    [Plugin] AreaTextTag
    97 Posts 27 Posters 90.8k Views 27 Watching
    • brookefoxB
      brookefox
      Thank you for sharing, TIG.
      Very, very useful for me...
      ~ Brooke
      • brookefoxB
        brookefox
        Is there a way to add multiple faces to get one total area? I see I can handily do multiple individuals to get multiple results...
        ~ Brooke
          The areas of 'surfaces' made from faces with smoothed edges are reported as 'one' if the edges; visibility is 'off'.
          You can of course report areas of selected/all tagged faces using a CSV file and the appropriate tool in the set...
          Please read the notes...
          • brookefoxB
            brookefox
            Well, thanks. I read your top notes, if that's what you mean (and the rest though less carefully). I see nothing about my question but don't doubt I may be missing it still.
            Trying your instruction doesn't work for me. Please see this pic:
            http://img831.imageshack.us/img831/2294/areaacres1.jpg
            ~ Brooke
              It's not so clear from your image what it is you are trying to tag...
              If the boundary edges between two faces are 'smoothed' [and not visible] then the picked/selected area-tag reports the area of the 'surface' - i.e. the two combined faces - otherwise each face gets an individual area-tag.
              If you want to show an area split into 'parcels' provided that the dividing lines don't split the face then the area-tag will refer to the underlying face. To stop the face splitting you could either leave a small gap in the line so there is no loop and therefore the face isn't split, or you could use a group to separate the 'dividing' lines from the face so that whilst the face might look like it was divided up it is not, OR draw two sets of faces - one set sub-divided and tagged individually and the other made as a copied group of faces on its own layer with dividing lines removed so there is one face to take the 'combined' tag... Also if you know the total area of a group of plots [found from a temporary outline say] you could add that to each tag's suffix - e.g. "Plot 1 <>\nof 12.3acres", "Plot 2 <>\nof 12.3acres" etc where each <> will contain the actual area, then if you adjust the dividing lines between plots an auto-recalc will adjust each plot's area but display the total consistently ?
              You can export a CSV file listing areas-tags and any text you might associate with the area-tags to help identify them. The total is easily got for the area-tags in a column...
              • brookefoxB
                brookefox
                Thank you. My problem was with the 'visibility off', by which you were not referring to hidden or not as I had assumed, but rather to smoothing aspects.
                Work-arounds are easy enough.
                To clarify what I'm trying to tag:
                http://img16.imageshack.us/img16/3326/areaacres2n.jpg
                ~ Brooke
                  If it's a single face it gets one area-tag - delete the intervening edges if it's all coplanar.
                  If it's a single surface that's not coplanar you must 'smooth' the common edges between faces [not just 'hide' them] - i.e. with view>hidden-geometry 'on' use Erase+Ctrl. Then with view>hidden-geometry 'off' place an area-tag on one of the surface's faces - now it'll report the 'surface area' - i.e. the combined areas of all of the connected faces...
                  • C
                    castaway
                    Thank you for such a useful plugin, TIG.
                    I am having some trouble with accents though, take a look at the screenshot, it should read "HABITACIÓ 1 ..." "HABITACIÓ 2..." and "DISTRIBUÏDOR". Should I change any setting to adjust the text language or character set?
                      If you use those accented characters in 'plain' Text does it then work OK ?
                      The tool should simply concatenate the same text/areas into one string...
                      • C
                        castaway
                        Do you mean creating a text label through Tools > Text? If so then yes, accents are displayed just fine.
                          Here's v1.4 http://forums.sketchucation.com/viewtopic.php?p=373717#p373717
                          The correct interpretation of UTF8 accented characters etc in customized area-tags has now been resolved.
                            OK...
                            You have the area-tags inside a locked-group.
                            It [should***] only reports on tags in the active_context.
                            So unlocking the group and editing it should then produce the CSV...
                            ***BUT it fails - I am investigating why... 😕
                            If I explode the group the area-tags export OK, BUT I notice the Unicode accented-character errors recurring - so I'll fix that at the same time...
                            Watch for an update soon...
                            • C
                              castaway
                              Hi again,
                              I noticed the behaviour you described and was about to post about it when I saw your comment.
                              One more thing about the exported cvs file if I may: as you can see I am using the following structure for the labels: label name, a new line and the area. The exported cvs outputs exactly this, in the form of "LABEL NAME\n<>", which does not seem very clean. What I can do is run a "find and replace" operation for "\n<>" in LibreOffice and delete it, but imo it would be cleaner if that information was not in the cvs exported file.
                              Thanks for looking into this.
                              • C
                                castaway
                                Wow, that was quick and effective. Now it works beautifully, thanks a lot!
                                I am having some trouble exporting to cvs though, the only contents of the exported file is "LAYER,TEXT,PERIM,AREA,UNITS". Perhaps I am doing something wrong, but I think I have followed the instructions properly (save as and then export to cvs). I am attaching you the skp file used in my tests.
                                areas_v4.skp
                                  Here's v1.5 http://forums.sketchucation.com/viewtopic.php?p=373717#p373717
                                  The CSV reporting is fixed - it now uses correctly accented UTF8 characters, and now reports Tags in the active context properly [so if they are inside a group edit that group before running the reporter].
                                  It now also strips all '\n' from reported 'names'
                                  It substitutes '/' if there is multi-line text, other than 'name\n<>' which becomes 'name' anyway, whereas 'name\nmore\n<>' becomes 'name / more' in the reported name.
                                  If the name includes text other than '<>' then the '<>' is always omitted - so 'name <>' becomes 'name '.
                                  However, a Tag with just a '<>' [or '<->'] is still reported as named '<>'.
                                  • C
                                    castaway
                                    I just tested it and works perfectly, I wish I had a hat to take of to you. Thank you so much!
                                    • Z
                                      ZFRPS
                                      Dear Tig:
                                      good job!The CSV reporting is my want,Very slow when reporting ....
                                      sketchup is bim
                                        Its 'slowness' is because it must find all text-tags in the current context by sifting out other things, then it must 'update' them in case a tagged face has changed since the last update, it also must check for tags that are no longer glued to a face and ignore them, and also for duplicate tags placed on the same face and so on [this can be done beforehand using 'Update' manually, which might speed up the CSV a little]... the writing of the CSV file itself is relatively quick once the updating concludes... 😉
                                        I noticed that your CSV toolbar button icon is missing - I have missed it out of the subfolder set.
                                        I'll add it to any future updates, but meanwhile if you substitute/add these two PNG files into the tool's subfolder it will fix the missing icon...
                                        • Z
                                          ZFRPS
                                          Dear Tig:
                                          Here amount only:1001006=60000;slow !!Half an hour past it no finish!
                                          if csv change to xml ?
                                          or other way ?
                                          Thanks again !
                                          sketchup is bim
                                          • Z
                                            ZFRPS
                                            OK!
                                            Irrespective !
                                            I only look forward to it change to very very quickly !
                                            Your job is great for all SU-FANS,I love you !
                                            THANKS AGAIN
                                            sketchup is bim
                                            • 2 / 5
