    [Plugin] Honeycomber
    91 Posts 21 Posters 58.4k Views 21 Watching
      @sufractal said:
      (Why didn't I think of something so simple as that? 😳 )
      As a general rule of thumb: When you have a software issue, first ensure you have the latest version. Your issue might very well be fixed already. And for 3D related applications, also check your graphic card driver.
        Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=395061#p395061
        It now has a 3 sided option making equilateral perforations, which assemble into hexagons etc thus
          SUFractal
          TIG:
          Just downloaded the new version (w/ 3-sided option). Same issues as before. Tool appears to begin working, TIG::Honeycomber: Perforating appears in status bar ......... appears, then spinning wheel of death appears and refuses to go away.
            Be patient !
            How many perforations are you making ?
            If there are many hundreds it will take a looong time !
            Try it with a small number and see if it works then.
            If, before running the tool, you open the Ruby Console do you get any error messages in it ?
            Works fine for me and many others...
            You do have SUp v8M2 ?
            Must be something you are doing ??
              SUFractal
              @tig said:
              Be patient !
              TIG:
              No error message in ruby console prior to tool. Running current version (you reminded me to upgrade remember?) of SU. Trying default setting that pops up. 30+ minutes later and the spinning wheel of death remains. Am I doing anything wrong?
              BTW ... the previous version (w/o the 3-sided option) seems to work fine.
                Try with a 4" cube it'd take a fraction of the time! [with ~125+ perforations, each with 8 faces etc]
                I replicated your 8" cube on my PC and it eventually made it in ~150 minutes 😲 .
                There are ~729+ perforations, each with 8 faces etc... It all adds up...
                So it is not just 10x slower, because the more entities you add to a context the slower Sketchup runs disproportionately... each extra step adds exponentially, time-wise.
                I think you don't need so many holes ???
                If you open Task Manager when running a looooong process you will see that Sketchup is still working.
                It's just taking a-g-e-s to process all of the needed geometry...
                In passing... please adjust your default Template's, Model Info > Units to show some decimal inches !
                  SUFractal
                  This one took ~2 minutes.[attachment=0:97y792mn]<!-- ia0 -->Capture4.PNG<!-- ia0 -->[/attachment:97y792mn]
                  4" cube with simple perforation offers no change in operation.
                  I'll continue to work in the units I need, thanks.
                  • guanjinG Offline
                    guanjin
                    Complex point of the porous,the generation process is very slow.
                      Guanjin
                      The more geometry there is the slower the processing.
                      It's inevitable. 😕
                      Set it running and make some tea...
                      • guanjinG Offline
                        guanjin
                        @tig said:
                        Guanjin
                        It's inevitable. 😕
                        Set it running an make some tea...
                        Thank you of TIG: you have worked hard, so many good tools for free use, you are great! 👍 👍
                        • EscapeArtistE Offline
                          EscapeArtist
                          Awesome plugin. I have enjoyed using it so far, just experimenting.
                          I have noticed it will hang if I breathe wrong when applying a large number of perforations. I can't tab to another program, it will simply lock SU up.
                          An idea - would it be possible to add a "random" or mathematical feature to the spacing and size? I.e., between 1" to 1'? Add a rotation feature, i.e. each new unit rotates 10 degrees "X", 5 "Y" and 12 "Z" (all 3 axis?), and finally to use one's own model as the subtracted shape?
                          I realize this may be completely prohibitive by SU's single core use and the added complexity of any intersections, but just a thought. One could come up with almost fractal-like iterations in a medium with these options.
                            It's almost certainly not 'hanging'.
                            It just takes ages to process and left to its own devices it will complete [eventually!]
                            Use the Task Manager to see that Sketchup is still processing away, although the screen has a 'white-out' - it's one of the quirks of SUp, when it's doing intensive calculations it looses the screen...
                            It does take a while to make all of the changes to the geometry - have patience...
                            I do have some recoding ideas to speed it up [a little], but testing takes time too...
                            • I Offline
                              ideas_arte
                              @tig said:
                              It is for v8-Pro only.
                              😳 "Free" users will have any chance of using this excellent tool?
                              Best regards!
                                v8-Pro only because it uses several API techniques only accessible to Pro - sorry...
                                  Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=395061#p395061
                                  The speed has been improved by ~4x.
                                  The 'shell' version still takes ~4x longer than an un-shelled version because of the many extra steps required - but while ~15 minutes is worse that ~4minutes, it is better than ~60 minutes !!
                                  Some minor glitches have also been fixed with 3-sided setting out centrally.
                                  • I Offline
                                    ideas_arte
                                    @tig said:
                                    sorry...
                                    I understand. 😒 Thank you for all the good work. My best wishes for you
                                    • guanjinG Offline
                                      guanjin
                                      Thank of TIG: Speed ​​is the key, to test the new file。
                                        dtolios
                                        Amazing work, great potential for this tool...
                                        Unfortunately is too slow for some of the complex shapes I had in mind, but I have trust that it will get better overtime (and yeah, my mobile i7 is not the fastest processor anyways...)
                                        • charly2008C Offline
                                          charly2008
                                          TIG, you have once again created a surprising and promising tool. Thank you.
                                            SUFractal
                                            I'm curious as to how long it took you to create this?
                                            • 4 / 5
