    [Plugin] Three Line Tools (Updated March 9th, 2009)
    117 Posts 43 Posters 79.6k Views 43 Watching
    • Chris FullmerC Offline
      Ahh yes, I think the ability to set a base z height was requested before too. It could be done. I won't get to it soon though I'm afraid. But when I get around to updating scripts, that could go on my list of features to add. Thanks for the great suggestion John!
      • JClementsJ Offline
        JClements
        Thanks Chris, for considering this. You've done so much already.
        It sure would save me a lot of time from manually subtracting elevation valves to determine vertical pipe lengths or the placement of their horizontal centerlines (many elevations in the drawings I get are specified to the tenth or hundredth of a foot as pipe slopes are critical to gravity feed flow ... yikes).
        • romboutR Offline
          rombout
          what are all these plugins ??? never saw them before
            I think that is a toolbar full of various plugins and with new icons. So they might be plugins you already have, just different icons. I'm not sure if they are still available as a group like that. But you can download them all separately.
              markozeta
              Chris,
              Can you also make the normal tool work so if a single edge is selected (without a face), it'll draw a line perpendicular to that line? And then you'd just choose the rotation of that perpendicular line?
              Or something like that?
              Or would that have to be a fourth line tool?
              Mark
              BSME - Cal Poly Pomona
              Sketchup Pipe Maniac
                It would be tricky to figure out how to reliably set the rotation.
                But I keep wanting the tool to work when its clicked on a vertex of 2 or more lines that do not necessarily make a face (like on an arc). I would be interested in exploring more possibilities like these with this tool.
                  c.plassais
                  Hi Chris,
                  a new translation, that of de Three Line Tools
                  Thanks for link repaired
                  The link for your translate plugin http://biblio3d.1fr1.net/plug-in-sketchup-f19/plugin-three-tools-line-en-francais-utilitaire-de-tracage-de-lignes-t451.htm
                  At next time
                  Christophe
                  • H Offline
                    hamster3
                    Very useful plugin.
                    Thanks Chris!
                    • E Offline
                      ElCarlos
                      Does this work on v 8 with Mac OS?
                      • EdsonE Offline
                        Edson
                        yes, it does.
                        http://www.mahfuz.arq.br
                        • O Offline
                          oisin.higgins
                          Hi Chris,
                          Would it be possible to modify the code for 2-D use? ie to bisect and angle?
                            shawnkelly
                            This does not seem to work in V2013 pro. I was able to activate the toolbar and even interact with it, as well as enter a value but no line appears when a position for one is clicked on a model. Thought you would like to know.
                            Take care.
                              There is no difference in the API between SU8 and SU2013 - it should be working. If you open the Ruby Console (under the Windows menu) when you use the plugin, are there any errors?
                              • cottyC Offline
                                cotty
                                I've got this error...
                                my SketchUp gallery
                                  johnnygitarr
                                  hi there,
                                  same for me!
                                  three lines tool used with sketchup pro v2013 (mac) doesn't work.
                                  i installed the plugin via sketchucation plugin store.
                                  can someone helo?
                                  • gillesG Offline
                                    gilles
                                    Same thing with the 3 tools:
                                    Error; #<NoMethodError; undefined method `GetString' for nil;NilClass>
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;102;in `onLButtonUp'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;286
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;182;in `onLButtonUp'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;286;in `onLButtonUp'
                                      bjornkn
                                      Any news on this problem with it not working in SU 2013 (and probably 2014 too?) ?
                                      It is a really useful plugin, which I'm really missing..
                                        I just installed it and it works just fine for me on SU2014. Did you try getting the current version via the Extension Warehouse?
                                          bjornkn
                                          I re-installed using the rbz file, which caused no lines to be drawn.
                                          When installing via Extension warehouse it works fine in both 2013 and 2014 - to my big surprise.
                                          Would that be a newer version than the one available here for download then?
                                            Yes. It is a newer version. In fact I would expect all of Chris Fullmer's plugins to be newer in the Extension Warehouse. You can see that the version uploaded here is 2.1 while the version in the EW is 2.2.
                                            • 6 / 6
