    [Plugin] Three Line Tools (Updated March 9th, 2009)
    117 Posts 43 Posters 88.5k Views 43 Watching
    • DoodlerD
      Doodler
      Hi Chris, I'm new to this forum. Thanks for the great plugin. I wanted to try something different today and I came across this plugin. I've had fun with it, just playing around. I also wanted to say the tutorial is good too. Not only does it show me how to use the tool, I could actually see what you were doing, the video was clear and your explanation was to the point. β˜€
      • Chris FullmerC
        I don't quite get it. Seems like the tool should do that already. Do you have a quick drawing to show better what you mean? I think I don't understand how you're using (or wanting to use) line tools in your workflow.
        • JClementsJ
          JClements
          You answered too quickly ... I updated my previous posting. The more I think about it, the lines tools wouldn't.
          I think what would be needed is a way somehow set the origin Z value to a specific base elevation (like a site's ground level or slab level of a building), and then somehow have your line tool reconize this and draw up from that value to a specified elevation or distance.
          • JClementsJ
            JClements
            Hi Chris:
            Could you add one that draws lines UP FROM an elevation to a specified elevation.
            I'm often given scan of old section drawings for piping which only give the elevations of their centerlines and joints.
            • Chris FullmerC
              Ahh yes, I think the ability to set a base z height was requested before too. It could be done. I won't get to it soon though I'm afraid. But when I get around to updating scripts, that could go on my list of features to add. Thanks for the great suggestion John!
              • JClementsJ
                JClements
                Thanks Chris, for considering this. You've done so much already.
                It sure would save me a lot of time from manually subtracting elevation valves to determine vertical pipe lengths or the placement of their horizontal centerlines (many elevations in the drawings I get are specified to the tenth or hundredth of a foot as pipe slopes are critical to gravity feed flow ... yikes).
                • romboutR
                  rombout
                  what are all these plugins ??? never saw them before
                  • Chris FullmerC
                    I think that is a toolbar full of various plugins and with new icons. So they might be plugins you already have, just different icons. I'm not sure if they are still available as a group like that. But you can download them all separately.
                      markozeta
                      Chris,
                      Can you also make the normal tool work so if a single edge is selected (without a face), it'll draw a line perpendicular to that line? And then you'd just choose the rotation of that perpendicular line?
                      Or something like that?
                      Or would that have to be a fourth line tool?
                      Mark
                      BSME - Cal Poly Pomona
                      Sketchup Pipe Maniac
                      • Chris FullmerC
                        It would be tricky to figure out how to reliably set the rotation.
                        But I keep wanting the tool to work when its clicked on a vertex of 2 or more lines that do not necessarily make a face (like on an arc). I would be interested in exploring more possibilities like these with this tool.
                        • C
                          c.plassais
                          Hi Chris,
                          a new translation, that of de Three Line Tools
                          Thanks for link repaired
                          The link for your translate plugin http://biblio3d.1fr1.net/plug-in-sketchup-f19/plugin-three-tools-line-en-francais-utilitaire-de-tracage-de-lignes-t451.htm
                          At next time
                          Christophe
                          • H
                            hamster3
                            Very useful plugin.
                            Thanks Chris!
                            • E
                              ElCarlos
                              Does this work on v 8 with Mac OS?
                              • EdsonE
                                Edson
                                yes, it does.
                                http://www.mahfuz.arq.br
                                • O
                                  oisin.higgins
                                  Hi Chris,
                                  Would it be possible to modify the code for 2-D use? ie to bisect and angle?
                                    shawnkelly
                                    This does not seem to work in V2013 pro. I was able to activate the toolbar and even interact with it, as well as enter a value but no line appears when a position for one is clicked on a model. Thought you would like to know.
                                    Take care.
                                      There is no difference in the API between SU8 and SU2013 - it should be working. If you open the Ruby Console (under the Windows menu) when you use the plugin, are there any errors?
                                      • cottyC
                                        cotty
                                        I've got this error...
                                        my SketchUp gallery
                                          johnnygitarr
                                          hi there,
                                          same for me!
                                          three lines tool used with sketchup pro v2013 (mac) doesn't work.
                                          i installed the plugin via sketchucation plugin store.
                                          can someone helo?
                                          • gillesG
                                            gilles
                                            Same thing with the 3 tools:
                                            Error; #<NoMethodError; undefined method `GetString' for nil;NilClass>
                                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;102;in `onLButtonUp'
                                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;286
                                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;182;in `onLButtonUp'
                                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;286;in `onLButtonUp'
                                            • 5 / 6
