    [Plugin] Three Line Tools (Updated March 9th, 2009)
    117 Posts 43 Posters 82.6k Views 43 Watching
      publied
      very interesting tool! many congrats (and thank you).
      hire me@ http://www.publied.it !
      • Chris FullmerC Offline
        @Plot, I'm thinking about it. Some of that functionality fits right in with some of Frenchy's wishes too. I just haven't had time to do it yet. If I get more time to work on this one again, those are good ideas.
        • DoodlerD Offline
          Doodler
          Hi Chris, I'm new to this forum. Thanks for the great plugin. I wanted to try something different today and I came across this plugin. I've had fun with it, just playing around. I also wanted to say the tutorial is good too. Not only does it show me how to use the tool, I could actually see what you were doing, the video was clear and your explanation was to the point. β˜€
            I don't quite get it. Seems like the tool should do that already. Do you have a quick drawing to show better what you mean? I think I don't understand how you're using (or wanting to use) line tools in your workflow.
            • JClementsJ Offline
              JClements
              You answered too quickly ... I updated my previous posting. The more I think about it, the lines tools wouldn't.
              I think what would be needed is a way somehow set the origin Z value to a specific base elevation (like a site's ground level or slab level of a building), and then somehow have your line tool reconize this and draw up from that value to a specified elevation or distance.
                JClements
                Hi Chris:
                Could you add one that draws lines UP FROM an elevation to a specified elevation.
                I'm often given scan of old section drawings for piping which only give the elevations of their centerlines and joints.
                  Ahh yes, I think the ability to set a base z height was requested before too. It could be done. I won't get to it soon though I'm afraid. But when I get around to updating scripts, that could go on my list of features to add. Thanks for the great suggestion John!
                    JClements
                    Thanks Chris, for considering this. You've done so much already.
                    It sure would save me a lot of time from manually subtracting elevation valves to determine vertical pipe lengths or the placement of their horizontal centerlines (many elevations in the drawings I get are specified to the tenth or hundredth of a foot as pipe slopes are critical to gravity feed flow ... yikes).
                    • romboutR Offline
                      rombout
                      what are all these plugins ??? never saw them before
                        I think that is a toolbar full of various plugins and with new icons. So they might be plugins you already have, just different icons. I'm not sure if they are still available as a group like that. But you can download them all separately.
                          markozeta
                          Chris,
                          Can you also make the normal tool work so if a single edge is selected (without a face), it'll draw a line perpendicular to that line? And then you'd just choose the rotation of that perpendicular line?
                          Or something like that?
                          Or would that have to be a fourth line tool?
                          Mark
                          BSME - Cal Poly Pomona
                          Sketchup Pipe Maniac
                            It would be tricky to figure out how to reliably set the rotation.
                            But I keep wanting the tool to work when its clicked on a vertex of 2 or more lines that do not necessarily make a face (like on an arc). I would be interested in exploring more possibilities like these with this tool.
                              c.plassais
                              Hi Chris,
                              a new translation, that of de Three Line Tools
                              Thanks for link repaired
                              The link for your translate plugin http://biblio3d.1fr1.net/plug-in-sketchup-f19/plugin-three-tools-line-en-francais-utilitaire-de-tracage-de-lignes-t451.htm
                              At next time
                              Christophe
                              • H Offline
                                hamster3
                                Very useful plugin.
                                Thanks Chris!
                                • E Offline
                                  ElCarlos
                                  Does this work on v 8 with Mac OS?
                                  • EdsonE Offline
                                    Edson
                                    yes, it does.
                                    http://www.mahfuz.arq.br
                                    • O Offline
                                      oisin.higgins
                                      Hi Chris,
                                      Would it be possible to modify the code for 2-D use? ie to bisect and angle?
                                        shawnkelly
                                        This does not seem to work in V2013 pro. I was able to activate the toolbar and even interact with it, as well as enter a value but no line appears when a position for one is clicked on a model. Thought you would like to know.
                                        Take care.
                                          There is no difference in the API between SU8 and SU2013 - it should be working. If you open the Ruby Console (under the Windows menu) when you use the plugin, are there any errors?
                                          • cottyC Offline
                                            cotty
                                            I've got this error...
                                            my SketchUp gallery
                                            • 5 / 6
