    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 652.5k Views 135 Watching
    • jgbJ
      jgb
      Another thing with Follow-Me I discovered a while back (and reported) is when you are defining a path that has curves, place the template face somewhere on a straight portion of any line segment, NOT at an endpoint. ๐Ÿ˜ฎ
      If follow-me starts on an endpoint, the face template follows one of the subtended angles and royally screws up at the end, with an end face out of alignment. This is especially a major factor with closed loops. ๐Ÿ‘Ž
      However, if started on a straight section, it will end perpendicular to the last line of the path, and if the path is a closed loop, it will join properly. ๐Ÿ‘
      jgb
        Useful to know! ๐Ÿ‘
        • broomstickB
          broomstick
          I've seen this pointed out before, but I just discovered that while orbiting with the middle mouse pressed, if you press the left button, orbit becomes pan.
          It's a useful way to orbit/pan without using two hands ๐Ÿ˜„
            Mini Doh ๐Ÿ˜ณ (due forgotten function) ๐Ÿ˜’
            • Alt gives you the possibility to Move a segment escaping at the X Y plan ๐Ÿ˜‰
              !!! ๐Ÿ˜ฒ OMF-DUH!!!
                A bit awkward though, as I use my index finger usually to press the middle mouse button, so I need to shift to my middle finger to free up my index for the left mouse button. ...which it was the right button that did that...
                • GaieusG
                  Ditto. I have known this "feature" but could never adapt myself to it.
                    That is very curious, because with the medium you can rotate many more the Mouse wheel than with index! ๐Ÿ˜ฒ
                    So more speedy scolling! ๐Ÿ˜Ž
                    For the simple reason that the Medium is biggest than the index! โ˜€
                    So the medium is always on the whell, so click it is a formality! ๐Ÿ˜„
                    Try it! ๐Ÿ˜‰
                    • jgbJ
                      jgb
                      Try it! ๐Ÿ˜‰
                      I have always used my mid finger on the wheel, with index on the left button. I also move my mid to the right button when needed as the ring finger has less control (which is why it is the "ring" finger ๐Ÿ˜† ).
                      It shouldn't take long to adjust to that finger position.
                      And now I know why my "orbiting" suddenly goes into "panning" when my index finger twitches downward sometimes. Now that I know, I can exploit that feature. Thank you Broomstick.
                      And Pilou, I fail to see what you mean with Move+Alt. โ“ Could you please explain a bit more?
                      jgb
                      • Jean LemireJ
                        Jean Lemire
                        Hi Pilou, hi folks.
                        Yes, pressing the ALT key enables Autofold.
                        Just ideas.
                          Is that more clear ? ๐Ÿ˜ณ
                          Without Alt Z axis is locked!
                          You can make some prisms or no coplanar faces with Move + Alt! ๐Ÿ˜‰
                          The Z axis become free with Move + Alt ๐Ÿ˜„
                          • GaieusG
                            And here is the autofold description:
                            http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94865
                              I wish there was an option to make SketchUp Smooth+Soft auto-folded edges.
                              • jeff hammondJ
                                I've been harping on this for years now but I don't think anyone ever tries it.. oh well
                                orbit with a thumb button (if your mouse has one).. not only is it more comfortable, it also gets rid of the double duty zoom/orbit mmb... AND- makes panning with the LMB much easier.
                                  Thumb buttons are Copy, Paste ...
                                  • jgbJ
                                    jgb
                                    Read it, tried it and I still don't see any advantage. ๐Ÿ˜’
                                    If I want to go Z (blue) I press the UP arrow and it seems to do the same as the autofold, but with exact axis control. ๐Ÿ‘
                                    It seems to me that autofold may hold an advantage if we had true 3D screens, but mine is standard 2D, and I cannot control, with any precision, where my object is moving to.
                                    jgb
                                    • jeff hammondJ
                                      using the arrow key is the same thing.. you're giving sketchup permission to break a plane(s) into multiple planes.. that's what autofolding means (in sketchup speak).. [and moving along the Z isn't always what's wanted.. hence the cmmd/alt key]
                                      now if only follow-me had an autofold option.. we'd then be able to, say, extrude around a helix without the twisting.. (notice if you try that now, sketchup prefers to keep planes in tact as opposed to folding them which is required for a non-twisting extrusion)
                                        That's where FollowMeAndKeep steps in... No twisting !
                                        Also 'EEbyLathe' sorts the FollowMe around and Arc issues too...
                                        • jeff hammondJ
                                          right.. i was just trying to point out a case where autofolding doesn't (and can't) happen so that jgb understands when/where it's needed..
                                          maybe the follow me example just confuses the matter even more unless you already understand the inherent problems of that tool.. ??
                                          • brookefoxB
                                            brookefox
                                            I refuse to apologize for being ignorant... I couldn't figure out for the life of me why when twisting with fredo scale, etc., I got nothing much. I had neglected to learn about auto-slicing in the parameters settings menus, or of enabling it with F4. I thought that some form of slicing had to occur, and tried slicing before executing and saw that worked as I thought the routine was supposed to work. In my defense, since I seem to need some, I think it should be more prominently mentioned. Or did I miss it?
                                            ~ Brooke
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 34
                                            • 35
                                            • 18 / 35
