    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 299.1k Views 135 Watching
      Mini Doh 😳 (due forgotten function) πŸ˜’
      • Alt gives you the possibility to Move a segment escaping at the X Y plan πŸ˜‰
        @broomstick said:
        I've seen this pointed out before, but I just discovered that while orbiting with the middle mouse pressed, if you press the left button, orbit becomes pan.
        !!! 😲 OMF-DUH!!!
          A bit awkward though, as I use my index finger usually to press the middle mouse button, so I need to shift to my middle finger to free up my index for the left mouse button. ...which it was the right button that did that...
            Ditto. I have known this "feature" but could never adapt myself to it.
              That is very curious, because with the medium you can rotate many more the Mouse wheel than with index! 😲
              So more speedy scolling! 😎
              For the simple reason that the Medium is biggest than the index! β˜€
              So the medium is always on the whell, so click it is a formality! πŸ˜„
              Try it! πŸ˜‰
              • jgbJ Offline
                jgb
                Try it! πŸ˜‰
                I have always used my mid finger on the wheel, with index on the left button. I also move my mid to the right button when needed as the ring finger has less control (which is why it is the "ring" finger πŸ˜† ).
                It shouldn't take long to adjust to that finger position.
                And now I know why my "orbiting" suddenly goes into "panning" when my index finger twitches downward sometimes. Now that I know, I can exploit that feature. Thank you Broomstick.
                And Pilou, I fail to see what you mean with Move+Alt. ❓ Could you please explain a bit more?
                jgb
                • Jean LemireJ Offline
                  Jean Lemire
                  Hi Pilou, hi folks.
                  Yes, pressing the ALT key enables Autofold.
                  Just ideas.
                    Is that more clear ? 😳
                    Without Alt Z axis is locked!
                    You can make some prisms or no coplanar faces with Move + Alt! πŸ˜‰
                    The Z axis become free with Move + Alt πŸ˜„
                      And here is the autofold description:
                      http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94865
                        I wish there was an option to make SketchUp Smooth+Soft auto-folded edges.
                        • jeff hammondJ Offline
                          I've been harping on this for years now but I don't think anyone ever tries it.. oh well
                          orbit with a thumb button (if your mouse has one).. not only is it more comfortable, it also gets rid of the double duty zoom/orbit mmb... AND- makes panning with the LMB much easier.
                            Thumb buttons are Copy, Paste ...
                            • jgbJ Offline
                              jgb
                              Read it, tried it and I still don't see any advantage. πŸ˜’
                              If I want to go Z (blue) I press the UP arrow and it seems to do the same as the autofold, but with exact axis control. πŸ‘
                              It seems to me that autofold may hold an advantage if we had true 3D screens, but mine is standard 2D, and I cannot control, with any precision, where my object is moving to.
                              jgb
                                using the arrow key is the same thing.. you're giving sketchup permission to break a plane(s) into multiple planes.. that's what autofolding means (in sketchup speak).. [and moving along the Z isn't always what's wanted.. hence the cmmd/alt key]
                                now if only follow-me had an autofold option.. we'd then be able to, say, extrude around a helix without the twisting.. (notice if you try that now, sketchup prefers to keep planes in tact as opposed to folding them which is required for a non-twisting extrusion)
                                  That's where FollowMeAndKeep steps in... No twisting !
                                  Also 'EEbyLathe' sorts the FollowMe around and Arc issues too...
                                    right.. i was just trying to point out a case where autofolding doesn't (and can't) happen so that jgb understands when/where it's needed..
                                    maybe the follow me example just confuses the matter even more unless you already understand the inherent problems of that tool.. ??
                                    • brookefoxB Offline
                                      brookefox
                                      I refuse to apologize for being ignorant... I couldn't figure out for the life of me why when twisting with fredo scale, etc., I got nothing much. I had neglected to learn about auto-slicing in the parameters settings menus, or of enabling it with F4. I thought that some form of slicing had to occur, and tried slicing before executing and saw that worked as I thought the routine was supposed to work. In my defense, since I seem to need some, I think it should be more prominently mentioned. Or did I miss it?
                                      ~ Brooke
                                        Read it, tried it and I still don't see any advantage. πŸ˜’ ...
                                        Autofold (as the name implies) is mostly an automatic feature of SU when you force it not to maintain co-planar geometry. But you need to force it somehow. In your case, by pressing the up/down arrow. Some other cases (when axis alignment is not that obvious), you press the Alt key letting SU know that now you do not mind if it breaks a face or not.
                                        This is just like inferencing: you can always "encourage" SU to infer to certain things like parallel / perpendicular to something instead of axes etc.
                                        • jgbJ Offline
                                          jgb
                                          I C β˜€
                                          jgb
                                            ArCAD-UK
                                            I hadn't realised until recently that if you set Model Info>Components>Fade rest of model to hide you can still edit a group/component, triple click to select all faces and then (rt-clk) "intersect with model" which you can then edit as required.
                                            In some ways I prefer this over solid ops as it avoids creating a new group on layer zero 😑 .
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 34
                                            • 35
                                            • 17 / 35
