. My best wishes for you
                                  • guanjinG
                                    guanjin
                                    Thank of TIG: Speed ​​is the key, to test the new file。
                                      dtolios
                                      Amazing work, great potential for this tool...
                                      Unfortunately is too slow for some of the complex shapes I had in mind, but I have trust that it will get better overtime (and yeah, my mobile i7 is not the fastest processor anyways...)
                                      • charly2008C
                                        charly2008
                                        TIG, you have once again created a surprising and promising tool. Thank you.
                                          SUFractal
                                          I'm curious as to how long it took you to create this?
                                            I reproduced it [badly!]
                                            • 4 / 5
