    [Plugin] Three Line Tools (Updated March 9th, 2009)
    117 Posts 43 Posters 86.8k Views 43 Watching
    • EdsonE Offline
      Edson
      @elcarlos said:
      Does this work on v 8 with Mac OS?
      yes, it does.
      http://www.mahfuz.arq.br
      • O Offline
        oisin.higgins
        Hi Chris,
        Would it be possible to modify the code for 2-D use? ie to bisect and angle?
          shawnkelly
          This does not seem to work in V2013 pro. I was able to activate the toolbar and even interact with it, as well as enter a value but no line appears when a position for one is clicked on a model. Thought you would like to know.
          Take care.
            There is no difference in the API between SU8 and SU2013 - it should be working. If you open the Ruby Console (under the Windows menu) when you use the plugin, are there any errors?
            • cottyC Offline
              cotty
              I've got this error...
              my SketchUp gallery
                johnnygitarr
                hi there,
                same for me!
                three lines tool used with sketchup pro v2013 (mac) doesn't work.
                i installed the plugin via sketchucation plugin store.
                can someone helo?
                • gillesG Offline
                  gilles
                  Same thing with the 3 tools:
                  Error; #<NoMethodError; undefined method `GetString' for nil;NilClass>
                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;102;in `onLButtonUp'
                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;286
                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;182;in `onLButtonUp'
                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_vertical_line_maker/clf_vertical_line_maker.rb;286;in `onLButtonUp'
                    bjornkn
                    Any news on this problem with it not working in SU 2013 (and probably 2014 too?) ?
                    It is a really useful plugin, which I'm really missing..
                      I just installed it and it works just fine for me on SU2014. Did you try getting the current version via the Extension Warehouse?
                        bjornkn
                        I re-installed using the rbz file, which caused no lines to be drawn.
                        When installing via Extension warehouse it works fine in both 2013 and 2014 - to my big surprise.
                        Would that be a newer version than the one available here for download then?
                          Yes. It is a newer version. In fact I would expect all of Chris Fullmer's plugins to be newer in the Extension Warehouse. You can see that the version uploaded here is 2.1 while the version in the EW is 2.2.
                            bjornkn
                            I guess one shouldn't complain when you get such great tools for free, but it is a bit confusing when there are different versions around. I have used the Extension warehouse very little, as it seems to often be the other way around; the old version on EW and the newer one posted here. ?
                              That's strange. The plugins shown in the EW have to go through quality testing by someone to ensure they meet standards before they are made available. Your first stops for plugins should be the Sketchucation Plugin Store and the Extension Warehouse. And both show the date and version number of the latest version of the plugin.
                                bjornkn
                                Well, you know when you try a new tool and it doesn't work like expected right away you tend to shy away from it until the tool starts getting some applause (like now πŸ˜‰ ...
                                • greenskpG Offline
                                  greenskp
                                  Hey guys!
                                  I use 2014 version and found the solution. Thanks for Didier Bur on the following link:
                                  http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=27019#p311954
                                  Open clf_vertical_line_maker.rb with Notepad++ and add the code below at line 46:
                                  require 'LangHandler.rb'
                                  $uStrings = LanguageHandler.new("clf_menu_loader")
                                  Now works like a charm.
                                    @greenskp said:
                                    Hey guys!
                                    Or, if you want to take the easy path, just download and install it automatically through Window>Extension Warehouse. It's called CLF Vertical Line Tools. πŸ˜‰
                                    • 6 / 6
