    [Plugin] Three Line Tools (Updated March 9th, 2009)
    117 Posts 43 Posters 86.4k Views 43 Watching
    • JClementsJ Offline
      JClements
      You answered too quickly ... I updated my previous posting. The more I think about it, the lines tools wouldn't.
      I think what would be needed is a way somehow set the origin Z value to a specific base elevation (like a site's ground level or slab level of a building), and then somehow have your line tool reconize this and draw up from that value to a specified elevation or distance.
        JClements
        Hi Chris:
        Could you add one that draws lines UP FROM an elevation to a specified elevation.
        I'm often given scan of old section drawings for piping which only give the elevations of their centerlines and joints.
        • Chris FullmerC Offline
          Ahh yes, I think the ability to set a base z height was requested before too. It could be done. I won't get to it soon though I'm afraid. But when I get around to updating scripts, that could go on my list of features to add. Thanks for the great suggestion John!
            JClements
            Thanks Chris, for considering this. You've done so much already.
            It sure would save me a lot of time from manually subtracting elevation valves to determine vertical pipe lengths or the placement of their horizontal centerlines (many elevations in the drawings I get are specified to the tenth or hundredth of a foot as pipe slopes are critical to gravity feed flow ... yikes).
            • romboutR Offline
              rombout
              what are all these plugins ??? never saw them before
                I think that is a toolbar full of various plugins and with new icons. So they might be plugins you already have, just different icons. I'm not sure if they are still available as a group like that. But you can download them all separately.
                  markozeta
                  Chris,
                  Can you also make the normal tool work so if a single edge is selected (without a face), it'll draw a line perpendicular to that line? And then you'd just choose the rotation of that perpendicular line?
                  Or something like that?
                  Or would that have to be a fourth line tool?
                  Mark
                  BSME - Cal Poly Pomona
                  Sketchup Pipe Maniac
                    It would be tricky to figure out how to reliably set the rotation.
                    But I keep wanting the tool to work when its clicked on a vertex of 2 or more lines that do not necessarily make a face (like on an arc). I would be interested in exploring more possibilities like these with this tool.
                      c.plassais
                      Hi Chris,
                      a new translation, that of de Three Line Tools
                      Thanks for link repaired
                      The link for your translate plugin http://biblio3d.1fr1.net/plug-in-sketchup-f19/plugin-three-tools-line-en-francais-utilitaire-de-tracage-de-lignes-t451.htm
                      At next time
                      Christophe
                      • H Offline
                        hamster3
                        Very useful plugin.
                        Thanks Chris!
                        • E Offline
                          ElCarlos
                          Does this work on v 8 with Mac OS?
                          • EdsonE Offline
                            Edson
                            yes, it does.
                            http://www.mahfuz.arq.br
                            • O Offline
                              oisin.higgins
                              Hi Chris,
                              Would it be possible to modify the code for 2-D use? ie to bisect and angle?
                                shawnkelly
                                This does not seem to work in V2013 pro. I was able to activate the toolbar and even interact with it, as well as enter a value but no line appears when a position for one is clicked on a model. Thought you would like to know.
                                Take care.
                                  There is no difference in the API between SU8 and SU2013 - it should be working. If you open the Ruby Console (under the Windows menu) when you use the plugin, are there any errors?
                                  • cottyC Offline
                                    cotty
                                    I've got this error...
                                    my SketchUp gallery
                                      johnnygitarr
                                      hi there,
                                      same for me!
                                      three lines tool used with sketchup pro v2013 (mac) doesn't work.
                                      i installed the plugin via sketchucation plugin store.
                                      can someone helo?
                                      • gillesG Offline
                                        gilles
                                        Same thing with the 3 tools:
                                        Error; #<NoMethodError; undefined method `GetString' for nil;NilClass>
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;102;in `onLButtonUp'
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;286
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;182;in `onLButtonUp'
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;286;in `onLButtonUp'
                                          bjornkn
                                          Any news on this problem with it not working in SU 2013 (and probably 2014 too?) ?
                                          It is a really useful plugin, which I'm really missing..
                                            I just installed it and it works just fine for me on SU2014. Did you try getting the current version via the Extension Warehouse?
                                            • 5 / 6
