    [Plugin] Three Line Tools (Updated March 9th, 2009)
    117 Posts 43 Posters 76.4k Views 43 Watching
    • JClementsJ Offline
      JClements
      Thanks Chris, for considering this. You've done so much already.
      It sure would save me a lot of time from manually subtracting elevation valves to determine vertical pipe lengths or the placement of their horizontal centerlines (many elevations in the drawings I get are specified to the tenth or hundredth of a foot as pipe slopes are critical to gravity feed flow ... yikes).
      • romboutR Offline
        rombout
        what are all these plugins ??? never saw them before
        • Chris FullmerC Offline
          I think that is a toolbar full of various plugins and with new icons. So they might be plugins you already have, just different icons. I'm not sure if they are still available as a group like that. But you can download them all separately.
            markozeta
            Chris,
            Can you also make the normal tool work so if a single edge is selected (without a face), it'll draw a line perpendicular to that line? And then you'd just choose the rotation of that perpendicular line?
            Or something like that?
            Or would that have to be a fourth line tool?
            Mark
            BSME - Cal Poly Pomona
            Sketchup Pipe Maniac
              It would be tricky to figure out how to reliably set the rotation.
              But I keep wanting the tool to work when its clicked on a vertex of 2 or more lines that do not necessarily make a face (like on an arc). I would be interested in exploring more possibilities like these with this tool.
                c.plassais
                Hi Chris,
                a new translation, that of de Three Line Tools
                Thanks for link repaired
                The link for your translate plugin http://biblio3d.1fr1.net/plug-in-sketchup-f19/plugin-three-tools-line-en-francais-utilitaire-de-tracage-de-lignes-t451.htm
                At next time
                Christophe
                • H Offline
                  hamster3
                  Very useful plugin.
                  Thanks Chris!
                  • E Offline
                    ElCarlos
                    Does this work on v 8 with Mac OS?
                    • EdsonE Offline
                      Edson
                      yes, it does.
                      http://www.mahfuz.arq.br
                      • O Offline
                        oisin.higgins
                        Hi Chris,
                        Would it be possible to modify the code for 2-D use? ie to bisect and angle?
                          shawnkelly
                          This does not seem to work in V2013 pro. I was able to activate the toolbar and even interact with it, as well as enter a value but no line appears when a position for one is clicked on a model. Thought you would like to know.
                          Take care.
                            There is no difference in the API between SU8 and SU2013 - it should be working. If you open the Ruby Console (under the Windows menu) when you use the plugin, are there any errors?
                            • cottyC Offline
                              cotty
                              I've got this error...
                              my SketchUp gallery
                                johnnygitarr
                                hi there,
                                same for me!
                                three lines tool used with sketchup pro v2013 (mac) doesn't work.
                                i installed the plugin via sketchucation plugin store.
                                can someone helo?
                                • gillesG Offline
                                  gilles
                                  Same thing with the 3 tools:
                                  Error; #<NoMethodError; undefined method `GetString' for nil;NilClass>
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;102;in `onLButtonUp'
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;286
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;182;in `onLButtonUp'
                                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;286;in `onLButtonUp'
                                    bjornkn
                                    Any news on this problem with it not working in SU 2013 (and probably 2014 too?) ?
                                    It is a really useful plugin, which I'm really missing..
                                      I just installed it and it works just fine for me on SU2014. Did you try getting the current version via the Extension Warehouse?
                                        bjornkn
                                        I re-installed using the rbz file, which caused no lines to be drawn.
                                        When installing via Extension warehouse it works fine in both 2013 and 2014 - to my big surprise.
                                        Would that be a newer version than the one available here for download then?
                                          Yes. It is a newer version. In fact I would expect all of Chris Fullmer's plugins to be newer in the Extension Warehouse. You can see that the version uploaded here is 2.1 while the version in the EW is 2.2.
                                            bjornkn
                                            I guess one shouldn't complain when you get such great tools for free, but it is a bit confusing when there are different versions around. I have used the Extension warehouse very little, as it seems to often be the other way around; the old version on EW and the newer one posted here. ?
                                            • 2 / 6
